Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jul 14, 2016 7:25 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Soak the rubber bumpers in glycerin to soften them back up. _________________ In Stereo, Where Available! |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Thu Jul 14, 2016 7:42 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Eric&Barb wrote: |
Soak the rubber bumpers in glycerin to soften them back up. |
Thanks for the tip i will try that. That might work on the roller cabinet wheel too. There are a few others in this camper that can use some softening. |
Posted: Thu Jul 14, 2016 8:43 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Roller cabinet wheel is a vintage "clay" wheel so it should not soften up. It was designed with non-marring of the floor in mind. _________________ In Stereo, Where Available! |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Fri Jul 15, 2016 7:32 am Post subject: Re: 1965 westfalia so-35 flipseat |
Outstanding job on the cabinets, thanks for sharing _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Jul 15, 2016 10:53 am Post subject: Re: 1965 westfalia so-35 flipseat |
Very nice work. Its always good to see the right person at the right time savaging what they can on any old bus. Keep up the good work! _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
oakman Samba Member
Posted: Fri Jul 15, 2016 11:14 am Post subject: Re: 1965 westfalia so-35 flipseat |
^^Thank you all for the tips and encouragement! I think one of the hardest things for me on this project is where to draw the line-what should be fixed, what is ok to leave as is. My slightly obsessive self wants it all to look perfect, but i'm learning to love the character and originality of what has survived all these years later. Tips, comments, constructive criticism are all welcome and encouraged! Thanks for looking. |
srfndoc Samba Member
Posted: Fri Jul 15, 2016 11:20 am Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
I'm the same way with my Westy as its mostly original inside. I try to keep things working well functionally and using OG replacement parts in better condition when I need to actually replace something. My floor is original and in decent shape so I can't bring myself to replace it even though the obsessive in me thinks it needs to be perfect (it has a few holes and is separating in a few spots).
Greg and Clara seem to do a good job along these lines so I try to follow their outline. I think preservation vs. restoration is key. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Stocknazi Samba Member
Posted: Fri Jul 15, 2016 11:33 am Post subject: Re: 1965 westfalia so-35 flipseat |
Curious what type of finish you are using on your cabinets? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Fri Jul 15, 2016 11:40 am Post subject: Re: 1965 westfalia so-35 flipseat |
notchboy wrote: |
Very nice work. Its always good to see the right person at the right time savaging what they can on any old bus. Keep up the good work! |
Yes, we all need to see more savaging of buses! _________________ In Stereo, Where Available! |
oakman Samba Member
Posted: Fri Jul 15, 2016 3:12 pm Post subject: Re: 1965 westfalia so-35 flipseat |
srfndoc wrote: |
My floor is original and in decent shape so I can't bring myself to replace it even though the obsessive in me thinks it needs to be perfect (it has a few holes and is separating in a few spots). |
I can relate! While cleaning up the cab area I was afraid to remove the seat stand mats because they are a bit brittle and I knew the only safe way to scrub them was left in place where they are form-fitted. A friend came by and nicely reminded me that WW makes re-pops.
Posted: Fri Jul 15, 2016 3:19 pm Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
While cleaning up the cab area I was afraid to remove the seat stand mats because they are a bit brittle and I knew the only safe way to scrub them was left in place where they are form-fitted. A friend came by and nicely reminded me that WW makes re-pops. |
Glycerin will help soften those up also. Actually any flexible rubber, plastic, vinyl, etc. will do better and last longer if used at least once a year, for hot weather areas probably twice a year. _________________ In Stereo, Where Available! |
oakman Samba Member
Posted: Fri Jul 15, 2016 3:52 pm Post subject: Re: 1965 westfalia so-35 flipseat |
StockNazi wrote: |
Curious what type of finish you are using on your cabinets? |
I have tried a few different methods on scrap paneling (not from this bus) and this is what i found to be a good method. After a piece is scraped clean of the old finish, I put a light coat of the "Zinser shellac" brand clear. It has a slight amber tint to it that seems to really bring the grain back to life. It dries quickly but I let it dry overnight usually. Give it a light sanding before applying the first coat of the poly-clear. This takes a little longer to dry, I leave it to dry overnight at least, light sanding and repeat 2 more times. The poly clear seems to me a true clear without darkening a bit more with each coat like the shellac. Shellac is approved to be used as a sealer/base coat beneath polyurethane, according to the can at least.
The spray cans have worked good so far, the poly clear lays down really nice and flat with absolutely no spray lines visible once it's settled and dry. I take the nozzles off and clean them in paint thinner after each use to keep from clogging.
I sampled high gloss, semi-gloss and satin finishes but ended up going with semi-gloss. It looks to be close to what was used originally like here in the back of the Emka cabinet.
The headliner portion will either need to be sprayed with a paint gun or applied with a pad or brush. Too much acreage for spray cans. Not sure yet what amount of gloss/flat finish it should have either. It seems to be less of a gloss where it's not checked and flaking.
oakman Samba Member
Posted: Fri Jul 15, 2016 4:19 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Eric&Barb wrote: |
oakman wrote: |
Glycerin will help soften those up also. Actually any flexible rubber, plastic, vinyl, etc. will do better and last longer if used at least once a year, for hot weather areas probably twice a year. |
Good to know, but i must admit i have only seen glycerin in ingredient lists on food labels. Edit: Looks like i can get it at Walgreens drug store. I need to get out more apparently! |
Posted: Fri Jul 15, 2016 6:20 pm Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
Also makes good soap!
Apparently Vaseline does same. Back in the 1980s the upholster fellow who did my 63 KG interior told be to apply some to the seats and vinyl headliner to keep it supple in the Texas heat. Never did try it though.
Helped Clara get her 54 BD out of the high desert in E. WA decades ago. The front OG floor mat was nearly petrified. After applying glycerin it went from feeling like it was going to shatter to a much more flexible state. _________________ In Stereo, Where Available! |
Posted: Sat Jul 16, 2016 6:46 pm Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
StockNazi wrote: |
The headliner portion will either need to be sprayed with a paint gun or applied with a pad or brush. Too much acreage for spray cans. Not sure yet what amount of gloss/flat finish it should have either. It seems to be less of a gloss where it's not checked and flaking. |
I like the look of the shellac, especially when it is brushed on. If you look at the og cabinet/panel finish it was no doubt brushed on; you can see brush marks clearly. You do have to work fast and keep a wet edge with the shellac, but other than that it's nice to work with. _________________ WANTED:
Thomas Jefferson |
oakman Samba Member
Posted: Sun Jul 17, 2016 12:12 am Post subject: Re: 1965 westfalia so-35 flipseat |
StockNazi wrote: |
I like the look of the shellac, especially when it is brushed on. If you look at the og cabinet/panel finish it was no doubt brushed on; you can see brush marks clearly. You do have to work fast and keep a wet edge with the shellac, but other than that it's nice to work with. |
I thought those were fine brush marks too until I started looking around more and found otherwise.
This is beneath the ice box cabinet and has no finish, yet it bears the exact same fine lines that look like brush marks:
From beneath the gnarly black stained area, ice box is upside down:
I think they're sanding lines from how they manufactured the veneer. Looking all over these pieces I really can't say for sure if the finish was brushed on or not. If it was indeed brushed those Germans did a stellar job!
I was searching the gallery for so-35 interior pics recently and noticed this pic from Clara showing how the wood inside the Emka cabinet is different from the Swiss Pearwood on the exterior:
Where my bus has the same Pearwood veneer inside and out of the cabinets:
Maybe an early vs late thing? |
oakman Samba Member
Posted: Sun Jul 17, 2016 7:01 pm Post subject: Re: 1965 westfalia so-35 flipseat |
The cabinet doors all have a number stamped on the backside along with the same number stamped on the inside of their matching cabinet face. Number 17 is the long door on front of the closet:
This is also noted on the molding, mostly in pencil but at least two in ink:
Other numbers found. #97 is the solid side piece of the closet, stamped on the top edge:
#41 & 42 are the rear closet doors:
The highest numbers i can find are the booze bottle cabinet and the Emka cabinet above it which are numbers 161 & 162:
The lowest numbers i found are #7 & 8, this is inside the cargo door cabinet:
Maybe a clue to production totals? I just thought it was interesting, i love the minutia.
oakman Samba Member
Posted: Sun Jul 17, 2016 8:49 pm Post subject: Re: 1965 westfalia so-35 flipseat |
I experimented with the oxalic acid in a few areas that are hidden before attempting anything that shows. This is only my experience so if you decide to do any wood bleaching take your time and do many tests. It works great on the interior cabinet shelves which are a plywood of some sort, limba maybe? On the veneer i had some mixed results. Left on too long or more than two treatments of the same area it can dissolve the glue and lift the veneer. The veneer is really brittle and fragile on this westy after years in the desert, especially on the front of the closet where it is stained down at the bottom.
I started in this lower corner initially:
After seeing how it reacted and getting a method down i went ahead and worked on the whole area top to bottom a couple inches at a time. I used compressed air to dry the veneer quickly. I think it looks better than it did, here it is after the coat of shellac:
I did a handful of micro repairs to the veneer on the face of this cabinet where it was buckled/peeling from the seams. Tiny relief cuts with a razor blade and carefully lifted then glued back down. At least they're flat now and barely noticeable among the other tiny splits. This is after a light coat of shellac to seal the veneer:
Here's a good example of what the cabinets looked like when new. This is inside the wardrobe next to the right rear wheel well. There is a piece of paneling that covers this, you can see the staple holes. Much more red color to the wood originally.
DanM Samba Member
Joined: June 07, 2002 Posts: 1330 Location: Falls Church, VA
Posted: Wed Jul 20, 2016 5:10 am Post subject: Re: 1965 westfalia so-35 flipseat |
damn. amazing bus and great work. keep it up! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14272 Location: Casa de Oro, California
Posted: Wed Jul 20, 2016 8:43 am Post subject: Re: 1965 westfalia so-35 flipseat |
Oxalic is hard on the laminate if the wood is old as it has water. Heat up the water to almost untouchable before mixing the crystals and it will work faster without leaving it on as long. |
