Angus Dowrie Samba Member
Joined: March 07, 2005 Posts: 341 Location: Kangaroo Point, Australia
Posted: Sun Dec 20, 2015 1:03 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
OK, starting to look at paint.
I'm going two tone (sea blue and blue/white roof), but it's the transition I'm interested in here.
The cars were originally painted one colour, and then had the roof colour added over the top so there was a distinct ridge between the colours from the factory.
How have people done the two-tones today? A smooth transition or as per original? In line with the rest of the car, I'm leaning towards the ridge as per original, but I'm interested in other peoples thoughts/comments who have done a two-tone car. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
http://www.thesamba.com/vw/forum/viewtopic.php?t=610414 |
Posted: Mon Jan 04, 2016 2:11 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Trial fit of fuel tank and spare tyre to check hood closure. All OK, apparently many Ghias can't fit a tyre here.
Paint shop opens on 11 Jan so will be getting sample colours then. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Tue Jan 05, 2016 12:32 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Nice! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Tue Jan 05, 2016 6:36 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Angus, have you looked at Chris's (kiwighia68) Ghia? He's documented it very well.
http://www.thesamba.com/vw/forum/viewtopic.php?t=578994 _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Posted: Tue Jan 05, 2016 4:28 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
I've certainly looked at Chris' thread, almost managed to arrange a catch-up when I was going to NZ for work, but the trip has been delayed unfortunately. My thread will never match his literary prose!
Final bit of welding on the car! when the headlight buckets were fitted up, as can be seen in the photos below the concentricity was not great. Ended up with flat sections exposed around the edge of the headlight.
Looking in the gallery, it seems it's a common thing, I'm probably being overly fussy on it. But Barry will be re-working the metal around the headlights to improve that before welding out the buckets.
Another thing I noted was that the fit of the OG chrome rings was better than the repro Danish rings, so I'll be re-chroming the originals. This is with Euro headlight style as fitted to the Aussie cars.
Build thread;
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Tue Jan 05, 2016 6:01 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Angus Dowrie wrote: |
...Final bit of welding on the car! when the headlight buckets were fitted up, as can be seen in the photos below the concentricity was not great. Ended up with flat sections exposed around the edge of the headlight... |
The more I look at your build and others and remember how I walked the same road, the more I'm reminded of Tolstoy's statement that not all families are unhappy, but that every unhappy family is unhappy in its own unique way.
That certainly goes for our cars. Each has its own "unhappiness". Mine was bad but not around the headlights. And, of course, it had that hidden damage to the right side door hinge pillar assembly, which required a considerable detour on the road to complete the metalwork.
As to the "ridge" where the roof paint meets the body paint, the painter guy didn't like the idea when he painted my Ghia. So the transition is seam-less. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Tue Jan 05, 2016 8:11 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
I'm pretty sure that when the car is all together I'd be the only one who actually noticed that bit around the headlights. But now I have it'll drive me nuts, so I'm getting it fixed.
In this case it wasn't even a uniform error, it was on the outside edge of one and inside edge of another. No-one else will care, but I'll Know! _________________ 1963 Australian Delivery RHD Coupe
Build thread;
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Jan 05, 2016 11:43 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Can I suggest that your panel beater test fits the ring with the rubber seal. I found that one side wouldn't go on as nicely once the seal thickened things. Timing is right to do it now before paint and I just wish I had thought of it when it was my time.
Just a small dab of contact cement every 30 degrees around the ring will keep it position during test fist and will clean off later.
This image is how my euro headlight fitted out on the side that got the new surround and bucket. The hook at the top of the bucket is has a 5mm gap to the headlight surround which is where the seal is squished the tightest
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Wed Jan 06, 2016 2:58 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Thanks Nicholas
We did talk around that, but I'll let him know you found it made a real difference, I'll be giving him a call tomorrow. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Posted: Fri Mar 04, 2016 3:49 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Been a bit of a gap since last update.
Here are some photos of the motor going together. Riechert manifolds, linkage and air cleaners, 28PCI carbs, 010 distributor, vintage speed exhaust. A few bits of tinware appear to have gone AWOL, need to dig through some boxes!
Build thread;
wcfvw69 Samba Purist
Posted: Fri Mar 04, 2016 5:56 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Nice save of this Ghia! You got lucky to have found that body guy. He does good work.
I'm looking forward to seeing this beauty painted.
Cheers _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Mar 05, 2016 3:06 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
That engine's a beauty! _________________ Two Bugs-
Posted: Sat Mar 05, 2016 7:25 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
VeeDubWolf wrote: |
That engine's a beauty! |
Thanks! I like the look of it. I'm getting the 6V genny re-wound to 12V by an old-school auto-electrician. It means I can keep the original backing plate which is a different stamping to the later 12V ones. 12V Bosch regulator is on its way courtesy of thesamba classifieds.
I've also got some offset Mann oil bath air-cleaners, which ones I use depends on the decklid springs. Either way it will be that period look which is what I'm after. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Rich62ghia Samba Member
Joined: September 01, 2012 Posts: 147 Location: Wollongong, Australia
Posted: Mon Mar 07, 2016 6:42 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Engine looks sweet Angus, Where did you get the carby kit from. Is it period? or did you make it up, where did you source the carby's and linkage from? Do you plan doing any internal work, cam, porting etc. |
Posted: Tue Mar 08, 2016 4:37 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Rich62ghia wrote: |
Hi Rich
Kit design is by Riechert Tuning, http://www.riechertmotorentechnik.de/
I bought the manifolds about 5 years ago in a box of bits and pieces from a guy here in Oz. Never heard of Riechert before, but he made period speed parts back in the day. Still does, but he's pretty old now.
They either used Solex 28PCIs or Solex 32, depending on size of motor. These were intended for 1200 motors, or 1385 with the big bore kits.
I rebuilt this engine as a stock 1200 years ago, and don't really want the cost of a another rebuild on top of all the Resto costs of the car. I'm just going to drive it as is and maybe build a blueprint motor down the track.
The 28PCIs and 010 dizzy I bought restored by a guy in the USA who's name escapes me right now, but is well known for this sort of work. I was going to make a linkage but randomly thought I'd see if Riechert Tuning was still around - turns out they are. Called them and spoke with Berndt Riechert himself, a very helpful man. Bought the correct linkage and air cleaners from him, with a lot of help from a sambanista in Germany, Udo D. Berndt must be pretty old, and the whole thing about posting to Australia was too much, so Udo helped me out.
Happy to help out with more info if you want to do something similar. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Posted: Wed Mar 09, 2016 3:53 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Final metal work on the car! A little reshaping was needed around the headlight to sit properly. First photo you can see a bulge at about the 8:30 mark.
With a little heat shrinking, bulge gone.
And the same on the other side.
Front end done!
Paint is not far away! _________________ 1963 Australian Delivery RHD Coupe
Build thread;
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Mon Mar 14, 2016 7:00 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Well, isn't that just prime(red)! XD
Looking good! _________________ Two Bugs-
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Mar 14, 2016 3:45 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Hi Angus, that is a great milestone. Did the panel beater lead wipe around the welds before primer or is he going to use plastic filler after primer? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
