Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Tcash Samba Member
Posted: Mon Feb 01, 2016 12:03 pm Post subject: Re: 1978 Deluxe Canadian Westy |
That is great news. There have been reports of people loosing there vehicle for one stolen component.
Good luck
Tcash |
Posted: Mon Feb 01, 2016 1:51 pm Post subject: Re: 1978 Deluxe Canadian Westy |
The PO had made some modifications to the Westy to get more storage room.
The fresh water tank had been removed as well as the fridge components - ie: fridge turned into an icebox.
All the parts were kept however and I got them with the bus. I debated putting the fridge back together to make it operational, but after a lot of thought and research, decided not to. I did put back the fresh water tank and will be hooking it back up. I like the convenience of having it.
For a fridge, I have a portable cooler that works on 12VDC and 120V AC on an adapter so will use that along with the icebox.
Because it is a deluxe Westy it had the wiring for a camper battery, although that too had been removed.
It is a Canadian Deluxe though, so no control panel or charger.
I bought an Optima Blue Top and installed it as the new camper battery:
I hooked up a plug so that I can plug in either my portable solar panel to charge it, or a Battery Tender when in storage.
The existing camper battery wiring should charge it via the relay when driving.
I am running a few things off the camper battery:
1. A 12VDC RV light newly installed above the rear seat:
2. A 1000 watt inverter underneath the rear seat:
Note that I also installed a second 120V AC receptacle which is connected to the shore power - piggy-backed off the 120V receptacle which faces out. That allows me to take the yellow plug from the inverter and move it to the shore power - allowing me to run 120V accessories from either the inverter when dry camping (runs off camper battery) or the shore power when plugged in.
3. On the outside of the rear seat compartment, I installed a volt meter with a momentary push button, so I can monitor the Camper Battery voltage easily but not drain it by displaying voltage all the time:
4. I ran electric wiring (using an extension cord in conduit) from the yellow plug shown above, out through the rear seat compartment, along the floor and up by the icebox to the rear of the sink:
From there, I can plug in any 120V AC accessories to run off either the inverter or shore power depending on where the yellow plug is plugged in.
I currently have a small vintage light and vintage fan:
_________________ 1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
Last edited by Globespotter on Tue Feb 02, 2016 12:36 pm; edited 1 time in total |
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Mon Feb 01, 2016 4:06 pm Post subject: Re: 1978 Deluxe Canadian Westy |
I had a hard time finding out what heat dump pipes were. My 78 bus has them. The idea is that there is air going into the heat exchangers all the time in order to keep moisture out. So the heat is then allowed to be dumped because your not using heat in the vehicle. The pipes are used to get the heat to the back of the bus. I think they only used them in 78. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Tue Feb 02, 2016 8:08 am Post subject: Re: 1978 Deluxe Canadian Westy |
Congrats on the bus, and nice progress!
When I was a kid we had a fan very similar to this. We called it "the lopper"! _________________ 1976 Westy
1966 Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51168 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Feb 02, 2016 6:41 pm Post subject: Re: 1978 Deluxe Canadian Westy |
71Survivor wrote: |
No VIN there. |
Did anyone do a pre purchase inspection on that before you pulled the trigger? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Marleybus Samba Member
Joined: January 05, 2013 Posts: 314 Location: Oro Station, Ontario, Canada
Posted: Tue Feb 02, 2016 6:45 pm Post subject: Re: 1978 Deluxe Canadian Westy |
I love my sink and water tank. Personally I would recommend it. It doesn't take much space. Also look into LED lights. They throw great light and take little power. If you have a Canadian bus you should have a BA6 heater under the belly of the bus. Any reason why you didn't run the wire under the fridge cabinet? It would be a lot more inconspicuous. _________________ 1972 VW Westy (Hit by dumptruck)
1963 VW Beetle (RIP)
1974 VW Beetle (RIP)
1981 Vanagon Westfalia (Sold)
1969 VW Beetle Convertible (Wifes)
1977 VW Westy 2.0L FI Chrome Yellow
1978 VW Westy 2.0L FI (Under Restoration)
1973 VW Westy 1.7L Tourist Delivery Orange
Check out my thread!!http://www.thesamba.com/vw/forum/viewtopic.php?t=556709 |
Posted: Tue Feb 02, 2016 7:38 pm Post subject: Re: 1978 Deluxe Canadian Westy |
busdaddy wrote: |
Did anyone do a pre purchase inspection on that before you pulled the trigger? |
Yes, both mechanic and appraiser. The VIN was not filed off there, I'm pretty sure on mine, it only is on the Dash plate. That is what the owner's manual says. Not sure why there seems to be variation on VIN #'s. It's odd.
My owner's manual says VIN on Left Door jamb sticker and dash plate. That's it:
I don't think either of them picked up on the different front end, but they knew it had been rebuilt, and unless you are one of us Samba freaks, finding that M-Plate under the dash and decoding it is probably not SOP.
I'm satisfied that everything is legit and not stolen, and that the front end is a 77 donor front end grafted onto my 78. _________________ 1977 Westfalia - October 2015 - Current
Last edited by Globespotter on Tue Feb 02, 2016 7:44 pm; edited 2 times in total |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22464 Location: Escondido CA
Posted: Tue Feb 02, 2016 7:50 pm Post subject: Re: 1978 Deluxe Canadian Westy |
71Survivor wrote: |
Marleybus wrote: |
If you have a Canadian bus you should have a BA6 heater under the belly of the bus. Any reason why you didn't run the wire under the fridge cabinet? It would be a lot more inconspicuous. |
Yes, I do have the heater which needs to be pulled and refurbed.
Just lazy on the wiring I guess. This is a working bus, so I'm not worried about being too anal about things. I just want to enjoy it |
MMMmmm BA6 - that will be a nice addition when working _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
dabble Samba Member
Joined: April 21, 2004 Posts: 271 Location: Olympia, Wa
