ATV / MOTORCYCLE jack adapter to remove VW engines;update
grandpa pete
grandpa pete is offline
PostPosted: Mon Jun 18, 2012 4:51 pm    Post subject: ATV / MOTORCYCLE jack adapter to remove VW engines;update Reply with quote
after hearing about using a motorcycle jack to remove a vw engine on this site i purchased one.This is a great tool and it is much safer than balancing an engine on the standard floor jack. After my 3rd engine removal/install i decided that an adapter was in order to make the job safer for me. the width of the engine is only slightly wider than the space between the horizontal supports of the jack. During both engine installs i had the engine try to fall off into that space ...sooo here goes
I cut a peice of 3/4 plywood 13 3/8 inch wide by 14 3/8 long and put 2 furring strips (1 x2 wood strips)13 inches long 10 1/4 inches apart (the width of the engine) on top
on the bottom i put 4 furring strips spaced 8 1/2 apart double stacked ;long enough to catch them between the large bolt heads on the jack so the plywood won,t slip front to back in the jack
I drilled a hole in case i want to drain the oil and chiseled out an area so the taco plate isn,t supporting the engine weight. The other problem i had was fitting an engine that was perfectly flat onto a transmission that was tipped because the vehicle was up on a jack.in order to tip the engine to fit i put a "woodnut"on either side of the bottom of the plywood and threaded a screw through. With a fender washer jammed between two nuts I can tip the deck by turning the nuts with a wrench(speedwrench works great)
with a good coat of oil base paint this will last through many engine changes Cool
UPDATE after using this adapter plate to remove an engine to work on it;I found that this makes a great engine stand.In the following photo you can see the height ( compare it to my work stool milk carton) to work on the engine is great AND very sturdy
Laughing Cool Very Happy
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Tim MacDonald
Tim MacDonald is online now
PostPosted: Mon Jun 18, 2012 5:02 pm    Post subject: Reply with quote
This is what i use as well but without the adaptor.I like your idea and think this will be added to mine as well
61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet
Desertbusman
Desertbusman is offline
PostPosted: Mon Jun 18, 2012 6:38 pm    Post subject: Reply with quote
Outstanding Pete. You're on a roll. Cool
Side to side leveling is where we hit the snag here, looks like you've got that problem covered. And we didn't have the side to side or rotation hindered by your indexing to the jack. Hope you don't have it too snug or you will have to rely on your truck driving super skills. Laughing Your pictures show you havn't used it yet.
71 Superbug
71 Westy
webwalker Premium Member
webwalker is offline
PostPosted: Mon Jun 18, 2012 8:01 pm    Post subject: Reply with quote
Groovy design. I have the same jack and I'll be using it for my engine pull later this summer. I think it will have a 'St. Pete' adapter on it. Applause
"Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image
Daverham
Daverham is offline
PostPosted: Mon Jun 18, 2012 8:32 pm    Post subject: Reply with quote
This is cool. Great idea.
hiwaycallin
hiwaycallin is offline
PostPosted: Mon Jun 18, 2012 8:35 pm    Post subject: Reply with quote
Is your adapter designed for engine only, or engine/transmission as a unit?
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jun 18, 2012 9:52 pm    Post subject: Reply with quote
outstanding Pete. We've used something like that and it works super. I put a board in a regular Jack and a nail in that board. That nail sits into a factory support hole for tooling in the bottom of the transmission. When I lower them I can control the trans nose and the engine. When you do this you will also find that if your floor jacks rolls well, when you pull the engine on your new jack, the other jack will roll right with it like a coal tender on an engine and it will make it really easy to move them around mated.
Yours is much nicer and much better craftsmanship than mine
ccpalmer
ccpalmer is offline
PostPosted: Tue Jun 19, 2012 5:00 am    Post subject: Re: ATV / MOTORCYCLE jack ;to vw, adapter Reply with quote
grandpa pete wrote:
Great idea! The front-back leveling is where I always have problems... working on a dirt driveway!
'71 Westy
Manfreds78bay
Manfreds78bay is offline
PostPosted: Tue Jun 19, 2012 11:41 am    Post subject: Reply with quote
Awesome...thanks for the write up.
1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI
grandpa pete
PostPosted: Tue Jun 19, 2012 2:26 pm    Post subject: Reply with quote
ccpalmer;i used carraige bolts but will change them before i use it again,regular phillips head bolts will lower the engine farther down.it's great that everyone appreciates my little project Cool
hywaycallin ;engine only...Never took 1600 out with trans..too much weight for the "old guy"
63 two fold rag
white74westy
white74westy is offline
PostPosted: Tue Jun 19, 2012 2:30 pm    Post subject: Reply with quote
Thank you! Nice work...I will most certainly be using this design. Very Happy
grandpa pete
PostPosted: Thu Jul 05, 2012 4:34 pm    Post subject: Reply with quote
read the update...great work stand...VERY sturdy
63 two fold rag
nodrenim
nodrenim is offline
PostPosted: Fri Jul 06, 2012 4:07 am    Post subject: Reply with quote
Very neat, I recently used one of those jacks, without the plywood pad, to r&r the engine and tranny in one unit. Next time I will have the plywood pad for sure. Thanks for the pics.
Poptopcamper
Poptopcamper is offline
PostPosted: Fri Jul 06, 2012 4:29 am    Post subject: Reply with quote
I've had one of these jacks for about ten years.I can put my Harley Electraglide on it all by myself. I was wondering if it would work for an engine pull on my new bus. Now I know the answer. Thanks.
If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom
Hugo Stiglitz
Hugo Stiglitz is offline
PostPosted: Mon Aug 20, 2012 5:47 pm    Post subject: Reply with quote
I can pull/install the engine by myself in roughly 2 hours time because of this little guy. Didn't even do it on purpose. My floor jack was being used, and the MC jack was all I had.
Works beautifully!
'63 slow n low build thread...
Jay Leno's Garage
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o]
TequilaSunSet
TequilaSunSet is offline
PostPosted: Mon Aug 20, 2012 6:17 pm    Post subject: Reply with quote
Way cool thread... thanks!!
Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me
grandpa pete
PostPosted: Fri Apr 11, 2014 9:46 pm    Post subject: Reply with quote
UPDATE ;
This works great on type 3 engines too !
63 two fold rag
Tom Powell
Tom Powell is offline
PostPosted: Fri Apr 11, 2014 9:59 pm    Post subject: Reply with quote
engine dolly
Aloha
tp
oscarsnapkin
oscarsnapkin is offline
PostPosted: Sat Apr 12, 2014 1:15 am    Post subject: Reply with quote
Anyone ever use a pallet jack to install/remove a Type 4? Not quite sure if it would go high enough.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
Brian
Brian is offline
PostPosted: Sat Apr 12, 2014 10:41 am    Post subject: Reply with quote
Maybe if you put a banana crate on the pallet jack? Or some sort of table to put between the jack and the motor. From my experience, they only lift about 7 inches.
I have my eye on one of these:
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
