Parkker Samba Member
Joined: March 02, 2009 Posts: 35 Location: South Dakota
jberger Samba Member
Posted: Wed May 25, 2016 9:46 pm Post subject: Re: Ring and pinion video inspection |
Whoa... That's the noise your box is making? Tear it down now.. Before it's too late. That is a main shaft howl as it is the same in each gear being engine rpm dependent. |
Posted: Thu May 26, 2016 6:11 am Post subject: Re: Ring and pinion video inspection |
Thought so. Thanks for reply. Not driving it anymore, that was the last time so I could record sound. So much for summer vacation plans... Now I just need to raise a huge wad of cash... Vanagon blues |
Posted: Thu May 26, 2016 6:55 am Post subject: Re: Ring and pinion video inspection |
Just swap in a cheap used 2wd box while you sort out the high dollar issues. Can still enjoy the summer. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16510 Location: Brookeville, MD
Posted: Thu May 26, 2016 2:32 pm Post subject: Re: Ring and pinion video inspection |
jberger wrote: |
That's some great advice, I may do that, just need to find a box and the different shift linkages. Any tips appreciated! |
Posted: Thu May 26, 2016 4:08 pm Post subject: Re: Ring and pinion video inspection |
I found this transmission on ebay.
The ratios would work well with my engine conversion I believe. But I don't know if it will bolt up the same as the syncro trans . Anyone know more??
http://www.ebay.com/itm/New-VW-Vanagon-Factory-Reb...mp;vxp=mtr |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9628 Location: Western WA
Posted: Thu May 26, 2016 4:14 pm Post subject: Re: Ring and pinion video inspection |
I will be VERY surprised if that will bolt up. And the starter on top will prob interfere with the Syncro gas tank.
5.50:1 R&P, that's geared for some monster mudders! _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu May 26, 2016 4:43 pm Post subject: Re: Ring and pinion video inspection |
Okay duh, you're right I'm sure that starter on top won't work. Since the Zetec conversion likes to rev high the ratios would be good I think. Checked it out with DD gearing and tire calc spreadsheet.
I seem to recall on these forums some people stranded in south america who put a 2WD trans in their syncro so I hope it is possible anyway. |
Posted: Thu May 26, 2016 10:36 pm Post subject: Re: Ring and pinion video inspection |
SYncro R&P is 5.43 |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri May 27, 2016 6:46 am Post subject: Re: Ring and pinion video inspection |
U.S. R&P ratio is 4.86.
ROW ratio is 5.43. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Fri May 27, 2016 10:10 am Post subject: Re: Ring and pinion video inspection |
Parkker wrote: |
jberger wrote: |
You do not need any different linkage. The only thing you need to work out is how the front of the transaxle will be mounted. I believe there are vendors on this forum that offer a bolt on mount. I fabricated one to use the stock syncro front mounts. |
insyncro Banned
Posted: Fri May 27, 2016 12:36 pm Post subject: Re: Ring and pinion video inspection |
Inspection is a good thing.
What you find may not be.
Happy Holiday Weekend Y'all. |
Posted: Sun May 29, 2016 12:40 am Post subject: Re: Ring and pinion video inspection |
gears wrote: |
ROW ratio is 5.43. |
Thanks for correction. I took my info from the maint manual. |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Sun May 29, 2016 2:41 am Post subject: Re: Ring and pinion video inspection |
insyncro wrote: |
This looks like a typical noob foult.
The main bearing screw never sit outside like this one.
I am sure the main bearing sits not right in the gearbox main housing.
Thats why the pinion is too much inside and destroyed itself.
It is easy to avoid this foult.
Messure the pinion first with only the mainbearing and 1st (2nd) gear nut into the housing. So you can be sure the mainbearing sits right in the housing.
Make a mark on the mainbearing nut-housing.
After puting the gearbox completly together control the mark. If the mark does not fit, the mainbearing is not right inside. |
Posted: Thu Jul 07, 2016 6:24 am Post subject: Re: Ring and pinion video inspection |
Since the sound it makes is engine rpm related, the consensus seems to be main shaft or main shaft bearing. Would that cause the "unicorn blood" effect?
Could the bearing be wearing into the bore in the case, causing the magnesium powder in oil? If so, how is this repaired? Do they machine and sleeve bore or replace case section?
Thanks for replies! |
Syncro Jael Samba Member
Posted: Thu Jul 07, 2016 7:04 am Post subject: Re: Ring and pinion video inspection |
Parkker,
Here is an earlier post of my "unicorn blood". The beginning of my Syncro transaxle learning experiences.
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...corn+blood
Again I am sorry to hear of another transaxle issue. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
gears Samba Member
Posted: Thu Jul 07, 2016 7:48 am Post subject: Re: Ring and pinion video inspection |
Bearing bores don't really shed particles. Particles would be generated when the 4th fixed gear contacts the intermediate housing (after the pinion bearing has failed).
Yes, the pinion bearing bore can be resleeved:
'87 Syncro GL 2.5
Posted: Thu Jul 07, 2016 7:58 am Post subject: Re: Ring and pinion video inspection |
gears wrote: |
So magnesium particles accompanied by engine rpm specific whine indicates pinion bearing fail? Just a bit confused as people here have said the sound this transaxle makes is engine rpm dependent and that would be mainshaft or mainshaft bearing specific.
Also, if a resleeve is called for as shown in yur photo, can any shop that rebuilds these perform this repair or is it more specialized, requiring some sort of special machining equipment?
Thanks for your replies! Much appreciated. |
goskiracer Samba Member
Joined: January 15, 2009 Posts: 339 Location: Oslo, Norway
Posted: Fri Mar 29, 2019 12:21 pm Post subject: Re: Ring and pinion video inspection |
I am sending this transaxle down to Germany to get an overhaul by Tim at T+H. He will be installing oiling plates, main bearing retainer and aluminum gear carrier plus your standard slew of 3-4 slider hub and all bearings...looking forward to having this box fresh for summer.
I’d like to get some input from the expert who have seen far more R+P sets than I... what are your thoughts on this set? I’ll have Tim give me his insights. The pinion has a slight wavyness or is that pitting?
Gears, Waldi?
_________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
