Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Fri Jul 01, 2016 5:59 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Tcash wrote: |
busdaddy wrote: |
There seems to be no carved in stone rule to shift rod bushings, different years and different months have different styles and combinations.
You can file off one of the plastic titties to use the double one or drill another hole in the rod. |
You know there is a lot of conflicting information surrounding the Rear shift rod bushings, even in the parts manuals. So I went with the late manual.
It seems it is more common to have the 211711179 2 nub with clip located on the rear of the rear shift rod.
I edited the following picture to reflect this and edited
Shifter Parts ID post as well. But included text as follows.
"Note: It has been reported that the two Rear shift rod bushings have been found reversed of the following order. So make sure the locating nubs line up!
211-711-185B has one locating nub, NO "C" spring.
211-711-179 has two locating nubs and "C" spring goes inside feathered end."
https://www.thesamba.com/vw/gallery/pix/1525874.jpg
Thank you for bringing it to my attention.
Tcash |
Wow tcash
Your bus knowledge amazes me. Is it specifically 72s, or do you know all the Bay idiosyncrasies? _________________ ~Kevin
My 1968 Campmobile |
Tcash Samba Member
Posted: Fri Jul 01, 2016 6:54 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Hikelite wrote: |
Wow tcash
Your bus knowledge amazes me. Is it specifically 72s, or do you know all the Bay idiosyncrasies? |
Thank you, I do a lot of research.
If I amaze you, busdaddy must:
https://youtu.be/Z90wz-spxjE?t=8
You know I don't know if and when a change took place. The only mention of a change is when they added the middle bushing on the rear shift rod in 77 and suggested it for subsequent models.
It may have been a production blunder. Abelard drilled the holes for the bushings one way on Monday and Zelig drilled them the other way on Friday.
From an engineering standpoint. I would think you would want the bushing with the c-clip in it on the back to help support the weight of the Shift Rod and the Shift Coupler, to save the seal and bushing in the transmission nose cone.
Tcash |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12744 Location: on a bike ride somewhere
Posted: Fri Jul 01, 2016 7:42 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Tcash wrote: |
Inspector Otto might have let that fly a few times, but that's hardly something I imagine VW neglecting to train their employees on.
www.airschooled.com |
nathansnathan Samba Member
Posted: Tue Jul 05, 2016 12:43 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
So I'd planned to get it running with these Dellortos since I don't know how to tune Solexes and I wanted to make sure it was all good with what I know to start with.
Carrera Parts, a manufacturer in Taiwan had pm'd me about using their linkage as I'd commented in a thread they announced it in. They sent me a free unit in exchange for photos of a stock bus install as they only have pics of upright cooling installs in their ad in the classifieds.
It's kind of a long story, but stock enthusiasts can be reassured that my end goal is to get it running with the stock oil bath system. The Dell linkage I plan to integrate with this setup that I was developing for my kombi which is already very not stock.
The bellcrank linkages I've messed with, the cable connects to an arm so in its motion, the throttle cable would be cutting a slot in the firewall over time. It's less of an issue when the motor is flipped around for mid engine I think, with the bellcrank being further from the front firewall. Here's the Carrera Parts linkage next to a csp linkage - the Carrera Parts is actually labelled Vintage Speed on the package.
I had it mocked up before installing the motor. These are csp 40mm matched port intake manifolds.
#3 sparkplug gets close but clears if you hold it out of the way with the wire clips.
The quick disconnect ends are pretty sweet. Like, at the carb side of the arms is right hand thread. You lock down those long hex coupler nut-looking things. They fit over the outside of the rod ends, but if you open the butterfly valve on the carb they come right off. So all the adjustment is at the inner when you're using them.
The throttle cable requires a hole be drilled in the firewall. -Just below the squarenut there.
So then I put the motor in, along with the transmission.
Some interference with my tailpipe and the over rider. I was thinking it's because of the bent over rider, but it's bent the other way, and would be worse than it is if it wasn't.
I took off the bumper for now. I diverted the throttle cable to go through a hole in the transmission bearer, and made this special cable guide out of a 1/2" bolt.
Hooked up some pcv stuff
Welded a 1/2 od aluminum tube to #3 manifold for the brake booster. Probably would have been cleaner to use #1 actually. I only had 2% thoriated electrodes and you're really supposed to use pure tungsten for aluminum I think is why it was such a challenge. to weld.
Well I still haven't started it. I've never used a mechanical fuel pump in my life so I'm not sure what the deal is, but after putting a gallon and then another gallon of fuel in the tank, I still don't see any fuel in the filter.
I'm not sure if it is some problem with the pump, or if you're supposed to prime it, or if you just turn it over until it works. I tried cranking it but I'm thinking this pump isn't working.
Anyway that's where it's at for now. I'm thinking of using an electric pump for now. |
Tcash Samba Member
Posted: Tue Jul 05, 2016 1:34 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Stupid questions.
Are the hoses hooked up right?
Do you have the correct pushrod. A lot of the rods where cut down.
IIRC there are two different lengths.
Pumps are self priming. But Pull the hose off the pump and gravity drain some gas into a can to make sure you have flow.
Good luck
Tcash |
Posted: Sun Jul 10, 2016 1:30 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Tcash wrote: |
Stupid questions.
Good luck
Tcash |
Finally getting to this, I pulled off the hose after the filter from the tank. Before I got the hose fully off, gas started coming down, so it's definitely just stopped by the pump. I never messed with the fuel pump, just hoping it would be ok. I've never had anything but unbroached bosses or already blocked off ones. I;m not even sure how you'd disable this one if that were the plan. I do have another engine a 72 I think, that I've never run with a mechanical pump. Not sure what to do...
Here is how I interpreted an image I saw on google search, I thought I had it right. The filter is on the non pressure side here. What do you think?
Posted: Tue Jul 19, 2016 9:51 am Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
I took out the fuel pump - it's not possible to remove the upper left screw to hold the warm air duct without removing the starter seemingly, but I was able to remove the other 3 and pivot it out of the way enough to get the pump off.
It's a Brazilian pump. Foolish not to have gone through this earlier, but...
Some jelly in the spacer area. I took it apart and not only was the little plate under the spring glued to the seat, but under it was like a half inch deep plug on resinous gump. I cleaned it all up, but I didn't try it. I put it back together and moving the plunger in and out, it doesn't seem to make any pressure putting my fingers over the holes. Oh and the outlet nipple came out with the hose removing it.
I have a german one from another 72 (I think) motor - that one seems the same as far as making any pressure at the holes, feeling it. I assume a good one you'd feel something?
Anyway there seem to be no rebuild kits that I can find, so I ordered a new probably Brasilian one from busdepot. I see f I can get fuel at the regulator when it arrives. |
Posted: Tue Jul 19, 2016 10:29 am Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Delving into the tail lights, they looked so so, the lenses, but the bottom of the passenger side came off separate, and the top wouldn't come off at all. Nuts once held by plastic turning freely in what has become styrofoam, I had to break the lenses to get the rest off.
The plastic molecules had turned into worms and migrated to the reverse light area on the driver side.
Other goodies, late rear side markers with no seals held in by painter's tape scrunch anchors.
The passenger side was missing the side marker wiring, the driver the connector for it had broken inside the housing. I cleaned Up the wires of overspray and rejuvenated them with a glycerin rubbing.
Both sides were missing the backing covers. Too bad, I only have 1 original and a chinese aftermarket cover, these brazilian housings don't come with covers. I notched the connector to make it fit how the factory harness should be, the smaller connectors.
Because of how the contact for the double pole center bulb comes out in a different direction, you loose about 3 inches of your loom, there is just enough slack on the passenger side to do it. Makes it even harder to run the wiring so it doesn't want to pop off the covers, but I managed.
The side markers... I have 1 decent original housing with the threaded inserts to use 4mm machine screws. I've only got 1 of those screws currently.. The other side I have a chinese housing. I think the only boot you can get for the insides is the crapy one from the repops so I've got those. This stainless 8mm flathead allen hardware I had laying around works pretty well instead of ridiculous plastic clip things. I used an exacto to remove the lip from the surround seal so they would sit how theyre supposed to - the outer seals make these sit out too much from what I can tell - I did this awhile ago so I forget, but I had an original seal to compare and determined that lip had to go.
At some point I took off the rear bumper. Kind of disgusted that they didn't paint under it and it was a bit messed up beneath, I felt I had to do something about it before putting it back on.... I thought about stripping the paint from the whole back, but trying it just on the apron revealed too much damage to the original to make it worth it. The whole back of the bus is done in like really dry rattle can white. I was buffing the sides a panel at a time with my multispeed grinder buffer, a poly wool blend and some 3m cutting compound which made the back stick out extra, all rough and hard to clean, from the sort of smooth crappy aftermarket paint up front. So I decided to improve the rattle can with my own, canvas white rustoleum matched what was already on the back. I did below the belt, minus on the hatch which I left because I'd already put the emblem on and the inner panel, from the seam behind the gas flap, 1 side to the other. Like around the tail lights and side markers, the strip above the decklid. Rustoleum sprays like shit and I had all these runs. I wet sanded though and it fixed them. It did 300 and 600 grit and buffed it and it's like the nicest paint on the bus now. Makes me look at the sliding door track cover and wonder I I should take it off to get that rust covered. You can see the dryness on the hatch from the PO, and the pearl like look of what I did, it's like not as deep the shine as the real paint on the sides.
I put my other rear bumper on as it was not on my other bus anyway and is straight. At some point I'll switch them back, but this one is painted and nice already. The gravel guard I need to touch up, it looks really cool with this muffler - also the right tow hook makes a lot of sense with it.
Posted: Mon Jul 25, 2016 10:43 am Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Well I got a new mechanical fuel pump, it's an Omega brand, looking to be chinese I would say. Anyway I installed it yesterday and it seems to work well enough so far. Pushrod is 4 1/2", same as before. Moving the plunger in the pump you can definitely fee and hear it working was what I'd wondered about the old.
So reading pressure at the regulator at 6psi, I put it down to 3psi, and got it to run by timing it statically to 8*btdc. I'm running the dual Dell drla 40s and a 005 fully mechanical distributor to make things easy, but still have run in to some issues.
I unhook the linkage after starting it and somehow the left 3-4 carb is pulling at like 10 on the unisyn where the right 1-2 is only pulling like 3, but the 3-4 side the throttle stop is backed off the whole way, and I can't get it to do any less if you get me. It doesn't make much sense to me how they could be so uneven and even less sense on how the one could do so much with fully closed butterflies.
I'll give it another go today. I was thinking maybe the brake booster is bad as that is tied to the #3 manifold right now, though #4 is pulling evenly with #3 so I'm not too hopeful that's it.
I thought maybe the idle jet is plugged on the right 1-2 carb, but if it ran as well as the left, the idle would be like 2000rpms or something minimum. So weird... |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Jul 25, 2016 11:31 am Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
nathansnathan wrote: |
You may be able to adjust your unisyn to read lower/higher flow volumes. I know I can on mine by screwing the center plate up and down.
Good work on your refresh. It looks really clean. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Mon Jul 25, 2016 12:32 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Spike0180 wrote: |
Good work on your refresh. It looks really clean. |
Thanks, dude.
I actually have a carbtune II 4 way manometer to tune the carbs, but the sync is so far off that the 3-4 side is completely maxed out and the 1-2 side shows nothing. It's bizarre how the thing reads, like if the motor isn't even on the steel bars are all the way down, but then running the motor the bars go up, but the cylinder that's pulling harder the bars won't go as high. If you think about it that you want them all even it's easy enough, but how it is right now I thought 3-4 weren't doing anything as the bars are all the way down while 1-2 side reads 3/4 of the way up. The snail unysin on the airfilter bases though, show 3-4 to be pulling so much it's off the scale, so it's a problem with maybe the carbs or pistons or valves rather than the test equipment I think.
I've got the carbs off and the tops off and it all looks mostly good. I do note the 1-2 carb the float is off from the other. It is closing even at 7mm from the top. The 3-4 side is closing at the proper 6mm, open at 7mm (carb top to the top of the float with an allen key between. I wouldn't think that would make a huge difference, but I will even them up and see if that helps.
I'm not sure what else to do, I checked the valves after running it and waiting until they cooled and they seem good. I'm not sure what else could make the 1 side run so much better than the other as compression was pretty even. |
Posted: Mon Jul 25, 2016 4:49 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
I set the floats as they were both off a little. I had another issue, a leak at the line going into the regulator, somehow the fuel hose was actually torn? I wasn't able to test it though as another issue arose, a drip from the fuel pump. I caught it on film.
I had to loosen the pivoting outlet piece to rotate it in order to clear the warm air intake duct. No matter how I tightened it, it dripped from there. Examining it, there are 3 washers stacked inside. I took 1 washer off thinking it was keeping it from seating on the o-ring. The metallurgy is like butter, 1 crank and it tore the middle off the piece, and the pump is basically ruined.
At this point I've lost all confidence in mechanical fuel pumps. Is there one I should be looking for, some brand? Can I rebuild the german 1 I have? It seems to need only the diaphragm? |
Posted: Wed Jul 27, 2016 7:46 am Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
It seems the only mechanical fuel pump available for a type 4 motor is the crappy, leaking, breaks-when-you-touch-it, made in China Omega brand. Sad to say I'll be trying a facet pump I have laying around. |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Wed Jul 27, 2016 3:01 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
Welcome to the 72 life my friend! Weird isn't it? My original pump didn't work, and tried one of those Chinese ones from CIP1. It didn't work either, but it took me soo long to install it I never tried returning it. Ended up with a low pressure electric pump I purchased from AutoZone for about $50. Seems to work pretty good. I'm currently running Dual Dellorto 36's on a 2L, but also worked well with my 1700 w/ the same Dells.
The kit for the fuel pumps are getting harder to find and are around $100 if you do. Can you use the diaghram (sp?) from the chinese unit to rebuild the original? _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
Posted: Wed Jul 27, 2016 3:55 pm Post subject: Re: Driving Daisy – 72 Deluxe Refresh |
NoBudgetVWGarage wrote: |
Can you use the diaghram (sp?) from the chinese unit to rebuild the original? |
smh, yeah I had the same thought, but the original and brazilian ones are like '6 lug' - 6 bolts holding the diaphragm together, while the Chinese one is 5 lug.
It's only a problem for 72-74 bus guys. I really wish a rebuild kit was available for the German one, the APG. I'll definitely keep it around.
I did think about turning a new cap with a hose barb for the omega, something on the lathe, but it's all been a lot of messing around, no telling if it would hold still.
To use an electric, I'm thinking about an oil pressure switch I have, could make a bypass for testing, I hate the buzz before you start is the worst somehow. |
