scott s Samba Member
Joined: January 04, 2005 Posts: 1122 Location: Rock Hell, SC
Posted: Sun Mar 06, 2016 5:52 am Post subject: The quest for better brakes |
I need better brakes. The stock '63 drums are woefully inadequate with the 190HP 2,276 and close ratio Berg 5 speed.
Years ago, I had a set of 356A brakes that I stupidly sold. Porsche 356 stuff has gotten crazy expensive since then.
Discs for the front are an obvious answer, but there's the snowball effect.... Wide 5 disc widen the track, which means I need a narrowed beam. If I get a narrowed beam, I'll probably want to swap out the stock shocks (which work fine and provide a smooth ride with the current cut-and-turned beam).
Then there's still the rear to deal with. I like the idea of T3 rears, but they've also gotten hard to find and I could probably get rear discs for the same money.
Then, I start thinking about the Ghia style discs that are 4-lug (an absolute No-Go on this car) but can be had in Porsche pattern. They don't widen the track (I don't think), but any money I save on not getting a beam would be spent on new Porsche pattern wheels.
A dual circuit master and new braided hoses are a given, no matter which route I take.
I've had this car for over twenty years but I've been out of the VW scene for a while. Can you talk me through the most cost effective (notice I didn't say "cheapest", necessarily) wide five brake upgrades? Disc/disc? Disc/Drum? Porsche 356? (I really like the idea of the big 356 drums, but whoa, Nelly....the cost...) _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5610 Location: 37.5N 77.1W
Posted: Sun Mar 06, 2016 7:09 am Post subject: Re: The quest for better brakes |
Quote: |
drums are woefully inadequate with the 190HP 2,276 and close ratio Berg 5 speed |
I've never been able to understand why people believe engine size determines what brakes are needed. Speed is speed, weight is weight. Do they keep their foot on the gas when braking? I don't know. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Rome Samba Member
Joined: June 02, 2004 Posts: 9681 Location: Pearl River, NY
Posted: Sun Mar 06, 2016 8:39 am Post subject: Re: The quest for better brakes |
You have a really impressive Beetle. Is the color Ruby red? From where did you buy your red sunroof cover?
There is now a front disc kit that has zero offset, but it is only for stock-height spindles so that it might not be what you want because it appears your car is slightly lowered- http://vwparts.aircooled.net/0-Offset-Wide-5-Disc-Brake-Kit-1949-65-Link-Pin-T1-p/401498.htm
Same vendor also sells "super stopper" rear brake shoes which have more aggressive material compared to stock replacement.
VW Things had wider rear drums than even a '67 Beetle and still kept the wide 5 bolt pattern. I don't know if such a drum would properly fit onto your '63 rear axle shaft ends so that you could still fit the stock large 36mm nut. If so, you'd then need to find the Thing rear brake shoes and hope the shoes' tangs fit into the '63 shoe retaining bolt slots.
How about aftermarket wide-5 front discs and Porsche 356 A or B rear drums? |
EVfun Samba Member
Posted: Sun Mar 06, 2016 9:51 am Post subject: Re: The quest for better brakes |
First, you should take stock of the tires you are running. If the fronts are quite a bit narrower than the back then increasing front braking is not going to help much. You will just lock them prematurely.
You could swap to Thing brakes in the back. The drums would have to have the snout shortened if you are running short spline axles. Thing brakes are 1968-1979 Beetle rear brakes with different drums. They share Beetle wheel cylinders, brake hardware, and shoes (40mm wide shoes instead of 30mm wide used on earlier Beetles.) The drums will increase the track width. You would need '68 up Beetle or Thing backing plates as the wider shoes don't fit on early backing plates. _________________
Wildthings wrote: |
txoval Samba Member
Joined: January 23, 2004 Posts: 3563 Location: The Woodlands, TX
Posted: Sun Mar 06, 2016 12:33 pm Post subject: Re: The quest for better brakes |
If you don't have lowered spindles, go the Aircooled zero offset front disc kit.
Swap rear pads as suggested above...you'll be amazed at the difference with front discs... |
Slimwonder Samba Member
Joined: May 29, 2013 Posts: 94 Location: Anywhere but Oregon and California.
Posted: Sun Mar 06, 2016 2:13 pm Post subject: Re: The quest for better brakes |
runamoc wrote: |
I've never been able to understand why people believe engine size determines what brakes are needed. Speed is speed, weight is weight. Do they keep their foot on the gas when braking? I don't know. |
Because when the 40HP motor would get you to 80-ish on a long highway run, the stock brakes (which are all rebuilt and adjusted) will definitely groan and moan and shudder and fade when hauling this thing down from speed now. Speeds much, much greater than 80...
Do you really have anything constructive to offer? _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Posted: Sun Mar 06, 2016 2:15 pm Post subject: Re: The quest for better brakes |
Rome wrote: |
Yes, the color is Ruby Red...and thank you for the compliments!
I actually DO have stock height spindles. The beam was cut and turned for some mild lowering. In fact, one bonus side effect of a new, narrowed, adjustable beam would be getting the front end down just a bit lower.
But I can live with the height it is now if I can get wide 5 discs and now widen the track.
I'll look into the link you posted. Thanks. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Posted: Sun Mar 06, 2016 2:17 pm Post subject: Re: The quest for better brakes |
Dang it! The zero offset brakes are out of stock with no ETA for restocking. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sun Mar 06, 2016 3:33 pm Post subject: Re: The quest for better brakes |
I`ve read that the non dropped spindle brakes can be modified to work on stock spindles. And you may not need different shocks if you change the beam. That depends on how much lower you would make your car over where it sits now. But I really think that given the money you have spent on your car already, a 2" narrowed beam and a wide five 4 wheel disc brake conversion shouldn`t be a problem. And would be the best way to go. _________________ If you`re going to do something, do it right. |
Posted: Sun Mar 06, 2016 4:15 pm Post subject: Re: The quest for better brakes |
Do you really have anything constructive to offer? |
Yes, don't break the law. Have speed rated tires. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
txoval Samba Member
Posted: Mon Mar 07, 2016 3:27 pm Post subject: Re: The quest for better brakes |
https://www2.cip1.com/ProductDetails.asp?ProductCode=C31%2D499%2D165%2D5130ZO
You have a nice looking car why would you even consider Chinese made brakes? Go German. Yea more money but far superior. What's a bit more $$ when you clearly have a high $$ car
Zero offset too
You can get a kit for the rear too if you want to rip your face off under braking... Although that might be overkill on such a light vehicle running skinny rubber |
Posted: Mon Mar 07, 2016 4:43 pm Post subject: Re: The quest for better brakes |
Are discs up front all for naught if I have the skinny tires?
I built this car years ago and was into the Cal-Look, hence the 145's up front.
I used to have a '70 and I ran the Smart Car tires; 175/55. With Ghia style discs and the 2.0L alloys, it all fit with a stock width BJ beam.
Think I could get away with a similar size tire on the BRM's? These are Flat Four BRM's from probably 20+ years ago. Right now, the beam on the '63 is a stock width kingpin beam. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Mon Mar 07, 2016 4:47 pm Post subject: Re: The quest for better brakes |
discs up front really make a difference! |
Posted: Mon Mar 07, 2016 5:33 pm Post subject: Re: The quest for better brakes |
I know plenty of people running 145 with discs including my self. (Porsche 944 Brembos). Let's face it you know you have skinnys so it's not going to handle any better with discs just a better peddle feel and positive braking unlike drums which are altogether crap and full of fade. New master cylinder is a must.
The dry yields and nice positive braking experience but the wet is somewhat lethal with skinnys. And I haven't got a power plant like you have. A smart head and driving style is needed in the rain for sure
The whole 145 or 175 smart tyre is a massive debate. The look of the smarts arnt very cal look. But are a better tyre. It's all down to what you decide. |
Posted: Mon Mar 07, 2016 5:44 pm Post subject: Re: The quest for better brakes |
Thanks, Slim.... useful information. The skinny '63 drums are downright scary at times. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Posted: Mon Mar 07, 2016 5:48 pm Post subject: Re: The quest for better brakes |
No problems. So many people just settle for poor quality EMPI or similar systems because they try and cut corners. Braking isn't one area that I'd skimp on. I've worked in the industry and you wouldn't believe how many faulty parts/bad or even non fitting parts go out in those kits is untrue.
If you were swapping out the BRMs for Porsche there are few good guys on here who make pretty awesome kits using Wilwood Calipers and discs.
Good luck with whatever you decide. |
slalombuggy Samba Member
Posted: Mon Mar 07, 2016 6:01 pm Post subject: Re: The quest for better brakes |
I have Empi disk kits on both my landspeed race cars. They haul my cars down from 120mph very well in a very easy, predictable manner. Nothing wrong with them. I would never run stock drums on cars able to exceed 100mph.
brad |
bluebus86 Banned
Posted: Mon Mar 07, 2016 6:50 pm Post subject: Re: The quest for better brakes |
I am wondering for a Stock Drum Bug, who has the best brake shoe friction material?
Surely some types are better than others, with trade offs in cold braking, cost, wear of material, wear of drum, noise, etc...
Is there a race high performance brake shoe available? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
