Singerdude Samba Member
Joined: March 07, 2015 Posts: 464 Location: Quebec, Canada
Posted: Mon May 23, 2016 6:32 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Looks like it |
Posted: Mon May 23, 2016 7:19 pm Post subject: Re: Splitting case/changing lifters and pushrods |
there's your 1/4" valve lash!!!!! _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon May 23, 2016 7:24 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Yup! And now for the ball-adjuster vs. Porsche adjuster, the point is moot cause I'll use these
Posted: Mon May 23, 2016 8:07 pm Post subject: Re: Splitting case/changing lifters and pushrods |
so you are clear, you use those rockers with lash caps. _________________ It's just advice, do whatever you want with it!
Posted: Tue May 24, 2016 9:08 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Well, I received the FK8 and the new pushrods today, the PR were the not the ones ordered and the FK8 was the dreaded sc-1... I'm not putting one of these back in... Not with the same lifters anyway. They weren't empi but a set of old bugpack lube a lobes. The alternate set we had was some CB ultralights. A quick call to David @ CB and we were discouraged to use CB lifters with an Sc-1 cam. We finally decided to order an eagle K8 and Cromoly PR's from him. The other stuf is going to be sent back. We also sent the crank out for some light polishing. Everything is now sparkling clean and ready to be re-assembled. Should be done for the weekend.
Good catch there Glen, as I was talking with the shop guy, he wasn't aware of the issues with Sc-1's. All the cams he has at his shop are EP12's. They're mostly his former boss' inventory that he bought a few years back when he quit doing ACVW's.
I remember reading a long thread on cam metallurgy a while back, I'll try and search it to educate myself (again). Gee that infinite ocean of data sure comes in handy at times but as I age, the more I learn, the more I have to forget to make room for the new stuff... |
modok Samba Member
Posted: Tue May 24, 2016 10:25 pm Post subject: Re: Splitting case/changing lifters and pushrods |
good plan.
IMO, ep-12 with CB lightweighs=ok
Others report, sc-1 cam with engle or scat lifters=ok
If the universe was fair, the VW aftermarket parts society should send you at least a thank you note, for your "R&d work" and persistence.
Thanks! and good luck |
Posted: Wed May 25, 2016 6:33 am Post subject: Re: Splitting case/changing lifters and pushrods |
Thank you, but I sure won't be sad to leave the R&D part behind... Well, I wanted to learn about these engines, and I sure am learning, the hard way maybe, but learning still. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed May 25, 2016 2:18 pm Post subject: Re: Splitting case/changing lifters and pushrods |
modok wrote: |
good plan.
I follow this regiment. I also use brazil resoulence( CB bigfoot) with lower lift, milder cams on ep12 blanks also. For the sc-1/EP10 blanks I only use the scat non hole versions. My personal engine uses a web cam that has been stroker clearanced so the id was scrubbed. For this one I use the TS-28s. Expensive but light and sexytime.
Nowdays when I order a cam, I specifically ask what cam blank it is for assurance on what lifter to use.
Sorry you have all these problems pal. They can really bum you out. My 1915 would've been perfect for you! Good luck brother and hope this time she purrs for 50k+.
Jon _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
porkchop-rob Samba Member
Posted: Wed May 25, 2016 3:00 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Props to you for hanging in there.
I hope it all works out this time! _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
Posted: Wed May 25, 2016 3:06 pm Post subject: Re: Splitting case/changing lifters and pushrods |
spread the word. It's amazing how many guys don't know of this cam/lifter compatibility issue, it's been going on for over a decade and we still see this disaster all the time! _________________ It's just advice, do whatever you want with it!
Posted: Wed May 25, 2016 9:54 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Thanks guys for all the good words it is appreciated. I won't let this car get the best of me. I'm meant to drive it, not the other way around.
Jon, the dude who started a thread asking questions about your 1915 didn't buy it in the end? Anyway, yeah I'm sure one of your engines would have caused me a lot less troubles, or one of John's longblocks for that matter. Hindsight is 20/20 and all that jazz. But the main incentive to have my engine re-built here instead of ordering a longblock was to be able to assist with the re-built and get some hands-on experience while also having someone local as a ressource.
Now fingers are crossed and I hope to be able to enjoy at least a few thousands worry free miles this summer. Based on my current experience, the idea of this engine lasting 50k seems rather far fetched but If I can get 15-20k out of it without any more major repairs, I'll be happy.
Again, thanks to everybody for contributing here. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Thu May 26, 2016 6:36 am Post subject: Re: Splitting case/changing lifters and pushrods |
Great stick-to-itiveness. I know well the pain of having things go upside down and also know well the joy of righting them. Good luck driving the car and have miles fun. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15313 Location: Deep in the 405
Posted: Thu May 26, 2016 7:39 am Post subject: Re: Splitting case/changing lifters and pushrods |
[email protected] wrote: |
spread the word. It's amazing how many guys don't know of this cam/lifter compatibility issue, it's been going on for over a decade and we still see this disaster all the time! |
Because there are only a few dedicated parts stores that care enough to educate the buyer. Most shops hope you have issues so they can continue to sell you more parts when you break the last ones they sod you. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu May 26, 2016 8:13 am Post subject: Re: Splitting case/changing lifters and pushrods |
vwracerdave wrote: |
Because there are only a few dedicated parts stores that care enough to educate the buyer. Most shops hope you have issues so they can continue to sell you more parts when you break the last ones they sod you. |
It isn't a brilliant business model: if it weren't for the support here on the Samba, I would've just given up the hobby and invested my money and time in something else. I'm sure I'm not the only newcommer who's thought of that. Kudos to John and the few other parts store/shop owners that take some of their valuable time to educate. |
Posted: Sun May 29, 2016 6:17 pm Post subject: Re: Splitting case/changing lifters and pushrods |
Case is sealed, barrels, pistons and heads bolted in place. New geometry and valvetrain should be setup by tomorrow. Then if all goes well, I should have it in the car for the weekend...
