Jamlit Samba Member
Joined: January 30, 2016 Posts: 107 Location: Nova Scotia Canada
Posted: Sat May 14, 2016 4:02 pm Post subject: Re: WolfsburgWest Panels Received |
Good metal is hard to find on the east coast. I live in Nova Scotia and everything is rusted to death here. My 58 bug deal is gone as the seller screwed me over but looking at a 68 now. Looks like lots of rust repair is in my future as well.
Over lapping does work and can be much stronger for sure but I have always had problems with moisture decay between the pieces. Even treat with zink primer and welded all the way around on both sides. Never know it rusting till it has become a larger problem then I wanted. This is only my experience though. We all do the best we can from it.
Again good looking work. Looking forward to seeing the completed project. |
itjustbugsme2 Samba Member
Joined: October 18, 2014 Posts: 246 Location: USA / Ohio
Posted: Mon May 30, 2016 2:27 pm Post subject: Re: WolfsburgWest Panels Received |
Well...headed back in the "Backyard Mechanics" garage to start again on the VW wheel wells ...."Passenger Side". Let me say for those of you "New" to my post....this Bug had previous repairs and as I go further I keep running into more "bad" metal and repairs . Also: This is truly a "Backyard Project"...No laid out garage, no lifts, no CND machine .....hand tools.....cheap A$$ Mig Welder for small project ....some electric cutters, grinders etc.. So before you look and say...."Here's how it should be done" ...remember, I'm old school.....duct tape and wire type "Get her on the road" type of gear head...but honestly....both these rear wheel wells were replaced with "All Metal" panels....the only "Putty" you see is the USA Steel filler which covered the mig weld areas......then a good coating of primer (next pics) and a nice spray of undercoating to protect....Again...not a "Show - Points Car", a "Driver" ....."Solid".....so enjoy the pics and future pics....comments always welcomed .
Posted: Sun Jun 05, 2016 7:56 am Post subject: Re: WolfsburgWest Panels Received |
Had a few comments....you know..."Here's what you need or should do" and appreciate them all....any "tips" always help ......but I want to emphasize one more time....I'm your (maybe typical) "East Coast" backyard gear head ....you know, love mechanics as a "like" - "hobby" but not a career...grew up "fixing $hit" rather than "buying new"....learned from "trial and error".....my back work shop (garage) is not only a "work area" but also shares the space with all the yard equipment (lawnmowers - tools), outside furniture when the Winter hits....Motorcycle and mini bikes and whatever else you don't want in the front garage.....then remember we have the heat it in the Winter which often last until April or May....so: here's a few pics of the work area....try working on a "Bug" when you're limited in space. Not complaining at all....just sharing the pics based on the fact that I'm sure many of you are in the "same boat"......matter of fact....at one time I even had a "boat" back there....enjoy.
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Sun Jun 05, 2016 10:09 am Post subject: Re: WolfsburgWest Panels Received |
Thanks......doin what I can with limited facility an "old school" talent.......just added a little more putty to the weld areas just to smooth it out but not real concern with the wheel wells being flawless......going to spray some undercoating over the completed work just for some more protection....and put the wheels back on. I just wanted to get "new" metal back on both of them; especially the rear bumper mount section and the shock towers....using the lights to quicken the dry......you know when you work when you can......cold or wet weather......you always try to help out the process.....should be good to go soon.
Posted: Sun Jun 05, 2016 10:14 am Post subject: Re: WolfsburgWest Panels Received |
Flyboy......went and looked at your profile and see you are an aircraft mechanic....I'm a safety and health consultant and one of my clients is a local FBO....also I took flying lessons some time back but never got my license...but have a love for aircrafts and going up....we share some similar interest.... |
Posted: Sun Jun 05, 2016 10:53 am Post subject: Re: WolfsburgWest Panels Received |
Yes sir we sure do. I have a '58 that I'm using some of the same techniques as you for repairing one hole. I'm sure your repairs will hold up for years to come with proper care and feeding, hahaha. I don't so much do the mechanical side of the house anymore; I supervise a crew of all skills on heavy modification of C-17's now. But in m day I've done just about all there is to do on these planes. From electrical, flight controls, hydraulics, structural repair and even flew on them for a few years as a flight engineer. Just keep doing what you kno best. _________________ My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
Posted: Sun Jun 05, 2016 2:15 pm Post subject: Re: WolfsburgWest Panels Received |
OK., I got the "new" metal (panels - Shock Tower area and Rear Bumper mount area) mig - tacked in, clean them up and put a nice "undercoating" over them. Both driver and passenger sides done. The upper "fender mount" area(s) will be cleaned up a little better, primered now will be left alone. Have to work on both the front and rear fenders now before they get re-mounted (minor cleaning up) and also going to re-finish the rear "interior" seat section .....where I cut out the rear wheel wells left some needed repairs; rear apron was also cleaned up. Again, this not a "body off" restoration and not a "show quality" repair....just wanted to get some "new" - "solid" metal where it was needed. Want to get her back on the road before the (Ohio) summer is over, see how she goes and if she works out well.....maybe.....maybe do some more (where needed) body work next winter. Calling it quits for today....rain storms moving in and I have to have that back garage door open....hope these post helps someone out as to what you can consider if doing a similar project and what "not to" or what "to do". Take care until my next post.
Posted: Wed Jun 22, 2016 7:01 am Post subject: Re: WolfsburgWest Panels Received |
Well; the rear wheel wells (replacement panels) are complete. Now I'm going to build up (repair-add some sheet metal) to the inside of the rear seat section. After cutting out those inner wheel wells I left some cavities that need filled. The Floor Pans actually look fairly solid (past replacement - not my work) so I simply brushed off the surface rust vacuumed it up and put a nice coat of POR over it (rusted but solid areas) . Other weak areas will be patched up (sheet metal) and then a nice over coat of USC All Metal filler...I like how it spreads and the fact it actually has metal fillings in it seems good. One think I'm doing; when I cut the original metal out of the rear wells, I had some fairly large "original metal" solid pieces. I have been using them for "patch metal", that way this Bug has the "original" metal even on some patches. Until my next post - back to work.
grandpa pete Samba Member
Posted: Wed Jun 22, 2016 10:18 am Post subject: Re: WolfsburgWest Panels Received |
I've been a "Practicing Body Shop" guy for years ....one day I'm going to get good at it . Often when I patch an area....I'm glad no one is around to see how it was done ....but..........she'll be sturdy and ready for the road in a few weeks.........I hope . |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Thu Jun 23, 2016 5:15 am Post subject: Re: WolfsburgWest Panels Received |
itjustbugsme2 wrote: |
comments always welcomed |
First time reading through your post and the only comment I have is....is it really "necessary" to put "quotes" around "every other" word in your "posts"? I don't know why but it's making me "crazy" and making it a "pain in the ass" to "read." Otherwise..."looks great". _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Thu Jun 23, 2016 6:34 am Post subject: Re: WolfsburgWest Panels Received |
"LOL".. ...."Sorry"....."OK"......"No more Quotes".....but really.....if you think about it......you probably was a "Little" crazy way before reading my "Quotes"...but ok....NO MORE |
splitjunkie Samba Member
Posted: Thu Jun 23, 2016 8:48 am Post subject: Re: WolfsburgWest Panels Received |
Looks like you have done nice job making those less than perfect panels fit.
One bit if advice though. Primer will not protect from rust for very long. Moisture can go right through it. Undercoating also doesn't provide as much protection as you think. It can retain moisture or allow it to get through tiny imperfections in the coating. You really should put a coat of paint over the primer to prevent future rust issues before undercoating it. _________________ Chris
Posted: Thu Jun 23, 2016 8:55 am Post subject: Re: WolfsburgWest Panels Received |
No doubt. The primer is simply a temporary coating. Once all the patch work is done, primer, filler applied.....I'll go ahead and put a nice coat of paint over her. For the inside, I'll probably simply use a nice flat or mat rust-oleum finish...you won't see that area once the interior is put back in and I believe the rust-oleum will provide a fairly good protection. Hey....."No Quotes"...oooops, sorry |
Posted: Thu Jun 23, 2016 9:03 am Post subject: Re: WolfsburgWest Panels Received |
I was referring to the wheel wells where you put the undercoating directly over the primer. _________________ Chris
Posted: Thu Jun 23, 2016 10:05 am Post subject: Re: WolfsburgWest Panels Received |
Oh, I agree...........well, we'll see how she holds up and possibly down the road I'll scrape that undercoating off and put a good coat of protection on the area....but I do agree with the moisture being trapped.
Hey, anybody reading this post: I went in the back garage and was going to start repairing some rust on my fenders...they're repairable but I'd like to find some better replacement fenders if I could. I know I can order replacements, right at around $200.00 (add shipping) a piece; but wondering if anybody has a set, front or rear they are selling. Any leads appreciated. |
Posted: Fri Jun 24, 2016 6:45 am Post subject: Re: WolfsburgWest Panels Received |
If you can't find anything in the classifieds or a local club, there's a big show coming up the second weekend in August in Pataskala, OH. COVVC Volksfest has a great swapmeet every year so you can probably pick up a good set then if you aren't in a terrible rush. Also great camping that weekend just a few miles down the road in Mt. Vernon at The Dixie Bus Gathering. I'm there every year, one of the best campouts goin! _________________ First Trip in the RustyBus:
borninabus wrote: |
notchboy wrote: |
EverettB wrote: |
Posted: Sun Jun 26, 2016 6:26 am Post subject: Re: WolfsburgWest Panels Received |
Thanks, I'll keep that in mind. Appreciate it. |
