Axel Andersson Samba Member
Joined: June 03, 2011 Posts: 132 Location: Sweden - Europe
Posted: Thu May 26, 2016 9:39 pm Post subject: Color code - handbrake and gearstick |
Does anyone have the color code/RAL for the Brown color on the handbrake lever and gearstick on a 1950 split? |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1050 Location: Germany
Posted: Fri May 27, 2016 1:32 am Post subject: Re: Color code - handbrake and gearstick |
Perhaps Nancy colud give us a hint? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri May 27, 2016 7:09 am Post subject: Re: Color code - handbrake and gearstick |
http://www.thesamba.com/vw/forum/viewtopic.php?t=193254&start=0
I found that RAL 8025 (L71) seemed to match the best on my 49 deluxe.
On my steering column, under the rubber was a nice area that was unaffected by sun, moisture, etc. so I felt like this was a pretty accurate estimation of the original color.
The really faded beige color you see on a lot of restored cars matches what the rest of the steering column looked like as well as the seat frames, shifter, etc.
This convinced me that the actual L71 color is a much richer, darker color very close to the RAL 8025
I found this color in a rattle can online at LowVolumePowder.com. It's also readily available in powder coat for those of you that do that sort of thing but I don't know how the paint and powder coat colors compare.
Posted: Sat May 28, 2016 12:35 am Post subject: Re: Color code - handbrake and gearstick |
Thank you very much Nancy.
Found in the actual thread of correct wheelcolour for bordeaux red splits:
"JT Garwood self published a two volume book called "Volkswagen Beetle car of the Century" decades ago. It was typewritten on a typewriter and spiral bound volumes. It lists every color spec of every year for any part. It also details out chassis number changes as the running detail changes appeared year over year. Want to know the correct color for your e brake boot on your Turkis 61 beetle??? (It's different than 62!) This is where you find it... Want to know the last chassis number for stale air 40 horse... It's in there... Want to know the last chassis number that had a given transmission ratio... color of the pinstripe on your split beetle wheels... Etc etc. it's all there. I bought the set in the 80's. It is THE reference for accurate detail info. Not sure if it's in print anymore... Haven't seen a set in decades. Maybe somebody will chime in that knows."
Perhaps there is also a hint to find, althoug I think Nancy, and the thread she quoted, is a good and right answer. |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sat May 28, 2016 1:15 am Post subject: Re: Color code - handbrake and gearstick |
Car of the Century lists it as L71 Beige _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sat May 28, 2016 7:08 am Post subject: Re: Color code - handbrake and gearstick |
Just to clearify, it is the Brown color code I am looking for, not the more common Beige color.
Please see pic with original Brown color.
Posted: Sat May 28, 2016 7:44 am Post subject: Re: Color code - handbrake and gearstick |
Yes, I believe that to be originally the L71 beige. Of course heat, the elements and time have changed it from the richer browner color similar to what I found under the rubber of my steering column. RAL 8025 was the closest to what I saw. |
Posted: Sat May 28, 2016 8:18 am Post subject: Re: Color code - handbrake and gearstick |
nlorntson wrote: |
Any chance that you could post or email me a picture of a part painted in RAL 8025? |
Posted: Sat May 28, 2016 10:02 am Post subject: Re: Color code - handbrake and gearstick |
The wheels are 8025 but in this picture the lighting makes them look much lighter.
Car is middle brown. |
Posted: Sat May 28, 2016 10:57 am Post subject: Re: Color code - handbrake and gearstick |
The problem for us european people is that "beige" is a colour, known to look similar as "ivory", so no traces from brown or other colours in it. Very often, Europeans call a pearl white beetle "beige" beetle, when they are not in the VW scene and have a detailed idea. Beige is not far away from ivory, cream or dark white. So it is surprising for a German car builder calling a colour "beige" when it is light brown in reality.
But you can be sure, what Nancy shows and says is right. She has done some studies for her own restoration and what you see on her wheels is the same colour you find on interior parts from many spilts of that time. |
