klcarrie Samba Member
Posted: Mon Aug 04, 2014 4:54 pm Post subject: How to remove those 60 year old mangled door hinge screws? |
So, off and on I've posted deconstruction photos from my 55 Commercial 'Snappy' that I am working towards 'rusturection'...
Before getting into bodywork, I've left what I think are amongst the worst mechanical issues for last and those are the front door hinge screws.
After soaking for over a year, periodically applying a liberal amount of acetone/oil mixture, I took to it yesterday to remove my doors from the bus.
I was able to successfully remove the left side door:
The lower hinge pin (211831421) was an easy drift out. I was able to remove the 4 upper Countersunk Raised Head Screws (N142892) by pounding the appropriate Phillips Socket into the screws' slots and using a breaker bar to break loose the screws.
LH Upper A -- Successfully removed the bolts - gonna need to replace the A Pillar though
I was unsuccessful in removing the other screws. Pics follow:
LH lower -- Sheared one bolt while removing it... other three are rusted in.
RH upper A - Rusted
RH lower A - Rusted
RH upper - Hinge Rusted 211831421B
I am attempting to refrain from heating/welding so as not to distemper any of the hinge (211831401, 405, 411, 412) metal.
What opinions do you have as to removal of these Rusted and distorted Screws.
Also, Any advice on removing the rusted mirror hinge pins (211831421B)?
Thanks,
Kevin _________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy |
tubdub Samba Member
Posted: Mon Aug 04, 2014 5:54 pm Post subject: |
check with Eric at Nor Cal Relics. he can point you to a tool that works good |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10199 Location: Petaluma, CA
CaLiBus Samba Member
Posted: Mon Aug 04, 2014 6:10 pm Post subject: |
HEAT HEAT HEAT till red hot. Sorry but that always does the trick for 50 plus years of old screws and hinge pins. Never had any issues putting heat to hinges and phillip screws on my 55.
Cut off the remaining mirror arm, use a center punch and support the hing with a 2x4.
A torch is your best friend when you have something this old. You have more old screws then just doors waiting for you. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Aug 04, 2014 10:09 pm Post subject: |
I, too, use the tool that fits on an air chisel. It works good with the vibration. Mine is a Snap-on that I bought out of one of their tool trucks for about $40, years ago. It is one of those tools that people should have in their tool boxes. _________________ Don't worry; be happy. (Baba) |
dawerks Samba Member
Posted: Mon Aug 04, 2014 10:50 pm Post subject: |
I know you don't want to weld but... I use KCW's trick, weld a bolt onto them. The heat + bolt is 100% success and if you use a heat sink there's 0% chance of messing up anything else.
If anything the hinges are already shot from 40+ years of no use _________________ "There is only one sin; disconnection from self." |
quartermilecamel Samba Member
Posted: Tue Aug 05, 2014 12:40 am Post subject: |
I know what WILL remove those screws. Weld a bolt to those screw heads. Then you will have a hex head to work with. Welding a bolt is much more accurate way of concentrating the heat. You cant contain the heat of a torch as well as the "bolt weld" method. I x2 and x3 the bolt method. Used it many times. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Tue Aug 05, 2014 2:07 am Post subject: |
I can't believe that's only 40 miles from my house
But how does it work? I've never seen a tool like this used _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
Posted: Tue Aug 05, 2014 5:49 am Post subject: |
BUGTHUG wrote: |
I can't believe that's only 40 miles from my house :D
But how does it work? I've never seen a tool like this used |
The handle mounts on an air chisel and the impact bit mounts on the end. While you squeeze the trigger on the chisel you slowly work the handle left or right to break it free. Buy one - without a doubt it's the best tool for this job. |
Clara Samba Member
Posted: Tue Aug 05, 2014 6:22 am Post subject: |
campingbox wrote: |
BUGTHUG wrote: |
What tool are you using now? Just a screw driver is not going to work unless you are really lucky.
If you don't have air, one of the whack them on the end impact driver tools works.
I would definitely use that before getting out the torch. |
Posted: Tue Aug 05, 2014 6:32 am Post subject: |
campingbox wrote: |
BUGTHUG wrote: |
I'm going up there in a few days, the outdoor store is a place to spend most of the day. They get a lot of their supply from the aircraft co.'s, they have about 10 Quonset huts full of sheets of aluminum, and slabs. Part of the store inside is like a Army/Navy surplus store, lots of weird do-hickeys.
I don't know if you seen their sticker, it says "I love the smell of jet fuel in the morning" If you want a sticker, send me a e-mail with your address and I'll send you a couple. _________________ I know you would understand what I'm saying if you could just see my HANDS
1963 15 window bus
1966 VW bug
1969 Dune Buggy
1965 VW bug
1974 VW bug
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Tue Aug 05, 2014 7:37 am Post subject: |
You can always just drill them out.take about a minute per screw. |
Posted: Tue Aug 05, 2014 9:33 am Post subject: |
Clara wrote: |
I was not using a screw driver.
The goto method will be to acquire a 4" Old Man, and apply it to my air chissel... Thanks Greg. Now I have to find if Snap-On in Canada has an OLD-MAN or get one shipped to Canada, or my favourite border address.
If that doesn't work, then I will probably have to resort to welding the nut onto the screws' heads.
Thanks,
'71 Westy |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24766 Location: Olympia Wash Rinse & Repeat
Posted: Tue Aug 05, 2014 10:08 am Post subject: |
RPGreg2600 wrote: |
Not for a novice.
Even for the experienced it takes much longer than a minute.
Start with 1/8" drill bit. Cobalt ones are real nice to have. Once thru with that you go up a size or two in drill bits and drill out the hole bigger and at same time can adjust how centered your hole is drilled.
If perfectly centered and perfectly straight you will see the spiral of the threads appear and use a scribe to work out the now spring like remains of the fastener. If off to one side you now have a crescent shape of bolt left that will require using a punch to pry out the chunk of fastener. Either way best to use a thread chaser to reform and damaged threads. Taps tend to just remove any mushed up threads making them thinner/weaker. Above all if using a tap, make sure it is not an over sized one!! A good quality HSS (High Speed Steel) tap will have marking like H1 or L1 if bigger or smaller than nominal. H= Larger diameter, L= smaller diameter, and 1 = 1/10,000" bigger or smaller. So a H3 will be 3/10,000 bigger and loose so fastener can be finger spun into the threads.
If one must drill use LH drill bits. More often than not with vibration and heat from friction the threaded chunk will just come out with the drill due to rotating CCwise.
Agree though that welding to the fastener head and quickly water cooling works fine/easier. With less chance of thread damage and will not change temper the hinge. _________________ In Stereo, Where Available! |
velvetgreen Samba Member
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Tue Aug 05, 2014 1:04 pm Post subject: |
The tool Mr. Campingbox suggested with an air chisel is tits for this kind of job.
Before I fashioned myself something similar but much cruder, I had about a half dozen gate hinge screws on my SC that were in snug enough that the heads on the screws stripped while attempting extraction
The screws are made from a pretty soft alloy, so they strip easy, but also drill out easy.
I drilled a small hole through the middle (the stripped Phillips centres the bit nicely). Drilled the hole all the way through.
Then aimed the sharp blue flame of my micro torch in the little hole. This has the great advantage of heating up the screw much faster than the surrounding area so you get the expansion differential that weakens the corrosion bond on the threads
While it was still good and HOT, I used an Easy Out to turn out the screws.
I know, I know, I don't like relying on Easy Outs either, BUT, they do have their place in the tool box for specific applications.
I found this to be one of them, as the screws were surprisingly easy to turn out good and hot.
I only had one that was really stubborn and I was not about to apply the amount of torque that would come close to breaking the Easy Out (having performed that miracle in the past), so I had to drill out one screw entirely.
It was somewhat tedious, but no more so than a hundred other tedious jobs required on these rusted relics. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Campy Samba Member
Posted: Tue Aug 05, 2014 6:49 pm Post subject: |
Buy the tool and try it first before using any of the other methods. As I noted earlier, everyone should have one in his tool box. The end is like the end of an impact driver that you hit with a sledge hammer. You can change bits in it.
Years ago, I was able to remove all but one small phillips screw from the hinge carrier of my 1957 bus. That last screw was stuck and the center of the screw had gotten pretty rounded. I thought that I would have to drill it out in order to remove the engine door hinge. I bought the tool from Snap-On, put it on my air chisel, and it removed the screw. _________________ Don't worry; be happy. (Baba) |
Posted: Tue Aug 05, 2014 8:53 pm Post subject: |
Its an extreme PITA to find specialty tool suppliers in Canada.
In Edmonton, I am 500 miles from the US border, but in the heart of Oil and Gas fabrication country. Can't find the old man to save my life. What gives?
Snap-On doesn't show it in the catalogue, nor does Mac Tools. The little guy specialty houses also don't show the tools in their extractor kits.
So, I have a 3/8" Drive 4" Old Man on order from a supplier on Amazon.
I sent it to my US address at Montana Shipping Outlet. I tend to make a few trips down a year for items as I hate to unnecessarily forward Government(s) duty and taxes not explicitly determined prior to purchase.
The T-handle 8mm box nut tool I bought from Samestagsales was levied with a 100% duty. Not happy about paying over $50 for an 18$ tool.
I recently bought a Kukkos 6304-5-6 puller set, a Rilex 6305 puller, a 24mm reamer and a Jogr Drift that I waited 4 months to pick up. But they were worth it. Smooth as butter bearing extractions and bushing drifts. Easy on the wallet. Free from randomized levy.
6305 in Action...
So I'll revive this thread once I get the tool and give my screws a whack!
I digress.
'71 Westy |
Posted: Wed Aug 13, 2014 8:56 pm Post subject: |
Well I didn't pick up the knocker yet, but due to some impatience on behalf of Pete, I (we) was able to get the screws out.
It took:
Heat, but we still broke screws. We then ground the boss of M8 vinyl nuts and mig'ed them to two of the remnant studs; Worked better than drilling out and tapping a third broken stud
When I get it, I Will update as to using the knocker on some other, less critical door glass frames and maybe on some door hinge screws from my Single Cab.
Thanks Pete...
Wheelie Pete wrote: |
I kept driving down the Alaskan highway backs towards Edmonton.
Everything became flat
Frankie wasnt having it
Traffic picked up, lanes widened
a few nice bridges
then downtown Edmonton
and back to Kevin's house!
Spent a day washing the bus, and helping Kevin on his bus. Since I left he took the front door off, and I offered him a hand welding his bus up and getting the door back on
His bus could be a candidate for Gerson doglegs, front clip, rockers, and what not, but there was a decent collision on this bus, and one panel replacement would quickly escalate into another panel, and another,.....
so we decided to fix what was there,
first was cracked a-pillar / hinge area
so I performed a little welding and grinding and it soon looked like the rest
next was the dog leg. I was able to cut out the rust, but that's where we stopped for the day
There were a 3 broken door screws, so we welded nuts to them and took them out. Soon a spare front door was on. Looks better already!
Tomorrow I'll head towards Calgary, visit Concept 1, and visit Mr. RiffRaff.
Next, I'll head south to Montana, and maybe visit Thermopolis, and maybe Jewel cave.
or I was thinking about driving through oil country in North dakota, via US 2. Haven't decided yet! |
'71 Westy |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Wed Aug 20, 2014 3:40 am Post subject: |
I just used this knocker on my front doors for the first time yesterday and it work incredibly well. I was dreading taking the doors off but it took about 3 minutes for each door and the screws are intact. wow. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
