Old_Ben_Gun Samba Member
Joined: December 18, 2012 Posts: 30 Location: Spanaway Washington
Posted: Mon Aug 18, 2014 6:23 pm Post subject: Rear disc brake Kits |
Im looking for information and an evaluation of the rear disc brake kits. I want to replace the drum brakes with the least amount of down time. Has anyone done the Burley kit ? any recomendations. "Burley Motorsports" I have a 1989 Camper. Just kits noting else. |
insyncro Banned
Posted: Mon Aug 18, 2014 6:31 pm Post subject: |
I've mounted a bunch of Burley's rear kits.
The parts are new and the adapter is perfect.
I do not use the provided spacers for the emergency brake lines and have custom length cables made for a much better brake hold on a Syncro weighing 4500+lbs.
The spacers work well if you do not need to hold the Van on steep inclines offroad. |
m_goerzen Samba Member
Joined: November 29, 2011 Posts: 21 Location: Chilliwack BC
Posted: Mon Aug 18, 2014 6:32 pm Post subject: |
I have Burleys rear disk kit for the last 2 years and wouldn't drive without it. I had it installed by my local mechanic. Easy to maintain and I haven't had any problems with my e brake like other people have. When we came down Snowqumie pass last weekend it nice to know the the van will stop when I want/need it to.
85 weekender. Mike |
Posted: Mon Aug 18, 2014 6:37 pm Post subject: |
Don't expect to see much of any improvement over a set of stock drum brakes in good condition. Either increasing or decreasing the rear braking force will upset the front/rear brake bias and cause worse braking. The reason proportioning valves are added to the rear brakes is to reduce the braking effort of the rear brakes so that you can maintain steering contol during a hard stop. |
insyncro Banned
Posted: Mon Aug 18, 2014 6:55 pm Post subject: |
Since the subject was brought up, with my dual and quad piston calipers in the front and disc conversions in the rear, I use an adjustable brake bias requiring additional plumbing, but really helps dial in braking during various different scenarios.
If the rear kit and front kit are matched, like Burley's, the stock pvalve will do just fine. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Mon Aug 18, 2014 7:59 pm Post subject: |
Personally, I don't think the rear brakes do enough of the braking to justify upgrading to disks (nor do most car manufacturers, who until recently still ran drums or disks with parking drums inside, even on huge SUVs and trucks) but if you are certain you want rear disks I highly recommend Burley's kit. It's impossible to build your own for the time and money involved. I have seen his in person and they are first class.
Burley builds great products and offers exceptional customer support.
Neil2 |
Turk.380 Samba Member
Posted: Tue Aug 19, 2014 8:32 am Post subject: |
I used the SmallCar rear brake kit on my Syncro and have been happy with it. E-Brake holds better than the old drums did in my application, but my drums / backing plates / etc were rusted out really bad. _________________ Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Tue Aug 19, 2014 8:38 am Post subject: |
furrylittleotter wrote: |
Neil2 |
You should know first hand not to believe anyone who says it's impossible
I built my kit with a few hours and less than $200. 276mm vented rear disc brakes that hold on what ever surface the tires will stick to. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Tue Aug 19, 2014 11:09 am Post subject: |
Wildthings wrote: |
You might want to qualify this statement. Brakes stop a vehicle by turning mechanical energy into heat. Disc brakes do a superior job of doing that. So depending on your driving conditions it is quite true that you might not see much of a difference. Running around town going to the store doesn't tax the brake system like mountain or high speed driving. Repeated stops from speed would start to show the difference. The heavier your vehicle the more mechanical energy needs to be converted to heat and the greater the difference.
So like everything else with our vans the answer is, it depends. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Posted: Tue Aug 19, 2014 12:05 pm Post subject: |
hans j wrote: |
I built my kit with a few hours and less than $200. 276mm vented rear disc brakes that hold on what ever surface the tires will stick to. |
You built the entire kit with all new parts and how much did you figure for your time to come up with "Less than $200"
Not being combative, I just honestly do not see how that is even remotely possible. I did the math when I was considering rear disks and my numbers always came up higher than Burley's well thought out kit.
What did I miss? Used parts? Free water cutting (or flame cutting) on the brackets somewhere? Nothing figured in for time?
Neil2 |
ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Tue Aug 19, 2014 12:07 pm Post subject: |
I have the Burley kit on my 2wd full westy and it will hold solid on my steep driveway. I would but it again in a heartbeat… even for my heavy syncro doka (5000#). _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka |
hans j Samba Member
Posted: Tue Aug 19, 2014 12:22 pm Post subject: |
hans j wrote: |
Neil2 |
Nope, used parts, I never said mine was brand new. You didn't use new parts on your subaru a/c install right?
Cut out my own brackets and welded them to the wheel bearing housing, used B5S4 rear calipers, good used URS6 276x25mm rotors and barely used brake pads I found laying around the shop (probably squeaked on a customer car) and I bought brand new park brake cables from a Mk4 VW. It's all in my thread I think...
No, I don't account for time spent on it. If I did, the labor I have spent doing everything on my van would be near $100,000 (1,000 hours at let's say $100 hour shop rate?) I would probably sell it for that if someone was dumb enough to pay for it!
But again, as you know, most of the time you don't get your own labor out of what you put into it. You do it for fun. You do it to save money. You do it because you love it. I only did rear discs because I could and because all my stuff was so rusted away I didn't want to pull stuff off parts vans to swap over. My new van will retain rebuilt stock drum brakes _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Zeitgeist 13 Samba Member
Posted: Tue Aug 19, 2014 2:04 pm Post subject: |
I don't expect a performance boost from a rear disc swap, since the rears aren't doing much stopping anyway. What I expect is simplicity of maintenance...and of course the visual bling that accompanies such an endeavor. I loathe working on drum brakes, and they just plain look old fashioned and clunky. Obviously my priorities are all effed up _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16510 Location: Brookeville, MD
Posted: Tue Aug 19, 2014 2:22 pm Post subject: |
Zeitgeist 13 wrote: |
I don't expect a performance boost from a rear disc swap, since the rears aren't doing much stopping anyway. What I expect is simplicity of maintenance...and of course the visual bling that accompanies such an endeavor. I loathe working on drum brakes, and they just plain look old fashioned and clunky. Obviously my priorities are all effed up |
Mine too. _________________ Dave O
The Western Syncro build
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Aug 19, 2014 3:30 pm Post subject: |
dobryan wrote: |
Mine too. |
Mine three... heh..
A while back I swapped out drum brakes for disks on my sailboat trailer. The difference in brake control around town was night and day, better.
And on long hauls it took considerable pushing of the tow vehicle out of the equation.
Disks are on my list for the van..
And Burley's current kit is no. 1 on the list.. unless he develops his next generation kit.. then that will be no. 1 on the list.
My understanding of disks on the rear is that if you drive long grades all loaded up they will work considerably better than the drum.
They shed heat far better which takes pressure off the front brakes.. and biasing can be dialed in manually if you are up for that... by adding a manual biasing valve. No biggy... right? _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Tue Aug 19, 2014 7:14 pm Post subject: |
X4
unknownhell Samba Member
Posted: Tue Jul 26, 2016 8:34 am Post subject: Re: Rear disc brake Kits |
hi
what length stud I need for the rear brakes kit for my Vanagon syncro?
thanks |
