HellBentPuppet Samba Member
Joined: September 09, 2010 Posts: 8 Location: Rocky Mountains
Posted: Mon May 23, 2016 9:15 pm Post subject: 65 Bogs duriing start after running |
Didn't know whether to post here or in another area but since I lurk here the most I thought I'd try here first
I have a 65 with a 1776/dual scat 35's w/electric chokes, 2.5 fuel psi per manual, electric fuel pump ( I know sacrilege). The setup is a couple years old but but only about 3000 miles due to my limited summers up in the mountains.
It runs great, but if I stop to run into the market lets say for 15 min I go to start it and have to floor it to get her to kick in then stay on the throttle feathering it for a minute or two so it won't bog out on.
I've checked for leaks on the intakes, made sure the chokes where disengaging, checked for proper jetting.
Not a huge issue but just has me scratching my head.
A big thanks to all of Samba, I've learned and done a ton of stuff to my ride from here, installing all new wiring, new brakes/master, raising and lowering, carb tuning, installing and putting together motor/exhaust (Longblock already built not that far along to do it myself yet ) and a ton of other random stuff. Just wanted to throw a large blanket "thank you" |
mukluk Samba Member
Posted: Fri May 27, 2016 3:10 pm Post subject: Re: 65 Bogs duriing start after running |
Fairly normal behaviour for a carb'd engine. If you read through an original owner's manual for our cars, you'll find where the factory noted you may need to slowly open the throttle and hold it whilst cranking for a warm restart. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat May 28, 2016 4:45 pm Post subject: Re: 65 Bogs duriing start after running |
mukluk wrote: |
Fairly normal behaviour for a carb'd engine. If you read through an original owner's manual for our cars, you'll find where the factory noted you may need to slowly open the throttle and hold it whilst cranking for a warm restart. |
So much for using this as a getaway car
Ok then. I usually have to keep it idling for about 2 min then throw a few revs and its good.
Thank you for your response! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9776 Location: Oregon
Posted: Sat May 28, 2016 4:57 pm Post subject: Re: 65 Bogs duriing start after running |
It takes you 15 minutes to rob a store??? JK JK JK!
My dual carbed 1679 does the same thing as you describe. I stop at the store do my shopping and 15-20 minutes later, I have to depress the throttle while cranking the engine to get enough air into the engine to over come the gas rich environment. Then I just give it a few rev's and live is good again after about 30 seconds. Just the nature of the beast.
Have a great weekend. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
