1973 412 WAGON Samba Member
Joined: February 12, 2015 Posts: 68 Location: N.Dinwiddie VA
Posted: Thu Jun 02, 2016 6:44 pm Post subject: 1973 412 Fuel Sending Unit |
Anybody know where I can get a fuel sending unit? Or one that will work for my 73 412? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21521 Location: Oklahoma City
Posted: Thu Jun 02, 2016 8:20 pm Post subject: Re: 1973 412 Fuel Sending Unit |
Look for the part # on yours. It looks like its almost identical to the type 3 sending unit and they are having a discusion on the type 3 forum about them right now.
The type 3 uses rwo different lengths.....a 165 and a 170mm. I will measure my spare in the morning. But our part # is a type 4 part #..411 919 049...so its usually uniqie in some way. I cannot remember if I have ever swapped in a type 3 unit. Have to check my log book.
You can rebuild then if you are industrious. Several threads about this.....most linked to that type 3 thread. I will be rebuilding mine moving forward....and do a pictorial. Just have not gotten to it yet. Ray |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5999 Location: Brooklyn
Posted: Fri Jun 03, 2016 6:19 am Post subject: Re: 1973 412 Fuel Sending Unit |
Jim Adney rebuilds Type 3 fuel level senders, if they are similar to Type 4 maybe he can do those too? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Jun 03, 2016 7:24 am Post subject: Re: 1973 412 Fuel Sending Unit |
Sure!....forgot about Jim working on these .....however. ..as a rule for type 4 owners....something this simple. ....you should fix this yourself. Its pretty simple and takes few tools....all of which you should have.
The issue for me....is that if you are going to own and drive a type 4.....unless you are fairly wealthy or just have huge disposable income. .....you need to learn to do a lot of your own rebuilding.
This is not a type 3.....in the respect that short of a type 34 ghia......there are far far fewer parts available for type 4 cars than there are for type 3 cars.
Also....for example.....unlike the suspension of the type 3......when type 4s get to a certain point of wear.....they can't be driven without replacing a range of parts that are just NLA.
The vast majority of non seriously invested owners of type 4s.....that have come through the Samba and STF......have given up because of the long term costs......meaning you can't just go down and buy many basic wear parts for these cars.......and there are few if any people like ISP west.....making specialty parts for these cars.
If you want to own .....and drive......these cars and you have roughly 3x the budget of what owning a type 3 car of the same era requires......go for it!.....spend the money to have others rebuild all of your parts.
If not......I urge owners to start getting into doing your own work. If not.....the endless series of $100-$250 parts you will have to buy....and still not even have the full range of parts available that you need......will stop you from owning these cars.
Build your skills......learn and help the your own community. This is why I work to make the directions for how to rebuild and restore parts for these cars available.
If this were something like....remolded tail lights or restamped metal parts......which take heavy research and investment on the part if the person doing them......and are a real service to the community......and should be supported.
Otherwise......you are just paying for the labor of others. Which is fine if you can afford it. Ray |
ClassicCamper Samba Member
Posted: Sat Jun 04, 2016 12:30 am Post subject: Re: 1973 412 Fuel Sending Unit |
Quote: |
If you want to own .....and drive......these cars...I urge owners to start getting into doing your own work. If not.....the endless series of $100-$250 parts you will have to buy....and still not even have the full range of parts available that you need......will stop you from owning these cars.
Build your skills......learn and help the your own community. This is why I work to make the directions for how to rebuild and restore parts.
X2.
I went down the rabbit hole of sending out parts for 'refurb' or 'rebuilding' and my wallet was hit for $150 at a minimum. I'm not wealthy, so I tried to learn quickly. One thing I AM proficient at are statistics; that is more or less my career. I can say with confidence that purchasing a Type 4 in 2016 that does not have a cascade of urgent repairs is virtually impossible.
I hope some of my posts have helped others, and look forward to learning and contributing more. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
