stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
Posted: Mon May 02, 2016 7:36 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
HF cleaner getting it done!
_________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
Last edited by stonecoldcars on Mon May 02, 2016 9:19 pm; edited 1 time in total |
Posted: Mon May 02, 2016 8:59 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Wanted to clean out the nozzles after the ultrasonic bath. So I rigged up a adapter and applied 20psi air pressure, than activated with the 9v battery. Worked great and also showed zero leak down. I'm very pleased. Thanks for the tip on the ultrasonic cleaner tram.
Last edited by stonecoldcars on Mon May 02, 2016 9:23 pm; edited 3 times in total |
Posted: Mon May 02, 2016 9:10 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Four clean injectors and tubes..
Last edited by stonecoldcars on Mon Jul 03, 2017 8:26 am; edited 1 time in total |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
69 Notchback Samba Member
Joined: September 12, 2011 Posts: 714 Location: Bailey Co
Posted: Tue May 03, 2016 6:17 am Post subject: Re: My new 68 Fastback "Desert Rat" |
nice work. your going to love the way that stock EFI motor runs. I have the same car, lotus white and red only in a notch and a 69. Keep at it you are making good progress. |
Posted: Tue May 03, 2016 10:01 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Thanks guys! I still need to address the conditions of the AAR, the fuel pump dampner, fuel pressure regulator, head temp sensor, and the pressure switch under the RH intake runner. Than get all new hoses.. Gas tank goes out today to get chemically dipped to remove the rust. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Fri May 06, 2016 1:13 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
More cleaned parts, fresh out of the sonic cleaner.. I really like this cleaner for the money. I don't have to scrub.. I wish I had taken before pics to show how nasty the sender was after sitting in rotten fuel for 20+ years. After cleaning I tested it with my ohm meter, and it works through the whole scale so that's good news. My gas tank is due back from it acid bath on Monday.. I went out today to my friends at pacific rubber and purchased all new fuel hose, breather, and vacuum hoses.. Getting closer..
Last edited by stonecoldcars on Mon Jul 03, 2017 8:28 am; edited 1 time in total |
Posted: Fri May 06, 2016 1:16 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
New fuel injection hose and clamps installed on injectors.
Last edited by stonecoldcars on Mon Jul 03, 2017 8:29 am; edited 1 time in total |
Posted: Tue May 10, 2016 9:35 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Received the gas tank back from the dip shop, sure turned out nice and clean(pics to come).. Getting closer. The goal is to try and make it to the Northwest bug run @ Woodburn, but not sure if I can make it.. Even if I do get it running, I still need to go through the entire brake system.. But having a goal is good _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Thu May 12, 2016 4:05 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Since I have the gas tank out, figured it was a great time to access the brake master cyl. Started taking it apart for inspection. hoping to just be able to clean it up and re-assemble....... Yeah, no such luck found one seal pretty mangled. So now I'm trying to find a new master cyl. Ordered one from local parts house. It looks a little different in the pics online, but Hoping that it will work..
Last edited by stonecoldcars on Mon Jul 03, 2017 8:31 am; edited 1 time in total |
Posted: Thu May 12, 2016 4:17 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
The new replacement one.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
Last edited by stonecoldcars on Mon Jul 03, 2017 8:37 am; edited 1 time in total |
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Sat May 14, 2016 3:01 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Nice project , nice clean well documented maintance work !
Good luck,
Jim |
Posted: Mon May 16, 2016 4:39 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Very quick update. Today's progress during my lunch hour, was installing fuses into the empty fuse block, connected the broken separated wire from the positive battery cable to the voltage regulator, installed new tail lamp lenses, and installed battery.. Than very cautiously since we don't have any background on why things are the way they are on this car I attached cables to the battery..... And surprisingly, no sparks or wires frying... All seems good. We have lights, turn signals, gauge indicators, and than I ran out of time and had to return to work.. More to come.. getting closer... thanks guys _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Fri May 20, 2016 8:24 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Slow progress, but still moving forward. Yesterday during my lunch hour I picked up new O'rings from Christopher Seals here in Eugene for my fuel pump and the MPS. Initially I was just gonna run the old OG ones, but the more I thought about it and the luck I have, they would leak and now is the perfect time to change them out. I did get myself confused on the fuel pump mid plate "clocking" position I forgot to mark the location when I took it apart(bad me). But thanks to Mike Fisher and Jim Adney they both got me back on track.. thanks guys!
Moved on to cleaning the AAR and temp sensor. Again the HF sonic cleaner came in very handing and took out the scrub work. Should have bought one of these years ago..
Last edited by stonecoldcars on Mon Jul 03, 2017 8:45 am; edited 2 times in total |
Posted: Sat May 21, 2016 9:20 am Post subject: Re: My new 68 Fastback "Desert Rat" |
So I was looking through my Bentley manual last night see whats left of my fuel system work and I got the cold start system components section.. Well I don't have any of these items..Nor do I see any of the electrical connectors for these items. Is it possible my car did not come equipped with cold start since it came from dessert climate? How well will the car operate in the Oregon weather without these?
[img][/img] _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Sat May 21, 2016 9:38 am Post subject: Re: My new 68 Fastback "Desert Rat" |
I don't see it on my '69. You're welcome to stop by & inspect mine in person if it might help you? Mine does have a later model air cleaner on it because Tram thought it was in was prettier than my '69 air cleaner.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat May 21, 2016 10:39 am Post subject: Re: My new 68 Fastback "Desert Rat" |
The cold start system was optional the first couple of years, so yes, it's entirely possible your car didn't come with it. _________________ 71 Elm Green FI A/T Squareback |
Posted: Sat May 21, 2016 12:41 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Thanks Mike and Donnie.. Good to know. I'm getting closer to seeing if this rat will run.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
