911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sun Aug 24, 2014 10:45 am Post subject: |
Yes, photos when you get them mounted and installed. |
subgraphic Samba Member
Joined: January 02, 2004 Posts: 141 Location: San Diego, CA
Posted: Fri Sep 12, 2014 10:00 pm Post subject: |
Just bought a set for my '63
Posted: Fri Sep 19, 2014 7:06 pm Post subject: |
I was thinking about running 155/60r15 and 175/65r15 smart car tires on the new wheels.
I have a 2" narrowed beam, on adjusters, stock spindles and brakes. Very minor spline adjustment in back, the PO did it. Not low at all.
Short axels in the rear.
The wheels are 5.5 wide with BACKSPACING 3.80INCH ET+14
I'm REALLY ignorant about backspacing and what sizes are good. I'd like to get as wide of a tire under there as I can. Any opinions about the sizes I listed?
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Fri Sep 19, 2014 7:41 pm Post subject: |
you don't need tires ANYWHERE NEAR THAT SMALL with your set up. 165/60/15 front and 185/65/15 rear. you could even go with a 195 or maybe even 205/65/15 out back hard to say without pics. _________________ ITMC
Secret Service |
Posted: Fri Sep 19, 2014 8:03 pm Post subject: |
luckystiff wrote: |
you don't need tires ANYWHERE NEAR THAT SMALL with your set up. 165/60/15 front and 185/65/15 rear. you could even go with a 195 or maybe even 205/65/15 out back hard to say without pics. |
This is the kinda stuff I was hopping to hear, thank you! |
Posted: Fri Sep 19, 2014 8:34 pm Post subject: |
It's interesting that the ET of the 5x130 bolt patterned wheel is +35. |
Posted: Sat Sep 20, 2014 8:39 am Post subject: |
911pickup wrote: |
getting more "middle of the road" with consideration for the cars that came in that pattern most likely since they would have been closer to the +40range. _________________ ITMC
Secret Service |
Posted: Sun Oct 05, 2014 7:01 pm Post subject: |
Well, hit a few snags today- got the tires mounted and on the rear, but the studs for the front, that I ordered with the wheels, are a bit too long and are blinding/hitting the brakes. The stock studs are too short.
I'm not sure what to do- I don't have anyway to cut them.
Uggh |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11057 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Oct 06, 2014 5:30 am Post subject: |
subgraphic wrote: |
Uggh |
Install the studs... use a grinder to remove the excess from the inside.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Mon Oct 06, 2014 8:33 am Post subject: |
Are they studs or lug bolts? Either than be shortened with a grinder. If you taper the end a little with the grinder they will thread in easier. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Oct 06, 2014 6:31 pm Post subject: |
Looks like I'll need to go get a grinder. Thanks guys! |
Quickbms Samba Member
Posted: Sat Oct 11, 2014 2:25 pm Post subject: |
So Im ready to order a set,is there any problems with fitment with drop spindles and disk brakes in 4x130? Ive only seen pics of these on one car and it didnt look lowered.Any input? |
Posted: Sat Oct 18, 2014 11:49 am Post subject: |
Just put them on. No fitment issues for ball joint narrowed beam with airkewld drop spindles. |
Posted: Sat Oct 18, 2014 6:24 pm Post subject: |
So I got them on the car. No fitment issues at all. 6 inch narrowed beam airkewld drop spindles and disk brakes. |
Posted: Sun Oct 19, 2014 5:09 am Post subject: |
^ Nice.. but...may I ask why you opted for 4 lug on a "early look" car...
The wheels look good.. and out of place at the same time
Not knockin' just askin'...
Posted: Sun Oct 19, 2014 2:31 pm Post subject: |
The cost to swap it to 5 lug was more than I wanted to spend. I would have had to buy new drop spindles,plus a all new front disk brake set up and new rear drums. I talked with airkewld and he said it was my only option because of the front disk brakes and their drop spindles. |
Posted: Mon Oct 20, 2014 5:23 pm Post subject: |
Quickbms, very nice! |
tikitime Samba Member
Joined: December 12, 2006 Posts: 443 Location: New Westminster, BC, Canada
Posted: Tue Oct 21, 2014 10:37 am Post subject: |
tikitime wrote: |
VOLKSWAGNUT wrote: |
And I thought the purists were bad enough here. |
Pfff...Yeah.. right like Im a Purist....
My signatures.. pretty much sum it all up for me..
Nah... its just my OCD ADHD. . couldn't stand for 4 lugs on an old VW....
That being said.. even in 4 lug... they are the best looking 4 lug rims out there.. IMO.
They provide a good 5 lug illusion with the 5 spokes and 5 slots
and....I proudly display my thoughts!
Im all about your car do what YOU like..
Then drive the shitoutta it..
Posted: Thu Oct 30, 2014 7:12 pm Post subject: |
Forgot to post up
An angle grinder made short work of the bolts, so I have them on now.
I'm VERY happy with them.
