AggieZig Samba Member
Joined: March 10, 2013 Posts: 188 Location: Los Angeles, CA
Posted: Sat Jul 23, 2016 11:50 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Ok, found a longer spring and original looking plunger:
Man, this was a bitch to get installed. As I was screwing the temp sender in, I heard a click from inside the case. I'm assuming that was the plug seating all the way up. I'm thinking the other plug may not have even gone into its seat before?
Anyways, cranked for pressure, nothing. Thought to myself this is hopeless... decided to crank it anyways. After a few seconds... 20 PSI! Woohoo!
TheSamba 1; Me as a builder 0
Will run the break in tomorrow morning for the cam. _________________ Zig, Aircooled Enthusiast
Current: Porsche 914 Resto | 1969 VW Beetle
Past: 74 Thing | Sand Rail | Baja Project | Oval Beetle |
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Jul 24, 2016 12:56 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Good stuff,
Glad you figured it out, Nice engine btw. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Jul 24, 2016 8:10 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
mark tucker Samba Member
Posted: Sun Jul 24, 2016 8:49 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
the plug does not seat into any seat or clicker. and I would make sure you have the right spring too.I dont use the stiff spring in the cooler relief location.I do use the booster spring in the oil pressure location(neer the flywheel) i also always polish the pistons with 1000 wet (spun in a drill,lathe etc) to be sure there are no scratches or edges that can eat at the bore & cause sticken. |
Posted: Sun Jul 24, 2016 9:23 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
So, I spoke too soon.
Started up this AM to being break-in. Anything over idle speed and there is a high pitched whine noise. I disconnected the fan belt to see if it was coming from the alternator but no dice - it's coming from somewhere else (aka the engine).
I rolled it over by hand, no binding anywhere perceived. At least I'm catching this now before something seizes.
Looks like I will be tearing down after all. I guess this is a great way to learn the hard lessons on your first rebuild... _________________ Zig, Aircooled Enthusiast
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sun Jul 24, 2016 9:35 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
I only skimmed through, so forgive me if I missed something. Before you tear your engine down, make sure your whine isn't coming from the crank pulley rubbing on the pulley tin. I have had this happen before. I missed it when I installed the pulley. It only whined when the engine was warm. |
Posted: Sun Jul 24, 2016 5:13 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
motofly196 wrote: |
Good call and one of the first things I checked because I've had that same issue before.
I'll post a quick video tonight of what it sounds like...
Trying to think of other possibilities - rebuilt tranny internals? throw out bearing? _________________ Zig, Aircooled Enthusiast
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sun Jul 24, 2016 5:23 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
You didn't use straight cut gears did you? That'll do it sometimes..
post a video, people here are very good a diagnostics.
SD _________________ modok wrote:
Posted: Sun Jul 24, 2016 8:24 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Nope, just regular old helical gears.
Here are a couple clips of what it sounds like. No idea why it wasn't like this last night when I fired it up. One clip is with fan belt and one without. I'd let it run longer but I'm afraid of a grenade. It cranks over fine with no binding. (And yes, I forgot the coil wire and that's why I'm cranking for so long lol)
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1172 Location: San Angelo, Texas
Posted: Sun Jul 24, 2016 8:58 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
so, out of the frying pan and into the fire.
I don't recall hearing that particular noise. I can see the oil lines sort of tense up with pressure when you light it off. How much pressure do you have? It looks like it spins over freely.
Can you grip the crank pulley and feel end play fore and aft? You can pull the engine off the trans and remove the pressure plate and disc off to take the trans out of the mix. look inside the bell housing for interference. A 12 volt flywheel will rub on a 6 volt case.
I never have had a engine lock up, but I would think it would just seize....no sound. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Mon Jul 25, 2016 12:54 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Unfortunately I am back in DFW for the week so I cannot head out to the garage and play.
Re: Endplay - I'll have to give it a tug but I know that I was fairly meticulous when setting this on the bench.
Re: Oil Pressure - I wasn't watching as I was taken aback by the noise. On the previous start attempt it was around 20-25 PSI or so.
I may consider pulling the clutch / PP and reinstalling to eliminate any tranny issues. I suppose I could double check end play while I had it up on the bench.
Man, this sucks. _________________ Zig, Aircooled Enthusiast
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Mon Jul 25, 2016 1:24 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Sounds like maybe the fan inside the shroud. If that was the flywheel and bell housing getting ground down there would be mag particles falling out of the air hole on the bottom of the bell housing. Check there before removing the engine. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Mon Jul 25, 2016 2:24 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
yamaducci wrote: |
Sounds like maybe the fan inside the shroud. If that was the flywheel and bell housing getting ground down there would be mag particles falling out of the air hole on the bottom of the bell housing. Check there before removing the engine. |
I thought the same so that is why in the second video I pulled the fan belt to confirm the noise was not coming from there.
I'll have to check for mag shavings but I don't recall any clearance issues with the flywheel _________________ Zig, Aircooled Enthusiast
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Jul 25, 2016 5:56 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
you wouldn't happen to be using a super-sweet aftermarket magnetic drain plug, would you? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
74 Thing Samba Member
Posted: Mon Jul 25, 2016 7:37 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
What is on the flywheel end? Is it an old tranny or bell housing and if so maybe the flywheel is rubbing on that. |
Posted: Mon Jul 25, 2016 8:19 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
borninabus wrote: |
you wouldn't happen to be using a super-sweet aftermarket magnetic drain plug, would you? |
Yes... I'm afraid to ask why?
74 Thing wrote: |
Freshly rebuilt tranny on the other end - don't think it's rubbing but I will certainly check. _________________ Zig, Aircooled Enthusiast
SBD Samba Member
Posted: Mon Jul 25, 2016 8:26 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
AggieZig wrote: |
borninabus wrote: |
Sometimes they can be long enough to push the bottom of the screen assembly up against the bottom of the pickup tube and obstruct the oil intake. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Jul 25, 2016 8:44 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
Only cheap way out I can imiagie is the after market front pully is rubbing or the slinger is in wrong _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon Jul 25, 2016 9:34 pm Post subject: Re: No oil pressure... what gives? (New Rebuild) |
williamM wrote: |
Only cheap way out I can imiagie is the after market front pully is rubbing or the slinger is in wrong |
cheaper than a drain plug?
it's actually a combination of the super sweet aftermarket strainers and the super sweet aftermarket magnetic drain plugs that can cause blockage of the pick-up tube.
ask me how i know
if the pulley is rubbing and/or the slinger is wrong you can tell by checking endplay. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Tue Jul 26, 2016 7:23 am Post subject: Re: No oil pressure... what gives? (New Rebuild) |
borninabus wrote: |
williamM wrote: |
ask me how i know
if the pulley is rubbing and/or the slinger is wrong you can tell by checking endplay. |
Well, I know that I was getting oil pressure so I'm not thinking there is a blockage on the suction side.
The pulley / slinger could be another story. How would I be able to tell via endplay if there is a rub? _________________ Zig, Aircooled Enthusiast
