GArBa Samba Member
Joined: January 27, 2014 Posts: 2108 Location: Milano, Italy
Posted: Mon Mar 11, 2024 11:04 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Brazilian rear plates were (I think they still are) installed on the car by the equivalent of the DMV with a metal wire and seal to prevent theft/plate swaps. The holes are for the wire to pass through. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
glassbuggy Samba Member
Posted: Mon Mar 11, 2024 3:27 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Did a little searching after your reveal. Perhaps the lower hole is for the taller plate or bracket for taller plate? |
Posted: Tue Mar 12, 2024 4:17 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Are there any Brazilian connections on here? I need a correct license plate light. |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sat Mar 30, 2024 11:57 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Having an electrical issue with my 1985 Mexican Jubilee Bug. I'm thinking either ignition switch or turn signal stick related. When I start her up often neither the oil or gen lights come on, just the brake warning light. When I move off that goes out and the gen light comes on. I have no turn signals. Sometimes the 2 warning light are on, and I have turn signals, but as soon as I use the turn signal the gen light comes on and they stop. I can see the turn signal light in the speedo flashing faintly and the fuel gauge also drops. Otherwise the car runs fine. Stumped. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2485 Location: Ottawa, Ontario
Posted: Sun Mar 31, 2024 4:36 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
alikatcraig wrote: |
Having an electrical issue with my 1985 Mexican Jubilee Bug. I'm thinking either ignition switch or turn signal stick related. When I start her up often neither the oil or gen lights come on, just the brake warning light. When I move off that goes out and the gen light comes on. I have no turn signals. Sometimes the 2 warning light are on, and I have turn signals, but as soon as I use the turn signal the gen light comes on and they stop. I can see the turn signal light in the speedo flashing faintly and the fuel gauge also drops. Otherwise the car runs fine. Stumped. |
Weird, it sure sounds like a short somewhere. There are some wiring diagrams on www.1600i.de, they should help you trace the wiring. If intermittent, it sounds like some frayed wires somewhere. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
GArBa Samba Member
Posted: Tue Apr 02, 2024 5:24 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
a 1985 would be wired largely as a 1978 german model, but the wiring of the warning lights is pretty much the same as a 1600i. IMHO The issues sound like the base plate of the main warning bulbs is shorted to ground. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
hopkin Samba Member
Posted: Sun Apr 07, 2024 4:50 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Drove 6 hours yesterday to see the eclipse at my sister's farm in SW Ontario. Left Ottawa with snow on the ground, grass is green here.
No crowds here, I'll try to a pic of my car during totality!
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
hopkin Samba Member
Posted: Tue Apr 09, 2024 4:06 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Worth the 6 hour drive, clouds cleared 1/2 hour before totality .
Here's a few of many pics. The last pic is also during totality, the glow at the horizon can be seen 360 degrees around us.
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 832 Location: San Juan Islands
Posted: Wed Apr 10, 2024 1:04 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Sounds like a fun road trip!
Awesome picture of the Bug with the eclipse in the background. Over here on the left coast, less than 20% so nothing to see. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Apr 11, 2024 8:46 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
My 2003 1600i fuel pump has started making a "racket" the past few months. It's getting louder over time so I'm assuming it's getting ready to fail.
It's a replacement pump, probably 5-6 years ago?
Ordered a new pump on EvilBay ($30 GMB brand?).
https://www.ebay.com/itm/174074397010
Now I'm wondering if I made a mistake? Is there an actual VW pump still available? Shoot, maybe should have reached out to Antonio? _________________ When I set my timing, why do I flush, then take a pee? |
hopkin Samba Member
Posted: Thu Apr 11, 2024 9:49 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
Now I'm wondering if I made a mistake? Is there an actual VW pump still available? Shoot, maybe should have reached out to Antonio? |
I've read that it is hit and miss with the cheap Chinese fuel pumps, I'm not sure if OEM ones are still available, you'd have to reach out to Antonio.
Failing that, it may be possible to rebuild the Chinese one with a better quality pump portion. I have both a (new) OEM replacement and an unused Chinese one (that was given to me).
This is what my Chinese fuel looks like disassembled, you can see the pump portion:
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Thu Apr 11, 2024 10:49 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
That's really interesting, I'll keep the pump that's in the Bug for sure. I'll swap the units and hopefully this one is quieter. I thought maybe the rubber bushings had failed until I put my hand on the pump while the Bug was running. The pump was shaking like crazy. Certain the pump itself is about to fail.
Thanks for the pictures! Didn't realize you could take the unit apart like that. _________________ When I set my timing, why do I flush, then take a pee? |
hopkin Samba Member
Posted: Fri Apr 12, 2024 4:27 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
... The pump was shaking like crazy. Certain the pump itself is about to fail.
Hmm, makes me wonder if one of the plastic portions cracked, like the screened piece (rather that the electric pump itself failing). When you you disassemble maybe have a look and let us know. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
colinobe Samba Member
Posted: Tue Apr 16, 2024 2:39 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Antonio Trejo wrote: |
mf1274 wrote: |
I contacted Antonio and waiting for him to contact me back to ask if he can get looms, |
My team is searching right now those genuine VW Sedan 1600i looms. |
Posted: Tue Apr 16, 2024 2:42 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
mf1274 wrote: |
hopkin Samba Member
Posted: Tue Apr 16, 2024 4:01 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Just when I thought it would be hard to top the eclipse picture. I took these yesterday:
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Tue Apr 16, 2024 5:21 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Wow, perfect timing! Great photo! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
Posted: Thu Apr 18, 2024 7:35 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Swapped out the fuel pump last night and what a difference. Can't hear it anymore. The old one really made a racket, while idling it was very loud. This happened over time, would say 6+ months slowly getting louder.
Took the old unit apart and couldn't see anything broken. Figuring it was just the pump getting ready to fail.
Posted: Thu Apr 18, 2024 7:38 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Going to keep the old unit. Wonder if you could buy just the pump?
Strainer had a small amount of gunk, but nothing to make me think it would have made the pump fail.
aquavette Samba Member
Joined: May 30, 2007 Posts: 178 Location: Argyle, TX.
Posted: Sun Apr 21, 2024 12:25 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Open question.
How does the transaxle gearing of a 1996 Mexican beetle, compare to a US spec 1968 beetle?
Thx. |
