JeffRens Samba Member
Joined: August 25, 2012 Posts: 267 Location: Mishawaka, IN
Posted: Wed May 25, 2016 1:11 pm Post subject: Ignition switch cylinder disassembly |
I posted this in the Oval forum and got no respose, so trying here
I've disassembled my Oval ignition switch. I want to rekey the cylinder. Does anyone know how the cylinder comes apart to get to the tumblers?? Thanks
mukluk Samba Member
Posted: Fri May 27, 2016 2:58 pm Post subject: Re: Ignition switch cylinder disassembly |
The lock cylinder usually has a small screw, roll pin, or circlip holding it together. Later cylinders used a spring clip that can only be released after drilling a small hole in the correct location on the cylinder, allowing a straight pin to be inserted to depress the clip.
If you post up a few clear close-up pics from various ends and angles, we may be able to help figure out how it's assembled. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri May 27, 2016 7:35 pm Post subject: Re: Ignition switch cylinder disassembly |
Thanks for the reply. Here's a couple of close-ups. I know I could buy one from the classified, but this is the love of a project, right? I bought this from a swap meet. Can I assume it's an SG key?
mukluk Samba Member
Posted: Fri May 27, 2016 9:12 pm Post subject: Re: Ignition switch cylinder disassembly |
In the second pic it appears there may be a solid pin that's installed through the end of the center section of the lock -- looks like you may be able to drive that out, releasing the plate which limits the rotation travel of the center, which will then allow you to pull the center out the front of the assembly. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat May 28, 2016 4:24 am Post subject: Re: Ignition switch cylinder disassembly |
Thanks. Its obvious now. You are indeed correct. There is a pin that is driven thru the center round section that holds the plate in. The pin was ground down flush and polished so good it wasn't visible initially. Wish me luck. Now I just need to find a key. Anybody have an old cut key they want to sell so I can code this cylinder to it? From what I've read I need any SG key?.... Jeff |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sat May 28, 2016 9:09 am Post subject: Re: Ignition switch cylinder disassembly |
If you are so inclined, do us all a huge favor and take the time to put together a step by step of the process of disassembly, reworking, and reassembly. It would be a huge help. And it might even make the Stickies.
I got some keys with a parts lot a while back, I'll see if any are SG. _________________ Plate of shrimp |
Posted: Sat May 28, 2016 9:16 am Post subject: Re: Ignition switch cylinder disassembly |
Will do. Knocked the pin out and got the cylinder out to get to the "tumblers". If I can get a hold of a cut key, it looks very do-able. I'll post some pics... |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue Mar 06, 2018 8:16 am Post subject: Re: Ignition switch cylinder disassembly |
Any chance you took some more pics? I'm interested to do the same.
Thanks! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Wed Mar 07, 2018 5:53 pm Post subject: Re: Ignition switch cylinder disassembly |
Sorry... been a while since I've messed with this. I was able to re-key my door locks, ignition and engine compartment locks to the same SG key. I, unfortunately, did not take pictures through the process like I intended. The trick was to have enough tumblers from other lock cylinders to find the right combination for the same key. I was only able to get real close on one of them, and delicately used a grinder to get the tumblers smooth to the cylinder barrel. they all work great... It is not all that difficult with a little trial and error... Jeff |
