Brent Samba Member
Joined: April 28, 2010 Posts: 1617 Location: San Tan Valley, AZ
Posted: Mon Jul 18, 2016 9:03 am Post subject: Re: Black Fastback Build Thread |
Clatter wrote: |
Once the 163/86b (?) comes in, the bottom end should be ready to go together on the 2270.
Because I'll need the 2.0 914 plug angle for the DCNF linkage to work,
Those nice 2.0 heads I was planning on using on the 2270 will have to go on the 2056.
Hoping that it won't be a 'waste' of them to use them on the 2056.
What with the heat exchangers and 'mere' 494 cam..
The cylinders on the 2056 will have to be chopped down to get the deck right using the 2.0 914 heads,
And Bob had a stroke,
So it's kind of scary having him chop them down now.
His edge ain't as keen as it once was, dig?
Just China AA, but still...
Anyways,
That means I'm going to take one or three sets of these head cores and do one up with big valves.
Still 2270/96 bore, so maybe 44x36? 44x38?
The 96 cylinder might shroud the flow enough to diminishing returns vs. 42x36.
Heavier valves also float easier..
Was going to try and copy Jake's 'Torquer' and use a 163/86b and 42x36,
But,
having a huge exhaust makes me want to go big.
Especially with revs.
Maybe get a 1 5/8 to 1 3/4 step header?
MS was willing to come by when the 2270 goes together.
Can't wait!
He was saying how he's all about retarding the cam a few degrees to make more power upstairs.
With a set of those adjustable straight-cuts different settings are infinite.
My mind has been wanting that 2270 to spin hard!
Now I'm sitting on the fence with cutting for dual springs and a Web 494..
I think I'm gonna do it.
Gene Berg is whispering in my ear from the grave..!
Anyhow,
Bla bla bla..
If any one out there took the time to read this, (and can even understand it) and has anything to add, please chime in...!
WWND ... What Would Nate Do?? |
I have a 163/86b in my stash for my future project. I'm kind of leaning towards a 86b/86c though. Want to keep the 96 bore... yeah, WWND? _________________ 69 Fastback Build
Berg5 Build |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7561 Location: Santa Cruz
Brent Samba Member
Posted: Wed Jul 20, 2016 8:06 am Post subject: Re: Black Fastback Build Thread |
Nice. But going from 96 to 98 seems like a huge increase in cost. 98mm Nickies are $3500!
I wonder why people always increase intake and exhaust to 44x38. Why not 46x38? I seem to remember a post somewhere about exhaust valve sizing and what 36mm exhaust valves could handle. _________________ 69 Fastback Build
Berg5 Build |
Posted: Wed Jul 20, 2016 4:53 pm Post subject: Re: Black Fastback Build Thread |
Brent wrote: |
I wonder why people always increase intake and exhaust to 44x38. Why not 46x38? I seem to remember a post somewhere about exhaust valve sizing and what 36mm exhaust valves could handle. |
48x38 was always the traditional big valve set-up back in the day;
FAT and MS and EMW..
That was with 103s, tho.
Wally's set-up uses huge valves with only 98s.
Makes me wonder about the whole "cylinder wall shrouding theory"...
Anyhow,
A massive cleanup effort of Clatter World Headquarters has been started.
The Mother of All Mock-Ups has begun..!
_________________ Bus Motor Build
What’s That Noise?!? |
Posted: Fri Jul 22, 2016 11:41 pm Post subject: Inspiration Comes in Many Forms |
It's Friday night, And I'm feelin' alright!
Inspiration takes many forms.
This right here - have to stare at it sometimes,
Just to remind myself what that rusting hulk in my backyard really is.
The colors are right and everything..
Anyhow,
-Almost five hours-
Sketch-ball Flip-it-over, take-it-off-the-cart, roll-it-forward, solo style:
Forgot about these carts of parts!
I _knew_ I cut that bus up for something..!
Open-ended lug nuts let me fit my wheels prior to spacers/trimming, etc. that always seems to go with P-car wheels..
Also verified my torsions fit!
The camber adjuster bolts clear the sub! Lucked out..
(Yes, Alice, I know my backing plate over there is clocked wrong. This is just a mock-up)
No, Trudy, there is no chance these will fit under the fenderwells.. Fun to stare at and drink!
They clear the snubber plate and adjustment bolts, tho, barely..
And that's kind of cool, huh? Right?
Stab the trans, down off of the stands..
Set the rear to drag ass a bit to check clearances.
(And for inspiration - how cool would it be if it set like that.. )
Here's the kind of things mock-up uncovers:
Those brake line brackets seem too close together..
IRS cars have them further in towards the center of the car, huh?
Also, that spring-plate-to-trailing-arm bolt is going to foul the sub-frame at full compression.. Needs a notch.
Hope I can get a fitting to clear those tie rods...
Anyhow,
With any luck I'll get another day, and maybe even some help!
Feeling Inspired! _________________ Bus Motor Build
Posted: Sat Jul 23, 2016 8:53 pm Post subject: A Whole Day! With Help! |
Mom let me have a whole day!
Like 8-10 or so hours...
Here's the factory fuel outlets - for reference.
Anyhow, first thing this morning:
Before:
After:
My new friend Mike came over.
Mom can't find it in her heart to stop us,
What with TWO of us flailing away,
And one being a guy who it's not even his car...
This guy is an ANIMAL!
We got the body on the pan,
The car in the air,
And the holes moved over so all the bolts started.
Every pan-to-body bolt went in...
After that, all of the body panels went on.
The beam and wheels and all came off to make room for the clip.
I didn't take pics, what with being busy (and stoked).
Once we got the panels on, with the clip, things were a bit odd.
It finally came to me; the slab is all crooked.
(The concrete slab the car sits on)
When the car sits directly on solid stands, on a crooked slab, the car ends up crooked.
So I decided to put the car back on it's wheels.
The car's suspension will soak up/level out any concrete imperfections.
That way we can get everything aligned right.
We had to get out the angle protractor and set the rear spring plates equal,
(PITA), and re-hang the beam, wheels, clip, etc.
Mike didn't even flinch, and did it just like that..
So after getting the suspension re-hung,
And the body panels re-hung,
The car sat on the wheels, on the slab, on the final pan and suspension.
Everything made sense... The gaps acted like they were supposed to.
At that point we were tired, and it was late.
Reminds me of that 'Winter's Tale' Fastback with the rear wheels all poking out like that..
So, it was a flail - Two mock ups, really- with the re-work from my mental slowness; Mike works too fast for my brain.
One on stands, one on the wheels.
Still, tho, ready to go..
If I can get the panels to line up, that clip is getting tacked on!
After some rest, and staring/scratching/adjusting/measuring, seems that we might just be able to weld that mudder fusking clip down fo reals!!!
Big thanks to Mike for BUSTING HIS ASS all day long.
Mike - I owe you one! _________________ Bus Motor Build
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Sun Jul 24, 2016 9:06 am Post subject: Re: Black Fastback Build Thread |
Looks great. I think you could kidnap Mike for a couple of days and you would be finished this build. _________________ I think he meant "rare", as in "not well-done" |
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Sun Jul 24, 2016 12:05 pm Post subject: Re: Black Fastback Build Thread |
Now that's a mock-up!! Looking good Clatter!! _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22438 Location: Kimball, Mi
Posted: Tue Jul 26, 2016 9:50 am Post subject: Re: A Whole Day! With Help! |
Clatter wrote: |
Big thanks to Mike for BUSTING HIS ASS all day long. |
Now THAT is the mock up we've ALL been waiting to see. I love that rear shot, as it shows how far you've come with it. Looks like you're going to need Mike to come over a few more times, as he'll help you bust that job out.
It won't be long now before the front clip is in place, and welded up. Great job guys. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
Posted: Thu Jul 28, 2016 12:41 pm Post subject: Re: Black Fastback Build Thread |
Oh, I hope page 67 breaks the magic juju that lingers...
This car is cursed!
The last few days I have been trying to figure out why the clip won't fit!!!
Can only do so much off/on/off/on with that front clip before I snap!!
:snipersmile: :2gunfire: :fist: :2gunfire:
Check out Mike's convertible Falcon.. It's a stick!
This is my "life"..
The front lower mounts of the clip won't go on the Left side only.
Right side 'fits' (kinda)..
Clip won't go back...?
Left side won't move rearward to close this gap!?!?
WTF?
Checking with my 'trammel bar' to see if the front bulkhead is crooked.
(using the floor-pan I welded on - it's suspect)
Shock tower mount eye to rear bulkhead (Something I never messed with) looks OK.
Rear bulkhead to front firewall face is a bit off from L to R..
Maybe have to push the front firewall around a bit.
The whole thing must have gotten made crooked somewhere along the line..?
It's still not making any sense..
Sucks.
Buy rusty not wrecked! _________________ Bus Motor Build
Posted: Sat Aug 06, 2016 9:07 am Post subject: Re: World's Longest Build Thread |
The World's Longest Build Thread Continues..
I still haven't been banned from here for wasting space with this!
So here you go.. A complicated story of a very crooked car...
Might as well skip this, it will take too long to even read.
"Danger seldom approaches without exciting a nerve ending somewhere"
-Ian Fleming's James Bond
The front of the pan seems like it's bending down?
This gap opens up as it runs forward to the firewall.
I was just snugging it down and bringing it together.
Measuring the tunnel and pan shows that it's NOT 'curving down'.
The front of the body is 'curving up'???
Hhhmmm....
Something is just wrong.
I don't know what.
Time to strip it all down and swap pans again to see.
(Thanks again, Mike)
Here it sits on the OG pan while I think and drink.
Problem goes away entirely when I put it back on the roller pan.
WTF?
(And where do these kids get off thinking they can just fix things like a broken Nerf gun, anyways?)
Then it came to me!
Eureka!
The edges of the pan, outboard where the heater channels attach, are too high!
It's folded upward at the edges like a taco.
Since the final pan was sitting here as a roller, I just jumped up and down on it,
And it seemed to come right into line.
I threw the body back on the final pan, (thanks again Mike),
and no more 'curving'!!
Plus,
The seat track issue went away!
Things are making sense again!!
WhooHoo!!!
No more interference!
So,
Over the next few days after work,
I test-fitted the front clip a couple dozen umpteen times.
Finally just decided to open up this flange a bit to allow the clip to come back.
The firewall is a smidge too far forward,
But I'm at a loss as to how to bring it back.
So,
Fuggit.
Now it comes back into place.
POS!
See how bent up everything gets, with all of these tweaks and test-fits?
Started sheet-metal-screwing things into place last night after work;
The easy side came right in like it should.
The hard side did, too!
Check out how mangled everything gets from 500 on/off test-fit sessions..
(Actually it's only like 150 - I exaggerate..)
Easy side top corner sections fell right into place...
Even the hard side came into line..
Gaps all around looking good...
Can't believe it.. Can't believe it...
Set me back a year..!
Could it be possible that I will never, ever, have to pick that front clip up and move it again???
Impossible....
Notch Samba Member
Posted: Sat Aug 06, 2016 12:16 pm Post subject: Re: Black Fastback Build Thread |
Well that is so awesome. So glad you have been willing to keep moving forward on this project. Many lesser men would have quit.
YOU ARE DA MAN!!!!
Doug _________________ '64 Notchback
'67 Bug
(sunroofs both)
1964 Lavey Craft, Flatbottom V-Drive, 406 Ford |
Posted: Sat Aug 06, 2016 6:54 pm Post subject: Re: Black Fastback Build Thread |
I see a LOT of welding in the coming weeks. . . Good Job!! _________________ Regards,
Nate M.
Squarsche build
Posted: Sat Aug 06, 2016 8:27 pm Post subject: Re: Black Fastback Build Thread |
Thanks for following along, guys.
Props really help!
Trynna get to page '67..
Today was Saturday,
And Mom worked,
But I was kinda fried, what after last night and all...
Did a few things:
First of all,
I tacked the seat tracks into place.
That felt good!
Didn't get a pic. Too stoked.
That seat track issue had me in a funk!
Then,
That cut in the middle of the "B" pillar didn't make sense.
Hard side door opening was too small. Door didn't fit; Gap wrong.
Made a bunch of measured 6-inch increments along the rocker,
And measured with the trammel bar..
In order to open the gap like it needs,
A hoist comes in handy.
All of those clamps and blocks were used to align it all.
Scabbed in a bunch of little strips to fill the cut.
Too windy to finish-weld,
But I got the number there, dig?
And it didn't mess up my gaps at the front clip!
Killed some time - test-fit fuel tank and spare tire bowl.
Also dug out some spare motor parts.
Going to build up a mock-up motor for tin fits using 914 2.0 heads.
Need to work-up the 411/412 heaters and header..
All in all, not the best day, but got a few things done.
Can only mess with that front clip so much at a time..
For some reason..
Progress is progress! _________________ Bus Motor Build
Posted: Sat Aug 06, 2016 9:50 pm Post subject: Re: Black Fastback Build Thread |
Nate M. wrote: |
I see a LOT of welding in the coming weeks. . . Good Job!! |
Agreed. I too see lots of welding in the coming weeks. Great job Steve. Way to stick to it, and find the problems and FIX them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sat Aug 13, 2016 1:41 pm Post subject: Re: Black Fastback Build Thread |
Thanks for all the props, guys.
It really means a lot!
Back in the old days, guys used to Go It Alone..
So,
I did a few things..
Last weekend Mike helped me assemble a mock-up motor.
Still need to trim tins,
Figure out the dipstick tube,
Test-fit exhaust.
And that's about it!
Welding the front clip on started. (WhooHoo!!! )
Damn wind kept shutting me down.
See boogery blobs next to calm-air shiny/flat welds..
I said something about this before, huh?
Early this AM, Mom gave me half a day before the wind came up..
Makin' shit fit tight!
Hoping next week is going to be massive..
Mom and kids gone all week.
Mike has promised to help me.
If all goes according to plan,
OMG,
We could be seeing things actually DONE!
Brent Samba Member
Posted: Sun Aug 14, 2016 10:51 am Post subject: Re: Black Fastback Build Thread |
That clip really ties the car together, does it not?
Nice work, can't wait to see the forthcoming updates!
You should re-powdercoat those diagonal arms. Black would look better. And, you know you can get new rubber OEM bushings for them. Urethane, meh...
Not to bag on your sweet build though.
Wish I could be there for the week of progress. _________________ 69 Fastback Build
Berg5 Build |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Sun Aug 14, 2016 6:17 pm Post subject: Re: Black Fastback Build Thread |
Damn Steve, You have been a busy bee for sure. Way to knock out the mock ups and get that front end sorted out and welded in.
Not sure you did all that with the smoke out there but great job!. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
