57/58 Alken Fiberglass Coachbuilt Project
Page: Previous  1, 2, 3, ... 17, 18, 19  Next
JeffL
JeffL is offline
PostPosted: Sun Jan 27, 2013 6:16 pm    Post subject: Reply with quote
Stock Steve wrote:
Jeff,
We had to go with a 155R15 Vredestein (Sprint Classic) to fit in the spare tire well of Moogie32's '63 Ghia.
Nice looking, "older style" sports radial, plus it's a fresh tire, which is reassuring from a safety standpoint.
I also have a couple of sets of them that I use on my '60 Bug. Here's a shot of one sitting next to a 5.60x15 Firestone for comparison:
Here's another of the same tire, but on black-painted wheels (both are 4.5" width):
Keep up the great work on the Alken--very exciting to watch your progress!
Steve
Thanks Steve, those black rims look great with the Porsche drums in the back.
When I look at Cokers' site they have those 155SR15 listed with a cross section of 6.2" and I need to be at about 5.25". 155 converts to about 6.1" so it still will not work. I do like those Vredestein tires.
http://karmannghias.org/
https://karmannghias.org/GAlken/index.html
Stock Steve
Stock Steve is offline
PostPosted: Mon Jan 28, 2013 4:22 am    Post subject: Reply with quote
Those are FAKE Porsche drums, Jeff! Ouch!
Hope you can eventually find the right tire!
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
JeffL
JeffL is offline
PostPosted: Mon Jan 28, 2013 5:59 pm    Post subject: Reply with quote
They still look great Steve!
I like this as a spare and running set for the Alken. I would like the Vredestien but I can not find a thin spare to match.
The pic is of a whitewall but I would use blackwalls. They have 590s like used on the 356 Supers but they have a 600. I need to call Coker and check on the dimensions. While I realize the pics are for illustration the 600 looks to have smaller specs than the 590.
Standard Spec 5.60X15 Firestone
http://www.cokertire.com/firestone-bias-ply-blackwall.html 5.96 section 25.8 diam 3.80 tread 4.5 rim $164
BF Goodrich Option
http://www.cokertire.com/500-15-bf-goodrich-blackwall.html 5.1 section, 24.38 diam 4.00 tread 3.0 rim $135
http://www.cokertire.com/590-15-bf-goodrich-blackwall.html 5.88 section, 25.38 diam 3.75 tread 4.0-4.5 rim $157
http://www.cokertire.com/600-15-bf-goodrich-blackwall.html 6.0 section, 26.00 diam 4.35 tread 4.5-5.0 rim $157 - not a good matching design
Set of 5 $763 plus shipping/tax
Another choice could be the Michelin spare with Michelin or Vredestein tires (I like a matched set though)?
http://www.cokertire.com/125r15-michelin-x.html 4.7 section width 23.2 diameter 3.5-4.5 rim $151
http://www.cokertire.com/165sr15-michelin-xzx.html 6.4 section width 25.4 diam 4.5-6.0 rim $208
http://www.cokertire.com/165hr15-vredestein-sprint-blackwall-tire.html 6.6 section width 25.4 diam 4.5-6.0 rim $116
Set of 5 Michelin $983 plush shipping/tax
Set of 5 Mich/Vredestien $585
JeffL
JeffL is offline
PostPosted: Sat Feb 02, 2013 1:59 pm    Post subject: Reply with quote
Decided to go with the vintage BF Goodrich tires. Sandblasting the rims to get them ready for powder coated silver.
I ordered some rivets, clips and a rivet tool to repair some broken clips on the rims.
The photo links are updated with some of the work to get the suspension and ride height correct.
To lower the front beam I will use Avis adjusters. But since I want to use the internal lock, I have to get a 14 mm, 1.5 pitch bolt and cut it down to make my own grub screw. I will turn the head down for the point and then just double nut the remaining stud to get it in tight. Waiting for the bolts now. My only concern is will the standard grade bolt hold up? Berg's are out of these so I am on my own.
A Samba friend is hooking me up with the front sheet metal for the engine so that I can size up the firewall and engine bay.
Trying to find some straight pipes for the Dansk muffler, they are a little less than 42 mm on the outside so I need to find something to just slip over them. I could slot the sides and use a standard Porsche muffler clamp to secure it but everything I find is large in diameter.
Here is a link to all the photos. I included some original literature on the general album and the latest photos are on the "stripped" album.
http://karmannghias.org/Alken/
JeffL
JeffL is offline
PostPosted: Fri Feb 15, 2013 7:56 pm    Post subject: Reply with quote
Got the 356 rims sand blasted, clips replaced and dropped off at the powder coater. I also did an early Beetle rim too that requires a tube in case I need a thinner spare for the spare tire pocket. No reason to use one that requires a tube other than I like them.
I bought an Avis adjuster kit but will use the internal lock. I will throw away the circular lock that comes with the kit and the american thread bolt and lock nuts.
I took some 14mm X 1.5 pitch X 50mm long "full thread" bolts and had the heads cut down like the point on the original grub screw. This is just long enough to get two nuts on or I will use one nut and a lock washer with some blue lock tight. This bolt also fits more snug through the holes in the adapter. I wanted a higher hardness of this bolt but will hope for the best. I'll have to use the double nut procudure to drive the stud in since there is no head or hex hole.
The two studs in the center are what I had cut down. The shiney point use to be the heats of the bolts which were turned down.
The next picture is a test fit to see if the new grub screw studs were long enough. To use two nuts to tighten the grub screws in I might have to take the top part of the two piece adjust off, tighten the grub screw, and then put the top cap back on and then the nuts.
I don't plan to pull the axle apart to cut the interanl locks free and weld on the Avis adjusters. We'll see if this approach works.
http://www.karmannghias.org/AlkenChassis
JeffL
JeffL is offline
PostPosted: Sat Feb 16, 2013 3:55 pm    Post subject: Reply with quote
OK, got the Avis adjusters cut in today and set. Here is the link to the chassis pictures but here are a few.
http://karmannghias.org/AlkenChassis/
I started off drilling some pilot holes at the end of the indents and then a 3/8 drill. Followed this with about 2 hours with my cut off disk and freed all four indents. The whole front axle was pulled intact and I was able to do all of the cutting off to the side then put it back on.
You can see where I mounted the adjusters and made cover plates for the back. The center lock that came in the kit came in handy, I used my press and forced the lock down between two 2X4 and curved the cut metal plates, about 1 inch by 1 3/4 inch.
The initial ride hight was a litttle low and you can see where I placed the adjusters in the center initially and then went back and moved them up 4 notches for the final height.
I will wait for the new tires and powder coated rims. I will then set the back torsion rods a little lower and see if I need to reset the front. I will weld them in at that time.
The adjusters will be welded on to have it cover the opening from the screw down to the bottom of the indent.
With this setting, I should find another beam and do a "cut and turn" like old school in the day, so I have read............
I was shooting for a nice even margin around the wheel whithin the wheeld well which turned out pretty good.
JeffL
JeffL is offline
PostPosted: Thu Feb 21, 2013 7:51 pm    Post subject: Reply with quote
Adjusters and cover plates welded in. Test fit everything again tomorrow and lower the rear a little, and maybe the front a notch or two. We have plenty of room to lower it some.
JeffL
JeffL is offline
PostPosted: Sun Feb 24, 2013 7:20 pm    Post subject: Reply with quote
Long drive on Saturday, about 8 hrs each way. Picked up a nice 1958 chassis with new pan halves and frame head. I wanted the twist knob heater controls even though the current 65 pan was nice. Anyone need at 65 pan.....
disneyherbie
disneyherbie is offline
PostPosted: Tue Feb 26, 2013 11:27 am    Post subject: Reply with quote
Awesome project man! I love that you're keeping everything period correct. I think that will really pay off in the end with a great looking car!
JeffL
JeffL is offline
PostPosted: Sat Mar 09, 2013 4:54 pm    Post subject: Reply with quote
I got the rims powdercoated and sent them off today to get the tires mounted.
Has any tried to mount seats like speadster seats without drilling holes in the pan? I am thinking of making a transition plate that mounts to the exitsing seat rails where it basically is locked in place (ok it could move) and then mount the typical slider tracks to those.
Has anyone done something like this? The 58 pan I picked up has the seat rails on it and instead of cutting them off I though maybe a transition plate could be an approach.
gitchesum
gitchesum is offline
PostPosted: Sat Mar 09, 2013 8:16 pm    Post subject: Reply with quote
I would find some old beater seat bottoms and cut off the rails and bond those to the Speedster seats...that way they are easily removable and adjustable.
Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
JeffL
JeffL is offline
PostPosted: Sun Mar 10, 2013 9:19 am    Post subject: Reply with quote
That's what I am looking at but the speedster seats are much more narrow so a bridge plate/deck is needed to have something for the speedster seat to bolt on to. This mock up was to use some 1X4s to simiulate the position and seat height. This would allow for the seat assembly to slide on easy after upholstery then use the adjusters that came with the seats.
When I did a Kooble Kar I did the same type of thing where I welded the bottom of a Beetle seat to those, second picture. That was my only other "custom/specialty" restoration. Everything else has been to stock specs.
http://karmannghias.org/kubel.htm
wbrown45
wbrown45 is offline
PostPosted: Sun Mar 10, 2013 10:44 am    Post subject: Reply with quote
Scat makes seat rails for their seats that might work. I don't know the width, but they should be able to help you out.
OK Thang
JeffL
JeffL is offline
PostPosted: Sun Mar 10, 2013 12:49 pm    Post subject: Reply with quote
Good tip, I'll see if they a slider or can make one. I will check it out.
________________________________________________________________
Follow up
Scatt only had seat mounts that bolted to the standard seat rails (into existing holes). I need to make some that slide on or just get rid of the rails and bolt them through the floor, not yet........
JeffL
JeffL is offline
PostPosted: Sun Mar 10, 2013 5:42 pm    Post subject: Reply with quote
I pulled off the front shocks and tie rod ends.
The 356 A spindles take a larger tie rod diameter. The right one is angled too, not sure why.
I need to get new inners and new 356 outers but not too many out there with the original castle nuts.
I put a post on the 356 forum to see if there are Type 3 or some of larger diameter that match the outer tie rods. The are about 14 mm at the largest part so they must be about 12 mm shaft/bolt size.
JeffL
JeffL is offline
PostPosted: Fri Mar 15, 2013 7:00 pm    Post subject: Reply with quote
BF Goodrich Option
Well got the BF Goodrich tires. The 5.90X15 was the standard larger tire for the 356. The dealer made some errors but he finally straightened it out. The spare did not have a curb bead like the picture but it will do.
The spare is small to fit in the Alken pocket, still a little big. I powder coated an older Ghia rim too in case the 1/2 inch lets it slip in and in case i need it later.
Mayber tomorrow I'll lower the rear a little and put the body back on.
I think I might need to get some shocks for a lowered car. I need to reach this more. The best explanation I saw is that a shorter shock is a little softer because the shock force is not linear as it is compressed further.
The final picture is of the smaller spare.
I need to get some period 356 bullet hub caps.
wbrown45
wbrown45 is offline
PostPosted: Sat Mar 16, 2013 11:06 am    Post subject: Reply with quote
Your car is going to be pretty cool. I cannot wait to see the progress on it.
OK Thang
JeffL
JeffL is offline
PostPosted: Sat Mar 16, 2013 1:59 pm    Post subject: Reply with quote
Thanks, sometimes it feels like I'm not making much progress when I do most everything myself.
JeffL
JeffL is offline
PostPosted: Sat Mar 16, 2013 2:10 pm    Post subject: Reply with quote
All tires on.
Lowering. I don't get much out of +2, -2...... I use my protractor to get the pan level. I use the area ahead of the ebrake lever. Then with the panl level across, measured on one of the torsion rod tubes, I look for the "hanging/loose" angle of the spring plate. In my setup becasue the fiberglass car is so light I am set at 2.5 degrees right now. I might have to go back to 5 degrees (raise it a little) once I see how the body sets. Setting it this way is closer to the suggested method from the Bentley manual.
The rear spring plate has about 3/4 inch travel remaining, this should still translate to almost 2 inches of shock travel by measurement. I cut off 5/8 of a new bump stop to allow 1 inch of travel and then 1 inch of crush to slow it down and hopefully stop it before hitting the metal.
The rear wheels have about a neg 2 deg of camber. The axles incline about 1 to 2 degrees out to the bearings so I think we should get some lubrication.
Hope I didn't lower it too much for these 5.90 tires to clear all the fender wells. We'll see tonight if I get some time to drop the body back on it. The front inner fenders were rubbed by the past tires.
In the front I had to go to notch 4 on my welded in Avis adjusters (I started off welded in a little lower than stock. Not much "up travel" in the front either before the stock bump stop is hit. Less than 1 inch of travel. Maybe I can trim off the rubber stop to allow a little more travel.
The pan measures about 8 inches off the concrete in the front and rear.
If anyone has a suggestion on the shocks let me know. I think I might just try stock ones because I still have the full front and rear travel by the way I lowevered it.
The rear bump stop does not line up directly under the mating casting in the tower, is there a reason why?
JeffL
JeffL is offline
PostPosted: Sun Mar 17, 2013 6:00 pm    Post subject: Reply with quote
Got the body back on.
I had to raise the front end some to get the wheels to clear the front wheel wells. The front left seems to be softer on the left side front. Maybe I have to switch around the torsion rods, I'll have to read up on that.
I like the wheels and tires, they turned out just right for the vintage look and fully filled out the wheel wells.
With the ride height I'm going to work on the seats next. I decided to to cut off the tracks and use some seat brackets from Summit racing that are like a Z mount and then I can bolt the sliders to these brackets.
Page 2 of 19
