bratjie Samba Member
Joined: December 22, 2007 Posts: 35 Location: Gauteng, South Africa
Posted: Wed May 25, 2016 11:22 pm Post subject: DIY homebuilt water/meth kit, how to? |
Hi guy's, I want to build a water meth kit for my turbo setup on a 2.1 wbx. I want it to be boost activated at around 5 to 6 psi. I'm using T3T4 blowing through twin 40 Dellortos with charge cooler. Any ideas as to what to use and how to test/build would be greatly appreciated, |
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Thu May 26, 2016 4:07 am Post subject: Re: DIY homebuilt water/meth kit, how to? |
bratjie wrote: |
You'll find tons of info on turbo diesel truck forums...My daily driver was a dodge 3500 for years, those guys are serious gear heads. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Thu May 26, 2016 5:48 am Post subject: Re: DIY homebuilt water/meth kit, how to? |
I built my own W/I system.
I used a Sureflo pump and cranked it up to 120 lbs pressure.
I used a gas tank from a lawn mower for the water/alcohol mix.
The 1/4 inch hose and push-loc fittings are available locally.
I use two Hobbs pressure switches and two nozzles... One set at 6 lbs and the second one at 10 lbs. ( I run a lot of boost)
I bought the nozzles from Devils Own just because they work well and it's easier to buy nozzles that are a specific size than to make your own.
If I could do it again I would buy a Devils Own pump since they put out 250 plus lbs and are internally regulated for a more consistent pressure.
It would only cost $50.00 more since they will sell the pump separately for $120.00. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu May 26, 2016 1:50 pm Post subject: Re: DIY homebuilt water/meth kit, how to? |
^ ditto. A lot of people I know use oil pressure switches to activate the sprayer solenoid, and the pump itself shuts off at some predetermined pressure so it stays primed. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Thu May 26, 2016 5:45 pm Post subject: Re: DIY homebuilt water/meth kit, how to? |
My first Hobbs switch at 6lbs. activates the solenoid for the nozzle and also activates a relay starting the pump. It's just a extra safety so the pump won't bleed water when not in use. The solenoids keep the vacuum from sucking the tank dry.
Hobbs switches are available online that are adjustable for pressure and your choice of N/O or N/C for around $25.00 each they are well worth the money.
Get the ones adjustable from 2-14 lbs.
Oil pressure switches aren't adjustable and you want to be able to set when they come on. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
modok Samba Member
Posted: Thu May 26, 2016 7:42 pm Post subject: Re: DIY homebuilt water/meth kit, how to? |
You can't use one nozzle because the the top half of the system is not made for wet flow, and also because it is made so the water will drain into the carbs, which will screw everything up, so, don't do it.
It is not practical to have four water nozzles.
I think two may be practical, and could be made to work if you build tube "Y" carb hats like this, and locate the float vent way upstream
