WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Thu Jul 07, 2016 6:56 pm Post subject: Re: 66 slider |
Stepped 6V on left, o-ring 12V style on right.
Photo from hazetguy's gallery. _________________ Aaron D. Badertscher
Click here for ALL my links. |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Tue Jul 12, 2016 9:20 am Post subject: Re: 66 slider |
did a few things:
Changed out the old transmission mounts. They were toast.
Then checked the clutch:
Looks normal, not soaked in oil like I thought it would be.
what could cause this weird wear?
Same thing here. Not soak in oil.
Could the wear on the clutch input be from the ring on the pressure plate? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14272 Location: Casa de Oro, California
Posted: Tue Jul 12, 2016 10:24 am Post subject: Re: 66 slider |
orangebug60guy wrote: |
Could the wear on the clutch input be from the ring on the pressure plate? |
Does the pressure plate thrust ring have matching scars? That throwout bearing looks kinda different. See if it has matching scars. |
Posted: Fri Jul 29, 2016 2:02 pm Post subject: Re: 66 slider |
Drove down to the Mid Atlantic to visit my brother and pick up some parts from Russ aka "russbus". New 1776 with few miles, spare big nut tranny with many big nut parts to go with it, and heater boxes. Good haul from this weekend.
Posted: Sun Aug 07, 2016 3:36 pm Post subject: Re: 66 slider |
Went to work on the engine I got from Russ today. I took the alternator off and put the generator from the old engine. Cleaned up the tin, removed the frozen flaps, and changed the stand.
Old Alternator:
New generator:
Gotta clean up this mess. Any suggestions:
Rob gave me a set of these cool screens for camping that cover pop out windows!
Nifty huh! _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Aug 07, 2016 4:31 pm Post subject: Re: 66 slider |
the view outside your camper windows is nice |
Posted: Tue Aug 16, 2016 12:33 pm Post subject: Re: 66 slider |
Slammed engine in last week with a fresh sachs kit form bugcity in Berlin CT. Motor has gobs of power and runs like a top! Only funky thing is since it its AJ coded motor its has no mechanical fuel pump. So Russ suggested a electric fuel pump. This is a FI case built up to a 1776. So far so good.
I really want to go to flanders this september. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
viciouscycle Samba Member
Posted: Tue Aug 16, 2016 9:35 pm Post subject: Re: 66 slider |
I had a '66 panel w/ sliding door in high school, '74-'75
Way fun van.
The one I should have picked up was a '65 double door slider deluxe that I found in Idaho, never seen another one. |
Brw1marine Samba Member
Joined: September 07, 2014 Posts: 67 Location: South Wales UK
Posted: Thu Aug 18, 2016 4:04 pm Post subject: Re: 66 slider |
viciouscycle wrote: |
Way fun van.
Here is a stunner of a single slider deluxe
Posted: Thu Aug 18, 2016 4:51 pm Post subject: Re: 66 slider |
Not bad but that interior needs some work. My thoughts if I was restoring a bus like that and spending coin like that I would at least make the seats look og and not that Barrett Jackson puke. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Posted: Thu Feb 23, 2017 1:31 pm Post subject: Re: 66 slider |
No improvements this winter. Just happen to be able to drive it in February in Massachusetts on a 60 degreee day!
Hanging out with its best bud "tub bus"
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Fri Feb 24, 2017 12:21 pm Post subject: Re: 66 slider |
From the TO bearing or PP ring. Had even worse problem with the disc casting being fatter there and would not let the clutch disengage the engine from the transaxle. Required pulling the engine and grinding down that center disc area slightly. _________________ In Stereo, Where Available! |
Posted: Fri Feb 24, 2017 2:20 pm Post subject: Re: 66 slider |
Eric&Barb wrote: |
From the TO bearing or PP ring. Had even worse problem with the disc casting being fatter there and would not let the clutch disengage the engine from the transaxle. Required pulling the engine and grinding down that center disc area slightly. |
I ended up replacing the whole clutch, pressure plate, and throw out bearing with a sach kit. Solved the problem. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Fri Feb 24, 2017 2:48 pm Post subject: Re: 66 slider |
rawkin'
you're officially that 'vw bus guy' in your town now! |
Posted: Sun Jun 11, 2017 2:32 pm Post subject: Re: 66 slider |
Went camping last night. Someone called the cops on me.? So weird. They were doing a "wellness" check.
Posted: Mon Jun 12, 2017 8:18 am Post subject: Re: 66 slider |
well, people s*ck. I hate when stuff like that happens, sometimes police will say 'someone called' too ya know.
where were you camping? with all this rain in may new england is looking most verdant |
BarryL Samba Member
Posted: Mon Jun 12, 2017 10:16 am Post subject: Re: 66 slider |
iamdonquixote wrote: |
well, people s*ck. I hate when stuff like that happens, sometimes police will say 'someone called' too ya know. |
Did the cops say they thought you were dead? |
Posted: Tue Jun 13, 2017 8:26 am Post subject: Re: 66 slider |
I was camping at Sutton Falls campground. It was weird. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Posted: Sun Nov 05, 2017 8:59 am Post subject: Re: 66 slider |
The bus has been pushing along all summer with no issues. Had to stop at the town water tower for a quick pick.
Took the bus to Flanders All Air Cooled gathering. I haven’t driven the bus over the tapanzee bridge in many years. Very cool show.
The last show of the year is always transporterfest. A little cold and wet but always a great swap.
totemwesty Samba Member
Joined: February 17, 2009 Posts: 134 Location: Bend, Oregon
Posted: Sun Nov 05, 2017 1:13 pm Post subject: Re: 66 slider |
Such a cool bus and great camp / show photos. Did you get any parts from the swap or just check it out? _________________ "I set sail for the new world, then I burned down the mast.... It wasn't the first time, and I know it wont be the last..." Bloodkin
'67 Westy Pop Top |
