gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Sat May 28, 2016 7:14 am Post subject: Re: Who sells a brake light switch worth a damn? |
Well I buy mine from O'Rielly life time warranty. Buy them once and don't look back. They do not like it when I walk in the store and have a part in hand. First one lasted a week the one I have now is two year old. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5311 Location: Central Florida
Posted: Sat May 28, 2016 7:30 am Post subject: Re: Who sells a brake light switch worth a damn? |
Perhaps a stupid question but should you flush before or after changing out the switch? Would flushing possible loosen or dislodge something within the switch to possibly make it start working again? I will say I have very nice pressure at the pedal and the car stops very well. I could easily lock the brakes up if needed. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sat May 28, 2016 8:05 am Post subject: Re: Who sells a brake light switch worth a damn? |
Try a Standard SLS33. I`ve had good luck selling them in the past. Everything else has been coming back. _________________ If you`re going to do something, do it right. |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
glutamodo The Android
Joined: July 13, 2004 Posts: 26328 Location: Douglas, WY
Posted: Sat May 28, 2016 2:20 pm Post subject: Re: Who sells a brake light switch worth a damn? |
excellent! The only other place I remember selling those was OEVeedub and when they went away I thought I'd never see them again. _________________ Andy T.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11057 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun May 29, 2016 9:43 am Post subject: Re: Who sells a brake light switch worth a damn? |
Slight topic detour... but applicable...
flyboy161 wrote: |
" Then I looked in my '64 owners manual and behold:
IMO
5 years is WAY too long.. for Dot 3 - 4 (and this new 5.1)
Its not only the moisture content levels.. its also the drop in the boiling point..
The boiling point is generally not an issue on these old German tin cans.. but .. the moisture content degrades the system..
Better safe than sorry, $10 bucks and a half hour is cheap insurance every couple of years...
BUY quality fluid..
VOLKSWAGNUT wrote: |
Lot of us have been down this road... with no brakes or inferior parts.
One thing I've had to start doing over the years... clean "New" master and wheel cylinders BEFORE installation.
I know that sounds "Nutty"
I buy most parts locally. Easy to find, no shipping, and has a warranty. Yes some of the quality is low...
For brake parts I try to buy Napa, Beck Arnley, or TRW when I can but sometimes.... cheap out.
Somewhere in the ....inexpensive (and expensive) brand brake manufacturing process, 2 things are lacking. 1 bore surface and 2 bore cleanliness.
When I disassemble new units I have found semi rough honed bores along with a gritty feeling. Occasionally rust..
Clean, lightly re hone, clean everything, assemble and lube with quality brake fluid. THAT"S IMPORTANT. Not all brake fluids are considered equal. Buy good name brand fluid.. I usually use GM brake fluid ... but recently tried some Kia fluid that had completely different smell and texture.. Almost oil like and yet still 100% DOT 3. Needless to say it lubed up the cylinders and cups very well. Castrol LMA brake fluid has proven to be good fluid as well.
After I started my pre cleaning 15-20 years ago.. I've yet to have an issue with new cylinders, failures and the inability to simply bleed.... . Before that.. I wasted lots of gas getting bad new parts swapped out..
FLUSH BRAKE FLUID EVERY 2 YEARS... Period..
flyboy161 wrote: |
I would flush, change the bad switch and then bleed. The fluid change the dealer used to do was done with a pressurized tank bleeder and made it an easy job. You want your fluid to be just as clear coming out as going in. Not black. |
Thats is a great approach ..works well.. ensures clean fluid is at the new switch.. but does create some extra work..
In the event a switch must be changed....
I start with clearing all the fluid I can from the reservoir...
Use a cheap turkey baster and clean it well afterwards for future use.. DO NOT use the one from your kitchen.. .. trust me on that one..
If you are feeling REALLY OCD.. remove the reservoir.. and clean with ISO 99 or spray brake cleaner and dry.
Change the switch allowing it to drip fluid a little keeping an eye on the reservoir, install the new switch or switches.. then proceed with the single pump, and push exchange method..
Bleeder advice.
A pressurized bleeder can be made with an extra reservoir car, a fitting.. and a cheap tank pressure garden sprayer..
The reservoir just needs a very light amount of pressure to assist the bleeding process.
Vacuum bleeders work but.. at times on drum brakes and wheel cylinders a vacuum bleeder can draw actually air by collapsing the cup seal.. More so if the system has a restriction like at the brake hoses.. Also vacuum bleeders can pull the cups all the way inward and IF the cylinders have issues can actually cause damage and a leak..
By myself.. I sometimes use a high (light) vacuum bleeder..BUT.. I am also slowly pumping the pedal to assist the exchange..
Lots of methods out there..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Fri Jun 03, 2016 6:06 am Post subject: Re: Who sells a brake light switch worth a damn? |
For anyone caring, the bad switch in question was an FTE. I looked for a datecode marking on the part, but only thing I saw was 205, so not sure if that's a part number or datecode? Either way, brake lights work using a NAPA switch. Unfortunately, due to time restraints and the lack of a helper, I wasn't able to actually flush the brakes. Swapped the switch, drove it around a little and the brakes are fine and lights are working. I purchased and extra switch that I may swap out when I get a chance to actually bleed and flush the system. Does look like it needs it as I can see some potential crud in the reservoir and the color is a bit more orangy/yellowy than the clear stuff I put in. Needs it, but for right now a lick and a prayer is going to have to work to get it so it can be driven.
Also, for anyone that cares, I did get an offer from Antonio for the Mera switches. Unfortunately, the shipping costs were a bit out of line for shipping from Mexico IMO so I had to pass, but maybe someone would be willing to sub distribute or get a group buy together to offset the shipping? |
wcfvw69 Samba Purist
Posted: Fri Jun 03, 2016 7:09 am Post subject: Re: Who sells a brake light switch worth a damn? |
[quote="Antonio Trejo"]
Are these switches 3 prong or two? I can't tell in the pictures. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Jun 03, 2016 7:16 am Post subject: Re: Who sells a brake light switch worth a damn? |
I'm also an advocate of flushing the brake fluid every couple of years. As mentioned, it doesn't cost much in brake fluid and does only take 30 minutes. I built a hand power bleeder for around $25 bucks though they sell nice ones for $60.
I'm always amazed at how dark and nasty the brake fluid is after only a couple of years. I suffered some wheel cylinder failures in that they leaked. Taking them apart, they were rusty inside. This was before I started flushing the fluid regularly.
I buy good, German made brake parts that are not cheap these days. I want them to last as long as possible and flushing the fluid is cheap insurance. _________________ Contact me at [email protected]
Posted: Fri Jun 03, 2016 7:23 am Post subject: Re: Who sells a brake light switch worth a damn? |
Do you have a parts list or description of what you used? I think I get what you're doing, which is pressurizing the brake reservoir while you bleed them? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Fri Jun 03, 2016 8:54 am Post subject: Re: Who sells a brake light switch worth a damn? |
flyboy161 wrote: |
Gonna have to agree with Ken here. I bought a BMW a couple of years ago and one of the maintenance tasks is flush the brake fluid every two years. I thought, "What?" Then I looked in my '64 owners manual and behold:
And in the '71 Type 3 manual (among others), VW shortened this to as often as once a year:
Posted: Fri Jun 03, 2016 9:01 am Post subject: Re: Who sells a brake light switch worth a damn? |
KTPhil wrote: |
flyboy161 wrote: |
Gonna have to agree with Ken here. |
I guess VW wised up.. at one point..
I used a $9 pump sprayer, an extra reservoir cap with a barbed fitting screwed into a drilled hole..
Simply push the sprayer hose on the fitting and pump.
It only needs a little pressure difference to do the job..
I only use pumped up air in the sprayer.. and add fluid to the reservoir as it gets low and re pump.. That way no fluid is in the sprayer..
Posted: Fri Jun 03, 2016 9:03 am Post subject: Re: Who sells a brake light switch worth a damn? |
Sharp64 wrote: |
I'll copy and paste my answer to a PM-
Yup.. it's a $12 dollar hand pump weed sprayer. I drilled a hole into it for the PSI gauge that cost $7-10 bucks. I simply screwed the gauge into the side of the bottle. The end that screws into the reservoir is actually a cap from a quart bottle of engine oil. I made a cork gasket that fits inside the cap to seal the air from leaking out.
Here's how I use it-
I have an old turkey baster. I suck up as much of the old brake fluid as I can out of the reservoir. I then top it off w/new brake fluid. I screw the hose from pump onto the reservoir.
I pump up the hand pump to around 10psi. I then start at the RR and crack the bleeder with a clear hose fitted over the small bleeder screw that runs the old brake fluid into a clear bottle. I let it run until I get clean brake fluid out of it. On this long run, I'll close the bleeder once and pump the hand pump back up untill I get 10PSI again. I repeat these steps hitting one corner of the car at a time. Again, I often check the brake fluid reservoir level and pressure on the pump as I go through all 4 corners. I don't put nor need any fluid in the hand pump. It really doesn't use that much new brake fluid to flush out the old. I think I only re-top off the reservoir as I'm bleeding all four corners once or twice.
As I mentioned in that thread, it really only takes 30 minutes to do all four corners. I usually jack up the bug and put it on jack stands for ease of getting under the car to the bleeders. I'm getting too old to crawl and reach for the darn things! lol
I hope this helps!
Bill
You can probably buy everything needed at Wal-mart as well. I bought my items from Ace Hardware. _________________ Contact me at [email protected]
Posted: Fri Jun 03, 2016 9:11 am Post subject: Re: Who sells a brake light switch worth a damn? |
Awesome. Thanks. Sounds easy enough. |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sat Jun 04, 2016 1:42 pm Post subject: Re: Who sells a brake light switch worth a damn? |
Hi. I have been a victim of the shit brake lite switches. My parts supplier was selling me these EuroMax switches with the local distributor placing their decal over the "made in china" writing. WTF!
I recognized this problem with the 2 prong/3 prong brake switches and subsequently bought the 356 Porsche switch from Pelican Parts, in the Los Angeles area. The part number is 901-613-401-00. They offer the ATE brand for $15 and the genuine Porsche brand for $24. I bought the ATE switches. The application is for the 356 cars, 1956-1956. This switch is a bit different as the threads are not tapered but straight at 10mm x 1.0mm, with a crushable washer/gasket. I installed the 2 prong switchs, with a minor wiring mod.
To this date I have been happy with this. No leaks at the switch/gasket and pedal effort to illuminate the stop lites is adequate.
I know there are a number of retailers selling switches which tend to alleviate this quality problem with the Chinese crap. |
