joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Wed May 25, 2016 6:19 pm Post subject: Thermostat - yes or no? |
So I am contemplating installing a thermostat and flaps in my 1971 bug. I have never run this bug before. I have a complete thermostat, flaps, linkage assembly I can use. For some reason, I feel kind of scared of it, kind of if it aint there, it cant break. Also, the thermostat came off a fuel injected bug, and its rated warmer than what would have come stock on a '71. I live in California, so I am not dealing with freezing temperatures. Whats the up and downside to using it? Is it reliable and trouble free? Any one ever have problems with it? What year were they added, or did bugs always have them? |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Wed May 25, 2016 6:53 pm Post subject: Re: Thermostat - yes or no? |
When you install the thermostat make sure you test in tith a heat gun or hair dryer to make sure it's not binding. Then do a couple of a couple of short runs to make sure it's not binding once the engine is warmed up and expanded. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Wed May 25, 2016 10:59 pm Post subject: Re: Thermostat - yes or no? |
yes run it! _________________ 67 bug x3
67 ghia
64 bug |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed May 25, 2016 11:01 pm Post subject: Re: Thermostat - yes or no? |
I believe the thermostats for fuel injected engines open at a much hotter temperature. So don't use the one you have.
I live in California where it gets really hot in the summer. But it also gets cool in winter. So in winter, especially, you will get your engine warmed up much faster in winter if you have a proper thermostat, if properly adjusted.
If you want to test a thermostat, be sure to keep it in its bracket while aiming a hair dryer at it. If you don't you can over expand it because it will just keep expanding. I've seen some that grew to six inches and were ruined.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Thu May 26, 2016 3:33 am Post subject: Re: Thermostat - yes or no? |
Tim Donahoe wrote: |
Tim |
Regular thermostat is 65-70 degrees, FI thermostat is 80-85 degrees. Should be marked on the thermostat. |
Zundfolge1432 Samba Member
Posted: Thu May 26, 2016 4:28 am Post subject: Re: Thermostat - yes or no? |
Here's one you shouldn't use
Posted: Thu May 26, 2016 4:31 am Post subject: Re: Thermostat - yes or no? |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Thu May 26, 2016 6:03 am Post subject: Re: Thermostat - yes or no? |
Know plenty of people who dont...mainly those who lost engines due to them sticking |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Thu May 26, 2016 6:53 am Post subject: Re: Thermostat - yes or no? |
VW engineers had them installed at the factory. Do add them to the engine and make sure you have the correct temp. Test the system once it is installed. Imagine if your water cooled car did not have a thermostat. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
pistolpetecowboy Samba Member
Joined: February 10, 2014 Posts: 122 Location: Oklahoma
Posted: Thu May 26, 2016 7:07 am Post subject: Re: Thermostat - yes or no? |
Make sure your linkage doesn't bind and test with hair dryer/heat gun.
Also check that it has full range of travel and nobody has tweaked the crap out of the rods/other linkage trying to get the fan shrould off. ->
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...mp;start=0
Volkswagen put them in there for a reason, even expansion during warm up, cooler heads, etc.
If it makes you nervous get one of those dipstick temperature sensors or an oil temp gauge.
The original german thermostats fail open for safety and you can get them here:http://www.bugcity.com/shop/shop.htm?pquery=thermostat
If you do decide against running a thermostat, I would suggest leaving the flaps in the shroud and just wiring them wide open. _________________ 70 Beetle, 70 Beetle, 71 Beetle, 71 Super, 73 Super, 74 Beetle, 2000 Vintage Speedster, 2020 Jeep Renegade, 71 Squareback |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Thu May 26, 2016 2:34 pm Post subject: Re: Thermostat - yes or no? |
Zundfolge1432 wrote: |
That looks like one that was tested with a heat gun. I was being careful with a heat gun and made one look like that. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26328 Location: Douglas, WY
Posted: Thu May 26, 2016 4:39 pm Post subject: Re: Thermostat - yes or no? |
You think that one's bad....
link to thread
_________________ Andy T.
Posted: Thu May 26, 2016 5:03 pm Post subject: Re: Thermostat - yes or no? |
Thus, when testing do NOT heat up the thermostat unless it's in the confines of it's bracket. And only heat it until it reaches the top of the bracket. All you need is about a 5/8 inch expansion, anyway. That's all the movement you're going to get (or need) when the thermostat is installed.
Some people like to throw the thermostat in a pot of boiling water when testing. The previous pictures show the results. I simply use my wife's hair dryer. It doesn't take long for the test.
Richard O'Brien |
Posted: Thu May 26, 2016 6:23 pm Post subject: Re: Thermostat - yes or no? |
gt1953 wrote: |
VW engineers had them installed at the factory. Do add them to the engine and make sure you have the correct temp. Test the system once it is installed. Imagine if your water cooled car did not have a thermostat. |
A thermostat in a water cooled engine has absolutely no relevance in this discussion,a water cooled thermostat can control and maintain temperatures to 5 degrees..an air cooled thermostat does not modulate any more than open at an indeterminate temperature and allow cooling air to flow over the heads.. VW engineers installed altitude compensators too, do you have that on your car?.. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 26, 2016 7:03 pm Post subject: Re: Thermostat - yes or no? |
johnnypan wrote: |
gt1953 wrote: |
Why yes,.....yes I do, and I enjoy the way it improves the way my VW drives every day. Having taken the time to figure out what it does and how to adjust it I can't live without it now, those German engineers weren't just making shit up.
As for the thermostat it's not about maintaining a constant temperature while driving, but it does significantly improve the warm up time and prevent shock cooling coasting down hills. Consider the expansion rate of different metals in the engine, aluminum pistons expand much faster than steel barrels, if you like your pistons sloppy it's not an issue if they swell up before the cylinders do, but if they fit close and you want them to stay that way getting the barrels warm before the pistons is mighty handy. Same deal with barrel to head joints, every time one surface moves against the other it wears, sooner or later it's loose and leaking. And how warm the oil is in relation to pushrod expansion mostly plays on the sound they make, but if something's loose enough to clatter it's also beating itself to death slowly, the quicker everything gets warm together the better.
You may have had some bad thermostat experiences, no system is fool proof, but when set up properly they work very reliably and as mentioned fail open, install it carefully and keep your engine clean and it's a system you can almost forget about until the next time the shroud has to come off.
Some prefer Chocolate ice cream, others Vanilla, and some want both with sprinkles on top. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Thu May 26, 2016 7:55 pm Post subject: Re: Thermostat - yes or no? |
Top post Busdaddy.
The thermostat and movable flaps have SEVERAL functions. When shut(cold) the flaps still allow about 25% airflow so the thermostat will see some air and work when it's supposed to. The engine warms much faster with the thermostat installed, and the cabin heater starts to work much sooner. The time for the thermostat to open the flaps approximates the time that the choke opens, so the engine works smoother both cold and hot.
When the thermostat opens, the outer movable flap touches the bottom of the heads, creating a separate air path inside the should for the heads and cylinders. Since the airflow from the fan flows outwards to the outer edges of the fan shroud, the result is a little more air to the hotter heads, and a little less to the less-hot cylinders.
No thermostat means slower engine warm-up, greater engine wear, less effective cabin heater.
No movable flaps means less effective cooling of heads and cylinders.
Very clever, those German engineers. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Sat May 28, 2016 12:32 pm Post subject: Re: Thermostat - yes or no? |
incidentally, I was looking through the 1966 Without Guesswork and spotted this:
bomberbob Samba Member
Posted: Sat May 28, 2016 7:08 pm Post subject: Re: Thermostat - yes or no? |
I have had a beetle, two type 3, and a bus. None had thermostats except for the one type 3 on the island of Guam. It was stuck closed, so I wired it open.
The beetle spent probably a decade on the Mojave desert. I never thought that much about it. I just drove them.
Now, the derelict I bought off of ebay still had the thermostat in I, so I think I will keep it. Its a novelty. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon May 30, 2016 4:56 pm Post subject: Re: Thermostat - yes or no? |
Joemama, Hi.
You are in a perfect position to answer many of your own questions. If I were in your position I would:
1- Verify and document the engine's condition/tune.
2- Buy the Berg/Save a Bug oil temp dipstick, which is locally avail for about $35.
3- Install the dipstick and cruise around the local area and verify the little metal rods position, if not overheating around town.
4- Run your car down the 2 freeway from La Cresenta to the end and verify the dipsticks position.
5- Now run your car back up the 2 freeway from the previous spot back up the hill and see if the dipstick shows any overheating, via a glowing oil lite.
6- Document your results.
7- R&R your engine and install the complete flaps assembly.
There are a few things to inspect/repair/install at this point, such as hoover bit, foam on cooler , debris on cylinders/heads, etc. But improvements here can influence readings.
8- Repeat your local driving and the 2 "freeway run".
Please recognize the thermostat/flap system serves two functions, at least. One, proper warm ups and two, proper deflection of air to the cyl heads and upper parts of the cyl's. If still online Gene Berg Ent had many writings about this subject. Mr Berg's info is 40 years old, and still valid! I guess I'm a hypocrite as my daily driver overheated (previous owner) has no flaps in the shroud now.
Hope this helps, Bill.
Let me know if you need any help with this as I'm using this method (the 2 freeway) as a test. |
sb001 Samba Member
Posted: Mon May 30, 2016 5:13 pm Post subject: Re: Thermostat - yes or no? |
I just pulled mine. As is it was probably not doing much of anything anyway since I couldn't install it correctly (more on that below), but my bigger concern was that the pushrod on mine was not correctly oriented and might jam up inside the cylinder head fins, or cause the (too large) bolt/ nut on the flap arm securing my air cleaner cable to jam up against the fan shroud flap mounting screw. Until I pull the fan shroud and get all that fixed, it's better to run it without.
As long as you are sure that you can install it correctly and nothing is jamming it I have no problem with it.
Now, as mentioned earlier, here's some enjoyable reading for you:
http://www.thesamba.com/vw/forum/viewtopic.php?t=654264&postdays=0&postorder=asc&start=0 _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
