advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Wed May 11, 2016 6:43 am Post subject: 2276 beetle engine oil cooling |
Hi all can anyone tell me at what point or engine size the stock beetle oil cooler can no long cope and an external cool is needed. Cheers |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Wed May 11, 2016 6:59 am Post subject: Re: 2276 beetle engine oil cooling |
engine size has nothing to do with it....
friction / CR / sufficient fins on heads / cyls / proper air flow and volume....all factors creating and releasing heat
the stock oil cooler will do the job as long as all the rest is in check |
Posted: Wed May 25, 2016 7:25 am Post subject: Re: 2276 beetle engine oil cooling |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed May 25, 2016 3:04 pm Post subject: Re: 2276 beetle engine oil cooling |
I run only the stock doghouse oil cooler on my Ghia with a 2276. It can be driven on the street and runs 13.50's at the track. All the sheet metal and details must be addressed to provide cooling. An important item is running the heat shield tubing on your oil lines that pass thru the exhaust. This lowered my oil temps 15 degrees.
_________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed May 25, 2016 3:38 pm Post subject: Re: 2276 beetle engine oil cooling |
most VW guys add an external cooler before they even need it. They are often so concerned with "running cool" they go full retard on the oil cooler, without even taking care of the basics like oil pump sizing, oil viscosity, and optimizing the stock system.
Most street engines will work fine with the stock doghouse system. When full flowed you have to use your head, like not running lines next to exhaust pipes, etc. Each mistake will cost you 15-20F easy. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Posted: Wed May 25, 2016 4:53 pm Post subject: Re: 2276 beetle engine oil cooling |
The oil gets too hot, when.............the oil gets too hot.
If the oil is too hot, then you need a cooler.
What point is that? depends on app and opinion. 200, 220, or possibly 240 degrees F
I have one that runs 220-240 on the highway and I just go ahead and let that happen, it has a as21 case, single carb, nothing fragile about it, and I'm not worried in the least.
Many types of oil can handle the heat but the block can't, so, we are dealing with case temperature really, and internal and piston temp. The heat generated from X HP produced is not linear at all. Build it and see. Some combos run cooler than others, and it's not possible to predict. |
