TSLAVO Samba Member
Posted: Thu Aug 27, 2015 4:35 am Post subject: My 57 RHD Oval |
Picked this up weeks ago. Will spend some times collecting info. before doing anything on it. Going to be stock.
Chasis no below rear seats and front plate traced back to Jan 57, engine no to Jan 57 and body to Dec 56.
TSLAVO Samba Member
Posted: Fri Aug 28, 2015 5:15 am Post subject: 57 oval |
Today managed to find some time to shoot some photos. Trying to make a list of parts that i need to buy. It is difficult to get them locally so i got to bring them in together to save some shipping.
Severe rust at spare tyre well.
rust and hole at bulkhead too
No keys come along when bought it. It's a L profile ignition, not correct for oval.
A peek inside gas tank. Good that Fuel valve is there.
Engine come seperately.
goreygoreymanunited Samba Member
Joined: May 12, 2010 Posts: 44 Location: forest of dean
Posted: Fri Aug 28, 2015 2:31 pm Post subject: |
Wow. What a great find. A great start for a project. Where did you find the car? |
TSLAVO Samba Member
Posted: Sat Aug 29, 2015 5:42 am Post subject: |
Found it abandoned in a garage in a small town. It was left in the shade under a tree. It should have been in better condition if it is covered. Got it home after some hard bargain. Too bad that i didnt manage to shoot some photos when i found it.
TSLAVO Samba Member
Posted: Sat Aug 29, 2015 6:38 am Post subject: |
Took out the gas tank today. Brake line to master was broken. Hole for choke cable enter chasis was blocked off.
2 bolt cylinder, right for 57. Check in WW website, it cost $98 for rear and $89 for front! so much higher than cylinder for 60'.
Does it looks like 57 fender?
TSLAVO Samba Member
Posted: Thu Sep 03, 2015 6:27 am Post subject: |
Checking thru' all the engine stuff today.
bleeds_ink Samba Member
Joined: February 22, 2008 Posts: 219 Location: highland il.
Posted: Tue Sep 08, 2015 5:56 pm Post subject: |
Nice score on the semaphore car! I got a '57 bettle with semaphore too _________________ 1957 vw beetle
2012 vw gti |
txoval Samba Member
Joined: January 23, 2004 Posts: 3554 Location: The Woodlands, TX
Posted: Tue Sep 08, 2015 8:21 pm Post subject: |
The bottom of that car is pretty rotten, not trying to be a downer...
Not too often you see the front bulkhead rusted thru. Definitely appears the bottom side of the body will need to be cut out and replaced.
Good luck |
TSLAVO Samba Member
Posted: Wed Sep 09, 2015 5:09 am Post subject: |
Hello Bleeds..just glanced thru' thread on your 57. Nice work. I wish i have the facility to do sand blast for the body and power coat for the floor pan. Did your oval come with working semaphore? Is than a 6v? One side of mine is not complete.
txoval wrote: |
Good luck |
yup, i noticed rust thru at the bulkhead when i bought it, the rest of the chasis looks ok. Flloor pan and heat channel need to be replaced. Considering oval is pretty rare here, i didnt give 2nd thought about the condition when i bought it. I have not seen more than 10 oval here. |
Basketcase Samba Member
Posted: Wed Sep 09, 2015 8:33 am Post subject: |
nice find. keep the pics coming please! _________________ '72 Karmann Ghia Coupe (the Boss's) |
TSLAVO Samba Member
Posted: Sun Jun 26, 2016 9:33 am Post subject: Re: My 57 RHD Oval |
Decided to start with the engine. Managed to put it on the stand and started to open it up.
Con rod bearings need to be changed
-4 mark on right side of the picture
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Jun 26, 2016 9:55 am Post subject: Re: My 57 RHD Oval |
... beautiful interior and exterior body... patina... wouldn't change a thing. That is as beauty... have a '65 rust free pans, but the bulkhead is rusted through... no big deal. Will just repair that... beautiful. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
TSLAVO Samba Member
Posted: Tue Jul 12, 2016 3:49 am Post subject: Re: My 57 RHD Oval |
PO told me that this engine had a full rebuild and then has been sitting for years without being fired up. After opening up, it looks true that it has clean heads, new valves and new pistons. The pistons were wrongly installed with the arrow pointing wrong direction though. valve springs have not touched any oil and they all rusted.
Short block didnt show any sign of rebuild. Anyhow,I am glad that i took this path to open up the engine to take a look inside.
TSLAVO Samba Member
Posted: Fri Jul 22, 2016 5:18 am Post subject: Re: My 57 RHD Oval |
Trying to figure out how oil passage works.
Factory plugs
TSLAVO Samba Member
Posted: Fri Aug 26, 2016 7:19 am Post subject: Re: My 57 RHD Oval |
Finally all parts needed to complete the engine arrived.
TSLAVO Samba Member
Posted: Fri Aug 26, 2016 7:20 am Post subject: Re: My 57 RHD Oval |
Bought the rear engine tin from classified in samba
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Aug 26, 2016 7:23 am Post subject: Re: My 57 RHD Oval |
TSLAVO wrote: |
check the fit of the gland nut in the crankshaft before getting too far into the build. with that extra "lip" on the non threaded shaft, it does not look like a 36hp gland nut to me. 36hp gland nuts should be fully smooth there and not have a lip. |
TSLAVO Samba Member
Posted: Fri Aug 26, 2016 7:46 am Post subject: Re: My 57 RHD Oval |
hazetguy wrote: |
TSLAVO wrote: |
Thanks for the advice, will take a look at the garage tomorrow. Bought it from WW, hope it is correct. |
TSLAVO Samba Member
Posted: Fri Aug 26, 2016 7:50 am Post subject: Re: My 57 RHD Oval |
Posted: Fri Aug 26, 2016 8:02 am Post subject: Re: My 57 RHD Oval |
i guess what i meant was to check to make sure it threads down all the way without that lip hitting the crankshaft.
the threads are the same as a later gland nut.
maybe WW had them manufactured differently, i am not sure. |
