DeathBySnuSnu Samba Member
Posted: Sun Jul 03, 2016 6:46 am Post subject: Re: WooooHooooo |
Yeah Mark....
I already had much of the swing axle stuff. Besides it is difficult to get anew irs this narrow. |
Posted: Sun Jul 03, 2016 6:48 am Post subject: Re: WooooHooooo |
Only 4ft wide to the outside of the tires.
Posted: Sun Jul 03, 2016 6:52 am Post subject: Re: WooooHooooo |
Front end.
Posted: Sun Jul 03, 2016 6:57 am Post subject: Re: WooooHooooo |
One piece at a time.
So many small parts yet to make.
Posted: Mon Jul 11, 2016 7:16 pm Post subject: Re: WooooHooooo |
Rear suspension is together.
Now finishing the front.
Posted: Wed Jul 13, 2016 7:46 pm Post subject: Re: WooooHooooo |
2387 goes here.
satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Thu Jul 14, 2016 2:47 pm Post subject: Re: WooooHooooo |
Did you flip the ring gear? If not, 4 reverse 1 forward. _________________ DDC racing |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Jul 14, 2016 3:16 pm Post subject: Re: WooooHooooo |
The trans itself is flipped .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Jul 14, 2016 4:21 pm Post subject: Re: WooooHooooo |
Right, didn't catch that. Great project, will be waiting to see it finished. _________________ DDC racing |
EVfun Samba Member
Posted: Thu Jul 14, 2016 6:34 pm Post subject: Re: WooooHooooo |
gears wrote: |
The trans itself is flipped .. |
How does that work? The 4 bolts holding the engine to the transaxle are not at 4 equal points. From the crank center the upper 2 bolts on the block are 42 degrees left and right, the lower to bolts at 45 degrees left and right. At least those numbers worked to make an electric motor adapter plate. _________________
Wildthings wrote: |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Jul 14, 2016 7:22 pm Post subject: Re: WooooHooooo |
EVfun wrote: |
gears wrote: |
How does that work? The 4 bolts holding the engine to the transaxle are not at 4 equal points. From the crank center the upper 2 bolts on the block are 42 degrees left and right, the lower to bolts at 45 degrees left and right. At least those numbers worked to make an electric motor adapter plate. |
Go back and take a closer look at the pictures. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Thu Jul 14, 2016 7:25 pm Post subject: Re: WooooHooooo |
The engine end bolts to this drive extension.
The adapter plate has the upside-down pattern.
This moves the engine forward.
Scroll back to the very first pic on page one to get an idea how it assembles. |
EVfun Samba Member
Posted: Thu Jul 14, 2016 8:14 pm Post subject: Re: WooooHooooo |
DeathBySnuSnu wrote: |
That is trippy. it looks like a repurposed transaxle case and an adapter to move the engine forward and correct the bell housing pattern. So does that mean you have a custom made long input shaft? _________________
Wildthings wrote: |
Posted: Thu Jul 14, 2016 8:59 pm Post subject: Re: WooooHooooo |
Yes |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1172 Location: San Angelo, Texas
Posted: Thu Jul 14, 2016 9:18 pm Post subject: Re: WooooHooooo |
Holy shit. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Sat Jul 16, 2016 12:00 pm Post subject: Re: WooooHooooo |
There are more than a few handmade parts on this thing.
Posted: Sat Jul 16, 2016 12:10 pm Post subject: Re: WooooHooooo |
Your first rodeo? _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
Posted: Sat Jul 16, 2016 5:07 pm Post subject: Re: WooooHooooo |
Have been around the block a few times.
Posted: Wed Jul 20, 2016 6:23 pm Post subject: Re: WooooHooooo |
Making up the whatchamacallit and the doohickie stuff on the tail end.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7552 Location: Santa Cruz
Posted: Thu Jul 21, 2016 8:31 pm Post subject: Re: WooooHooooo |
Love it!
Been watching this on the STF..
My race-car hole-drilling lighten-ing hand just wants to drill so many holes in that empty trans case motor-spacer dealie-O I just can't tell ya!
It looks nice as a complete piece like that, don't get me wrong,
But the fact that about half of it could be turned into chips just won't leave me alone! _________________ Bus Motor Build
What’s That Noise?!? |
