Dodgy Samba Member
Joined: January 30, 2006 Posts: 518 Location: Leicester, UK
beetlenut Samba Member
Posted: Fri Sep 06, 2013 6:28 am Post subject: |
Dodgy wrote: |
Been doing more digging in the quest to get to the extent of the rust - LH side of the front bulkhead is basically all air now, and still more metal needs to be cut away. I think this is way beyond patching and I'll have to bite the bullet and fit a pattern part.
The panels available seem to be basically standard beetle bulkhead inner pressings which are altered at the edges where the super beetle attaches to the heater channels differently. Anyone fitted one of these? Does it cause any problems fitting the centre brace to the floorpan spine or the pedals / footrest panels?
As I'll have to do a significant amount of work on the pattern bulkhead anyway, I'm thinking of transferring what I can of the original inner panel upper onto the new bulkhead, and just using the lower part to give me the correct profile to seal onto the napolean's hat panel on the floorpan. |
If by bulkhead you mean front firewall, the Supers are wider than the Standards. I ended up replacing the entire front firewall as both ends of mine were totally gone. I'm not sure there are any replacements made that are not thinner than the original metal, and none that I know of containe the captive nut plates for bolting to the Napoleon's hat. Then there's the upper portion of the firewall where it attaches to the area under the gas tank. Mine was gone there too. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Dodgy Samba Member
Posted: Mon Sep 16, 2013 12:03 am Post subject: |
Did a bit more work over the last couple of weeks. Added patch panels to upper & lower parts of the body section so it's now solid again. But I think I removed about the same amount of (further) rusty metal as I've added in new pieces! I guess it's still progress though - although I'm looking forward to the point when the body actually starts getting heavier again!
I've now removed the rear part of the strut tower reinforcement to prepare for replacing the rusty sheet metal behind. All this will have to be stabilised before tackling the bulkhead. _________________ '75 1303 (current project) owned since 1989!
'72 Squareback - full resto completed 2008 - now sold
356 Speedster kit, completed 2005 - now sold |
don't_bug_me Samba Member
Posted: Mon Sep 16, 2013 4:18 am Post subject: |
You do good work, and i've seen a lot of people as of late doing extensive serious body work repair to some of these bugs, not ones with any great meaning either, like they've been in the family, rare car, etc, leading up to a question I guess, in the long run, wouldn't it be easier to find a donor body in better shape both for time and cost savings, I guess unless they are hard to come by where you may happen to be, but I seem to run across a lot of people taking the bodies off, some in real decent condition for whatever trike or buggy project they happen to be creating at the time, and most of them initially try to sell the body for some money, and after a couple weeks they practically try to give them away for mere pennies on the dollar to just get it out of their way. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Sep 16, 2013 4:56 am Post subject: |
Well they're not making any more of them,
Good project bugs have been starting to dry up due to people in the past scrapping good cars so its either fix a rotten one or pay through the nose for a solid one.
Some people have the skills and like the satisfaction of fixing a rotten one, it doesnt always need to have sentimental value. |
Posted: Mon Sep 16, 2013 5:29 am Post subject: |
Oh by no means am I putting anyone down for this, some people I can tell just enjoy the body work, I guess I don't mind the mechanical end of it, and prefer to do less body work, and have seen quite a few bodies for sale this past year, craigs in my area is full of project starter wannabees who never finish them, whether it's a car, bike, atv, etc, I usually have a pretty good pool to choose from, lucky I guess, maybe compared to others. |
Dodgy Samba Member
Posted: Mon Sep 16, 2013 10:56 am Post subject: |
Well, as I've owned this car so long and it was my first car, with the family connections etc, I guess a body swap is out and the sentimental value aspect is worth the work. And bad as it is (in some areas) there are plenty of people who have rescued far worse Beetles than this one. I've been a bit surprised how rotten this car is, especially bearing in mind that it's spent about a third of its life (so far) in dry storage.
It would be far harder if this car was less original than it is. For example having to re-do previously replaced heater channels would be a nightmare - it's not too bad picking apart the factory spot welds on an original body. That's where the additional challenge of 'project cars of the future' will be.
I don't mind bodywork, although it requires (a lot) more patience than mechanical jobs. I keep reminding myself that the end result will be worth it - and if I do it right this time I won't have to do it again - I'm reminded of that now I'm picking apart repairs that were just bodged on in the past. _________________ '75 1303 (current project) owned since 1989!
Dodgy Samba Member
Posted: Thu Oct 24, 2013 12:08 am Post subject: |
Thought it is time for an update, although I haven't had much garage time so not a lot of progress...
Finally completed the patch to go over the huge hole in the inner wing - this was a real pain to get all the curves correct and match the features on the panel. I lost 1 of the circular recesses and formed a new one using a couple of sockets and my vice, came out pretty good! I don't want this to be an obvious repair when finished and painted. I've drilled holes to plug weld through onto the various panels / sections behind that tie to this surface to make sure everything is as strong as it should be. The panel is just clamped in position for now, as I'm waiting until I finally weld the inner reinforcement in place, then can repaint where the welds have burnt the paint of.
I've cleaned up the inner reinforcement and welded in a patch where it was thinned due to rust, between the holes for the steering rack bolts, this is ready for refit but I'm still debating the refit order, inner wing panel, reinforcement, bulkhead etc
Have welded in a patch to repair the big hole in the inner wing by the A-pillar. This was a pain to match the deceptively simple curves. Still have to grind back the weld bead and make good. (Heater channel is just clamped in place in this photo)
Lastly, have started drilling out the spot welds to remove the bulkhead. This is going to be a big job as the pattern panel needs LOTS of work before it can be fitted.
Still going... _________________ '75 1303 (current project) owned since 1989!
Posted: Thu Oct 24, 2013 7:24 am Post subject: |
Dodgy wrote: |
Still going... |
At least you had metal to drill out at the top of the bulkhead. I had to make a new piece for that area so I would have something to weld the top of the bulkhead to. Let me know how you make out getting the new bulkhead in. I'd rather pass a kidney stone than do that job again! _________________ scrapyards are for quitters
Wetstuff wrote: |
Dodgy Samba Member
Posted: Mon Nov 11, 2013 1:25 am Post subject: |
The bulkhead is out!!!
What a ba***rd of a job
Unfortunately removing it has, unsurprisingly, revealed more rust on the RH side inner wing. This means that the corner reinforcement piece on that side is going to have to come off. I was really hoping I wouldn't have to do this...
The [wheel side] inner wing panel on this side is solid, so I'll have to try and remove the corner reinforcement welds from the underside, this is much harder than finding the welds from inside the chassis box section.
Here are the photos of the original bulkhead showing the differences to the pattern panel currently sold. I think this pattern panel is basically one from a standard beetle fitted with a slightly wider flat front panel.
1) The inner panel on the original has a flat top and completely different profile. It also has a centre face at 45 degrees to support the bracket that bolts to the top of the floorpan tunnel - missing from the pattern part
2) Front panel is similar - probably close enough to live with. There is a raised panel on the LH side (RH in photo), not sure if I'll have to remove this or not. Bracket from the top of the bulkhead that bolts to the floorpan framehead is missing and will have to be transferred over
3) Hole for drain tube is missing, I think the profile of the top flange is different too, but maybe not significantly.
4) The depth between inner and outer faces is different and will have to be built up, the pattern panel narrows towards the centre while the original is a constant depth.
On top of this of course, the reinforcement 'boxes' containing the captive threaded plates for the body mounts will need to be made up, as the bottoms had completely rusted away on both sides.
Feels like I'm staring into a (rusty) abyss at the moment, but trying to keep motivated to see it through. It'll be worth it when it all goes back together and is (a) solid and (b) correctly done. _________________ '75 1303 (current project) owned since 1989!
Dodgy Samba Member
Posted: Mon Mar 03, 2014 1:47 pm Post subject: |
Been a while since I updated here. Started to get frustrated and thought it better to take a while off than start rushing things and screwing the job up.
Finally got the second corner reinforcement bracket off. I think my car was built after lunchtime in the VW factory, and Herman the German (after his lunchtime beer) got carried away with the spot weld tool. In the end I had to cut into the solid inner wing panel and get to the welds from the inside. Never mind...
The small rust patches on the inner body section lower corner and between the steering rack mounting bolts have now been fully repaired.
So... started working on making a new 'proper' bulkhead from a combination of the original panel and the crappy pattern one.
Measured the better of the two (remnants of) reinforcement 'boxes' for the front crossmember captive nuts, drew it in CAD to develop a flat pattern, and knocked one up in 2mm steel.
Split both bulkhead panels
You can see the KlokkerCrap quality shining through - no inner paint coating at all, and already rusty just from storage
Added the cutout slot for the vent drain tube to the top of the pattern panel
Fixed the centre area on the original panel which was damaged when removing the bracket that bolts to the chassis tunnel - this area was completely different on the pattern panel which is one of the reasons I'm doing this repair the hard way.
Now started to build up the bulkhead inner panel, reshaping the corners of the pattern part to join with the good steel on the genuine one. You can just see poking out part of the reinforcement box for the front crossmember captive nuts.
This is as far as I've got for now. Still, making progress. Maybe things will speed up as the garage gets warmer again _________________ '75 1303 (current project) owned since 1989!
Posted: Tue Mar 04, 2014 10:47 am Post subject: |
Coming along slowly but surely. I had to make all those revisions to my new front firewall repair panel too! Seriously a POS replacement piece! Make sure you leave room for the captive nut plate to float inside the little housings that you're going to put into the firewall, so you have some play for the bolts that go up through everything. I made a slot in mine so the nut plate could slide around, without moving up or down.
Don't lose that bracket that bolts to the top of the floor pan tunnel! You think it sucked getting the front firewall out! Wait till you have to put the new one in. Some serious metal origami happening there. I had to end up taking both corner reinforcement brackets off in order to just get the mushroom-shaped firewall up in place, and I replaced the spare tire well, so I had a little more room to work with the old one out of the way. It's like the worst 3-D puzzle with no instructions!
Keep hammering away at it (sometimes literally)! _________________ scrapyards are for quitters
Wetstuff wrote: |
Dodgy Samba Member
Posted: Mon Jun 30, 2014 12:17 am Post subject: |
OK, time for an update. Been a few busy months without much time in the garage (again), but some progress has been made...
Finally got all the pieces assembled and welded together, and the bulkhead is now complete
Here's all that's left of the pattern panel and the original bulkhead
I made the two reinforcement brackets, copied the originals as closely as possible so they will tie into the structure in the same way as originally designed. The original rusty parts are shown for comparison
So, time to trial fit on the floorpan...
(Seeing it in place like this makes all the work worthwhile, the centre bracket fits properly and the footplates will fit correctly too - neither would be the case with the pattern panel)
...but not before finding out that the pattern heater channels are not correct at the front end (although I'd heard this was the case beforehand) - photo shows the front plate cut off and moved about 3/4" forward over the bolt holes
One small extension piece later
Now time to trial fit in the body...
...but the only way I could make it fit was cut into some of the parts I'd already repaired
It's so great to see this big hole finally filled. Trial fitted the heater channel too, and the fit of all the parts is good
Next job is to tack weld everything in place and drop the body back onto the floorpan to check alignment before welding everything together.
Then onto the heater channel and rear crossmember on the other side! _________________ '75 1303 (current project) owned since 1989!
Dodgy Samba Member
Posted: Tue Sep 16, 2014 12:08 am Post subject: |
Time for another occasional update...
Body is back on the pan! (Well, for now)
Made sure all the bolts lined up before tacking everything together in final position
Bulkhead looks good, worth all the effort. Fit over 'nap hat' looks fine.
Then puddle welded all the original spot welds back together
While the body is back on, thought I'd finish the LH side of the car before embarking on the RH heater channel. So time to deal with the big hole in the inner wing / rusty body mount
Here's what it looks like at the moment
Some work to go, but nothing like the bulkhead - if I can survive that I can survive anything!
Already see problems with the pattern panels - wrong curvature, poor form etc. Same old, same old. _________________ '75 1303 (current project) owned since 1989!
Metamatic Samba Member
Joined: June 19, 2014 Posts: 54 Location: Limhamn, Sweden
Posted: Tue Sep 16, 2014 1:34 pm Post subject: |
I am seriously impressed how well you are working with the metal.
I am currently working on a 1303 convertible and I've observed that my vert has similar rot in the bulkhead. Unfortunately I think I'm lacking the skill to repair it the way you do. But I am tempted to try because of your thread. So I will give it a go without removing the bulkhead. I suppose I have to build a rotisserie now.
Anyways, keep up the good work! I am really jealous! |
Dodgy Samba Member
Posted: Tue Sep 16, 2014 11:48 pm Post subject: |
Metamatic wrote: |
Thanks. Glad this job is behind me now. To quote Beetlenut:
beetlenut wrote: |
I'd rather pass a kidney stone than do that job again! |
I'm not sure how much the bulkhead can be repaired in situ, but I'm a bit obsessive about trying to recreate the factory panel joints & overlaps and make the repair invisible so maybe this influenced my decision to remove it fully.
If you have the coin and don't fancy doing the cut & shut on the Klokkercrap panel like I did, Memminger do a more faithful reproduction, not sure if it includes the internal reinforcements or not though.
http://www.feinecabrio.de/cms/front_content.php?idcat=42
Good luck! _________________ '75 1303 (current project) owned since 1989!
vwrobert Samba Member
Joined: February 10, 2002 Posts: 370 Location: England
Posted: Wed Sep 17, 2014 1:05 am Post subject: |
Dodgy wrote: |
Good luck! |
My sentiments too, I dont hold with Memminger price but when i did the job I was lucky to find NOS on ebay in the UK, the Klokkershit panel went back to VWHeritage for a refund. My question is why do we still buy that stuff? (Me included)
And according to the Memminger website its fitted with a 2.5mm steel reinforcement so id say it has the captive nuts. _________________ 1973 1303 RHD Vert Project
WWW.TheVolksmeister.Com |
Dodgy Samba Member
Posted: Thu Oct 30, 2014 2:20 pm Post subject: |
Time for another intermittent update
The inner wing panel is now fitted - dots show puddle welds from the inside replacing the original factory spot welds - all properly tied in!
View from inside - oh yes this floor repair piece also needed substantial reworking before it could be fitted to the car. Originally had a deep recess that had to be removed, maybe from later / Mexican Beetles?? (the panel was much larger than just the piece I've fitted)
View from underneath showing the third layer, the upper / rear part of the crossmember. Seemed a shame to purchase a whole crossmember panel and then just use this part, but there you go. Right now it's all about keeping as much original metal as possible.
So now the dilemma. I have to fit the reinforcement panel with the body mount. I have the pattern part but it's just as crap as the others I've had to deal with so far:
- Metal is thinner than stock
- Form of part is awful
- Body mount is thin steel and only single thickness (original is double thickness)
- Body mount bracket isn't even folded square
- Has maybe a quarter of the welds holding the original panels together (count the holes where I drilled them out!)
- Knowing Klokkercrap, the gap between these panels is already rusty from new
I'm thinking of repairing the front rotten part of the original reinforcement panel, then refitting the original body mount which had surface rust only.
Maybe I just look for the hard way to do everything? But I know it will annoy me to (a) fit and (b) forever see the crap panel in situ on the car, let alone be aware of the reduced strength in this area.
I'm trying not to look over at the other side of the car while I'm working here, it's too depressing
Oops I just did
Posted: Thu Oct 30, 2014 2:27 pm Post subject: |
Impressive work!
I haven't even started on my body yet and it's in even worse condition than yours. |
houseofboyd Samba Member
Joined: September 28, 2014 Posts: 613 Location: Flatwoods, Ky
