yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Tue Jul 26, 2016 7:40 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Did you happen to leave off the clutch throwout bearing and the fingers of the clutch arm are rubbing on the spinning clutch? I lost a bearing in a 1968 once and the clutch arm hit the spinning clutch and totaled the whole deal.
Wait ,I just listened to that again. Do you have straight cut cam gears in that? _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
AggieZig Samba Member
Joined: March 10, 2013 Posts: 188 Location: Los Angeles, CA
Posted: Tue Jul 26, 2016 7:43 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
yamaducci wrote: |
Wait ,I just listened to that again. Do you have straight cut cam gears in that? |
There is a T/O bearing installed and no straight cut gears, just regular ol' aluminum helical. _________________ Zig, Aircooled Enthusiast
Current: Porsche 914 Resto | 1969 VW Beetle
Past: 74 Thing | Sand Rail | Baja Project | Oval Beetle |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Jul 26, 2016 7:45 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
The slinger will lock up the crank if in backwards- that pulley usually takes one or two thick spacers- check between the pulley and the tin work for shavings - or remove the pulley and replace it with a stock one- inspect for rubbing. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Tue Jul 26, 2016 7:48 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Reverting back to old photos so I don't second guess myself
The slinger appears to be installed the correct way? Concave facing out? _________________ Zig, Aircooled Enthusiast
Posted: Tue Jul 26, 2016 8:00 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
That is correct. All looks pretty normal in there.
Take off the front pulley and run it. _________________ -John Cox
Posted: Tue Jul 26, 2016 8:26 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Yup- slinger looks good- pulley next- _________________ some days I get up and just sit and think. Some days I just sit.
jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Tue Mar 07, 2017 8:52 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
I have the CB spin on filter pump,and the cover pushed the tin behind the pulley out just enough to lightly rub it.Squealed loud.Scared the shit out of me first time I fired it. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed Oct 04, 2017 10:46 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Did this mystery get solved? _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
