Kuebel-man Samba Member
Joined: May 13, 2016 Posts: 19 Location: Frankfurt, germany
Posted: Sat May 14, 2016 1:09 pm Post subject: The Thing - oil pressure sensor |
My oil pressure light below the speedometer isn't working for a couple of days for no obvious reason, although i've been working on a bunch of things including the distributor and other stuff during the same period. I've tried to find the oil pressure sensor which according to pictures i've seen should be below the distributor or at least somewhere around there but my engine doesn't match any of the pictures. I've got no such thing around that area. At the same time, l've discovered an unconnected blue- white wire which is coming to the engine compartment but there is no place to connect this to. Not sure whether this wire was ever connected since i've bought the car or when the oil pressure light was working. I grounded this wire and the oil pressure light came on but always stayed on. So not really working.
Does anyone else have an oil pressure sensor which seems to be located somewhere else? |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Sat May 14, 2016 1:54 pm Post subject: Re: The Thing - oil pressure sensor |
Pictures needed!! |
Banker Samba Member
Posted: Sat May 14, 2016 6:42 pm Post subject: Re: The Thing - oil pressure sensor |
Here is a picture from the gallery. Your sender may look different.
_________________ Brian
07 Charger Sublime
03 Goldwing
74 Thing |
Posted: Sun May 15, 2016 1:13 am Post subject: Re: The Thing - oil pressure sensor |
I agree that things should look like the picture you sent but on mine, there's nothing there. Have a look at the pics
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun May 15, 2016 4:20 am Post subject: Re: The Thing - oil pressure sensor |
Do you have a Type 3 engine case?
The distributor clamp looks a little Type 3-ish.
Is your oil dipstick tube pressed into the case, or is it an adapter bolted to the back of the case?
If your engine was originally installed in a Type 3, look to the oil cooler; that's where the oil pressure sender was mounted.
Photo from the gallery:
Good luck, Mondshine |
Posted: Sun May 15, 2016 8:12 am Post subject: Re: The Thing - oil pressure sensor |
I always assumed that it was a type 1 case. The dipstick is in the back of the case which then has a tube underneath that leads to the case. Is that type 3? |
Posted: Sun May 15, 2016 8:58 am Post subject: Re: The Thing - oil pressure sensor |
In fact, just put in 2.5 liters of oil and dipstick is dry on flat ground! |
Posted: Sun May 15, 2016 10:21 am Post subject: Re: The Thing - oil pressure sensor |
Here's a photo of an aftermarket Type 3 dipstick adapter:
If your engine has one of these, look for the oil pressure sender on the oil cooler.
Posted: Sun May 15, 2016 12:00 pm Post subject: Re: The Thing - oil pressure sensor |
Here's how the dipstick looks like from above and under the engine.
I guess i now have 2 problems:
1. The oil light somehow doesn't work and if you guys are right, then i'll have to look for the sender around the oil cooler
2. Having just changed the oil and put in 2.5 liters exactly, i have a dipstick that is fully dry. Should i add more oil or just assume that there's something wrong with the dipstick and go blind. Note that the dipstick was not dry fore my oil change but i' m not sure how much pil the previous owner had put in.
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun May 15, 2016 1:09 pm Post subject: Re: The Thing - oil pressure sensor |
that is a type III case and that has got to be the weirdest dip stick I have ever seen you need to get the adapter that mondshine showed you and drill the case where you see the raised area under the dist for a 1/8 pipe thread |
Posted: Sun May 15, 2016 1:22 pm Post subject: Re: The Thing - oil pressure sensor |
Any better pictures to see exactly where i need to drill? I'm new to this and don't want to just put a hole in on the wrong place!
Does the position and therefore the reading of this weird dipstick seem right to you? In case i chicken out of drilling this new hole, i want to see if i can trust this weird dipstick. As said, before my oil change, the dipstick was showing oil level near the top bar! |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Sun May 15, 2016 1:37 pm Post subject: Re: The Thing - oil pressure sensor |
I have seen that dip stick before on type III's and it had a rubber sleeve that connected to a tube on the back of the of the trunk deck. The dip stick was rather long and kinda like on the auto transmission. You need to put in the exact amount of oil that the manual says and then mark the dip stick and go from there or get the on that is shown above. Go here and you can see the top part of the type III dip stick also there is the dip stick you need to put the correct one on about a 3rd of the way down.
GB |
Posted: Sun May 15, 2016 2:56 pm Post subject: Re: The Thing - oil pressure sensor |
Thanks. The dipstick i got is not that long. It's as long as the first tube that you can see on my picture. Maybe aroung 5 inches or so. Anyhow the manual says 2.5 liters and i've down 2.5 liters. I can't really mark the dipstick because the oil level doesn't even reach the dipstick now! Maybe i gotta buy a longer one but am not sure that will help because as you can see from the picture, the second tube is somewhat perpendicular to the first one down which the dipstick goes now! |
Posted: Sun May 15, 2016 3:09 pm Post subject: Re: The Thing - oil pressure sensor |
Kubel-man...
None of this is that terrible, and it should be relatively easy to make it serviceable.
If you buy one of those "conversion" dipstick adapters, you should be able to install it with only minor modification to the engine tin.
What you don't want are big holes in the tin that allow hot air to be drawn into the engine compartment (like you have now).
The oil pressure sender, which I suspect is threaded into your oil cooler, only has one wire connected to it. In stock form, the wire is red/green. This wire is connected to ground through the oil pressure sender when oil pressure is below ~5 PSI.
Look for a wire coming from the front of the fan housing where the oil cooler is installed. If you are reluctant to drill and tap as citroen suggested, you can connect the sender as it is until the next time the engine is apart.
Posted: Mon May 16, 2016 12:20 am Post subject: Re: The Thing - oil pressure sensor |
Got it. Thanks a lot. Sounds like a plan. |
