adamharo Samba Member
Joined: October 18, 2012 Posts: 33 Location: Fresno Ca
Posted: Sat Nov 03, 2012 11:35 pm Post subject: Surging follow-up, need part, electromagnetic valve |
Following up on my other post, according to the shop I have a bad idle up valve, or they said it might be called an electromagnetic valve. Are either of these the proper names for the part? Any idea on who would carry one or is there is a part off a newer vehicle that would work?
Thanks
Adam |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21521 Location: Oklahoma City
Posted: Sun Nov 04, 2012 8:52 am Post subject: |
Are they speaking of the electric deceleration valve? The one that is triggered by a presure switch from the automatic transmission?
Uh...no...Im not buying that. If its causing surging...just disconnect it and plug the line to the manifold. Comparatively few cars came with that valve (California mainly). Plenty of automatics including my first 411 came with the pneumatic version of that valve and worked fine. Even without it out all you get is sime mild popping on deceleration from high speed.
Yes...it could be kicking in and out at the wrong time causing intermittent enrichment, but more often its the control relay or the pressure switch that is at falt. Unlesss you are in Californis or really want to save it....remove it and go to a vacuum version of the valve which is also easier to adjust.
Also...long before you suspect that part...have you checked the other items I listed? Ray |
Posted: Sun Nov 04, 2012 11:56 am Post subject: |
Thanks Ray. They did check fuel pressure. Supposedly they were also checking temp sensors too. I'm not sure they were suspecting tthis valve as causing surging as much as throwing off fuel mixture. So you are saying this valve can be bypassed without issue? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22729 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Nov 04, 2012 1:08 pm Post subject: |
Are they talking about the vacuum dash pot? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Nov 04, 2012 7:15 pm Post subject: |
Pictures? |
Posted: Sun Nov 04, 2012 9:38 pm Post subject: |
I'm going to run by the shop tomorrow I will grab a picture of the valve. According to them it is specific to automatics. |
Posted: Tue Nov 06, 2012 7:47 pm Post subject: |
Yes...good question Tram. The vacuum dashpot on the 411/412 with D-jet is an automatic transmission part. Its hard to do without and it can be problematic. its not really hard to adjust.....but with age it can leak causing slight problems.
Also if the egnine has low compression because of age....it usually also corresponds to erratic vacuum signature which can cause the valve to be difficult to adjust correctly.
If you also have a deceleration valve that is malfunctioning or adjusted incorrectly...whether its pneumatic or electric...it can cause issues with the dashpot. All of this can be compounded....even with a properly working dashpot.....if your automatic transmission modulator is not properly adjusted.
What this dashpot does is to prop the throttl very slightly open as you gear down or come to a stop until the torque converter decouples and take the load off the engine. The dashpot is to keep the engine from stalling as you come to a stop.
You can get along without it with some careful adjustment of ignition timing and idle speed. Slightly higher than stock idle can keep teh car from stalling. It can also make the transmission slightly jumpier off the line.
The deceleration valve I was speaking of is helpful. It is actually slightly redundent in most later cars. Its purpose is to bleed a little air into the mixture...which actually slightly richens the mixture because it affects the MPS.....when you come off the gas at high rpm. When the throttle snaps shut at high rpm.....the vacuum spikes to its highest point. That causes the MPS to trigger full lean, but your ignition advance is still at maximum. To keep from getting popping in the exhaust or pinging....the decleration valve pops open and bleeds in some air right next to the MPS vacuum line triggering slight enrichment.
The redundent issue is that on later models of D-jet with fuel cut-off on the TPS....if the throttle snaps shut...fuel should be shut off. I "think" I had heard maybe from Brad Anders that the rpm signal keeps a certain amount of fuel running. I do not know that for certain.
Either way....I have found you will get better running when going without the decel valve at most throttle settings by pulling the wire that signals fuel shut off out of the plug for the TPS at least temporarily. Ray |
Posted: Mon Dec 17, 2012 10:20 pm Post subject: |
Just got my car back from the shop and it runs like a new car. They yanked out the fuel injection and put in a carb. Downside is I have a square box in the middle of the back cargo area but with the way it is running I could care less.
I have a bunch of injection parts if anyone is looking.
Next thing to consider is the tranny. It is pretty tired. After talking to the shop I think we'll be doing a swap to a manual tranny in the spring. |
Lahti411 Samba Member
Joined: January 26, 2005 Posts: 223 Location: Lahti, Finland
Posted: Mon Dec 17, 2012 11:38 pm Post subject: |
NOOOooooooo!
_________________ My cars: 1972 VW 411 Variant; 1973 VW 412 4d sedan |
Posted: Tue Dec 18, 2012 4:04 am Post subject: |
If a center mount progressive runs well out of the box it is probably running way too rich. There were a lot of better options out there your shop could have chosen that didn't involve butchering your car; a variety of dual carbs and several styles of FI. |
Posted: Tue Dec 18, 2012 4:42 pm Post subject: |
adamharo wrote: |
If you think THAT runs like new.......you should see what properly running fuel injection runs like. You will cry yourself to sleep for the damage they did to your car.
Classic mid 70's neanderthal VW mechanics...."grunt...Ugh..cant..seem ...make...wire...thingy....grunt....work.....must....have....crapuettors......fuel injection....bad....must....use...chicken bones....and....magic...dust...."
By the way.....if these guys think they will "swap" a manual transmission in....you will hang yourself when they start that little bit of butchery. The type 4 004 four speed is unique to 411's and 412's....and there were under 3000 shipped to this continent. Not saying you cant find one....just that they are a bit rare.
Not to mention the unique pedal cluster assembly, shifter, shift rod, shift gate, rear shift rod support, rear flexible shift coupling, tail cone mount, clutch slave cylinder, clutch master cylinder, clutch residual pressure valve, clutch hard line, clutch flexible joint line, clutch throwout fork with upper support ring (intact)...and a few small bits........all of which are unique to the car and required to make it work.
Putting any other kind of transmission is would be very, very hard.....would almost certainly require hydraulic clutch unless you can find a magical tube to put a clutch cable in. The only other transmission that physically fits...is a Porsche 901 transaxle unit...and would still need all of the above parts.
The automatic is an easy rebuild and is a Borg Warner unit. Ray |
Posted: Tue Dec 18, 2012 5:21 pm Post subject: |
Lahti411 wrote: |
NOOOooooooo!
Sometimes, you just have to laugh.
OP- Seriously... WHY did you allow this? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Tue Dec 18, 2012 5:28 pm Post subject: |
A VW garage in Eugene wanted to do that to my '69 FI/AT squareback! It just had a plugged up fuel return line, I found out when I towed it to a different mechanic. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Dec 18, 2012 11:43 pm Post subject: |
Honestly the carb swap made sense. The shop is very reputable in my area, the parts needed to get the FI were not available. Ray, I would be interested in a link to the rebuild kit for the AT. This isn't something I plan on dealing with till spring when I have the money. The AT currently works but shifts from 1st to 2nd very early and slips when shifting from 2nd to 3rd. |
Posted: Tue Dec 18, 2012 11:53 pm Post subject: |
adamharo wrote: |
Parts for FI not available?
:facepalm:
Hey, it's your car- glad you're happy with it... but I guarantee you, the very first time you drive one with FI, you won't be so keen on it. Plus, now you have a <Sam Kinison Scream> HACKED ENGINE LID!!!</Sam Kinison Scream>
Bryan67 wrote: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22439 Location: Kimball, Mi
Posted: Sat Dec 22, 2012 1:24 pm Post subject: |
Tram wrote: |
adamharo wrote: |
:facepalm:
Well, at least I'm glad to hear that shops don't just do that to FI type 3s. If the shop was as good as they say they are, they should have been able to find any or all of the FI parts. Hell, I bet you could have gotten the part out of the Samba classifieds for them IF they couldn't find one. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Fri Dec 28, 2012 3:48 pm Post subject: |
Posted: Mon Dec 31, 2012 3:26 am Post subject: |
By the way, as you now have taken all the FI parts out, you'd have a perfect opportunity to clean the parts and electrics, change the injector seals, change the fuel lines and vacuum pipes. Then, when you have the time, just put everything back to your car and enjoy driving! Infact changing to carburettor might have been a great idea: now you have a driveable car which you can enjoy, and you can repair the FI without any hurry! _________________ My cars: 1972 VW 411 Variant; 1973 VW 412 4d sedan |
Posted: Mon Dec 31, 2012 10:34 am Post subject: |
Alright, I get the carb switch appears to be a mistake. Pardon my ignorance and I mean this in all seriousness but can someone explain why? Aside from modifying the engine cover I don't get it. It seems the FI parts are hard to find whereas a carb can be easily replaced. Maybe the FI system gives you more power but it's not a race car anyway and it moves out pretty well.
Is everyone just a VW purist? |
KTPhil Samba Member
Posted: Mon Dec 31, 2012 2:33 pm Post subject: |
FI gives better starting, smoother idling, better mileage, and lower emissions. It actually does not do much for power. It just gets you that power in a more efficient way.
And once you get the wiring fixed, and your gas filler water entry problems, it will be more reliable. Parts are easily found here on the Samba, or on ebay.
Take the advice, good though perhaps said tongue in cheek, to clean, rebuild, and rewire the FI, and put it back on next time you have a couple of days and are sick of the constant fiddling carbs bring you.
And yes, some of us are purists! But VW got it right with the simple FI they introduced on these cars. |
