VicVan Samba Member
Joined: July 01, 2015 Posts: 1869 Location: Vancouver Island, BC
Posted: Wed May 08, 2024 1:56 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
Thanks Skills. There is indeed a learning curve.
I talked with BusDepot, they could not figure out what was wrong. From their end, and from the pictures I've sent them, the only problem they could think of was an incorrect install procedure. We went over my installation procedure and concluded it was as per instructions. The final recommendation was to send it to a professional who is used to doing this job.
Not thrilled by the conclusion, I was hoping there'd be a fix somewhere... I will take it down, and put it back up again. We'll see if it still sags. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6256 Location: Portland OR
Posted: Wed May 08, 2024 4:12 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
Are you doing this with the top still on the van? All your photos that show sag are of an incomplete installation. Until you have all sides attached, it's meaningless to look at the sag. With the top up and the sides NOT attached, it will sag.
The front will also tighten up when the top and bottom are fully attached. you're judging the install before you're done. _________________ 89 Westy 2.1 Auto |
Joined: January 01, 2007 Posts: 16914 Location: sticksville, ct.
Posted: Wed May 08, 2024 6:03 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
yea, X2
didn't realize you hadn't pinched the canvass along the side
FWIW I have done a staple in and screw in tent. it's suicide to do either one on the van imho. I wouldn't do a screw in on the van.... it's just a pain in the ass
top comes off in 5 mins _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
kamzcab86 Samba Moderator
Posted: Wed May 08, 2024 6:58 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
PDXWesty wrote: |
Are you doing this with the top still on the van? All your photos that show sag are of an incomplete installation. Until you have all sides attached, it's meaningless to look at the sag. With the top up and the sides NOT attached, it will sag. |
x3
Acrylic tent in my case, but also installed it front to back, top then bottom. Did it with the roof on over two days. The major PITA part was the rear and bottom corners. _________________ ~Kamz
2016 Golf GTI S
VicVan Samba Member
Posted: Wed May 08, 2024 7:30 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
PDXWesty wrote: |
Until you have all sides attached, it's meaningless to look at the sag. |
I see. I wish BusDepot told me that.
I've attached the sides, I had a bit of extra fabric that I tucked into the back corners.
I did do it with the poptop on. I see the appeal of removing the roof, but because of weather, and impossibility to commit a full day straight to the project, I've decided to do it with the roof in place. This allows me to go at it a little bit at a time. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2604 Location: Philly, mang
Posted: Thu May 09, 2024 4:15 pm Post subject: Re: Bus Depot's Pop Top Canvas "In House Brand" |
i installed my BD tent in place. i started with the front top center and worked to each corner, then did the rear top center and worked to each corner. then i did the front bottom center out to each corner and then the rear center putting two screws in on either side. then i worked from the front to the back on each side and finally worked on the rear bottom corners.
it was a PITA and i never want to do it again, but in the end it looks good.
_________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
