jimj90 Samba Member
Posted: Sun May 29, 2016 11:34 am Post subject: 1970 beetle won't idle. What should I try first? |
I'm new to this so bare with me
Car idled fine. Then the idle slowed down a bit and seemed like it wanted to stall this happened slowly over a month or so.
I sped up the idle with the idle screw and it still won't idle at all
Starts up fine and revs fine just stalls when I let off the gas
I also messed with the air fuel screw a little.
No results. I tried without the air filter it's kinda dirty no results
What should I do next?
Thanks! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9775 Location: Oregon
Posted: Sun May 29, 2016 11:39 am Post subject: Re: 1970 beetle won't idle. What should I try first? |
Probably have some crap in the idle jet. Might be a good time for a carb cleanup.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
gt1953 Samba Member
Posted: Sun May 29, 2016 11:48 am Post subject: Re: 1970 beetle won't idle. What should I try first? |
What type of carb do you have on the engine?
If it is a stock solex type, do check the idle cut off solenoid. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Bama Dave Samba Member
Posted: Sun May 29, 2016 11:55 am Post subject: Re: 1970 beetle won't idle. What should I try first? |
Try the Rob and Dave adjustment instructions. Go step by step...
http://www.vw-resource.com/34pict3.html
Good luck. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sun May 29, 2016 12:06 pm Post subject: Re: 1970 beetle won't idle. What should I try first? |
Dwell
also called
point gap
It's in the distributor the thing with the spark plug wires on top of it. |
