Dave Samba Elder
Joined: July 11, 2002 Posts: 2693 Location: The Forest Moon of Endor, in the Redwoods
Posted: Thu Oct 02, 2003 9:10 am Post subject: |
...took a leak on an electrified fence. The worst part was, I could see the spark travelling the "current path" but it was too quick to do anything about it. Went from falling-down drunk to stone cold sober in about 1/100 of a second |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Thu Oct 02, 2003 5:09 pm Post subject: |
YIKES!!! :crazyeyes: _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
obus Samba Member
Joined: March 08, 2001 Posts: 11072 Location: just off Garden State Parkway Exit 81
vegabok Samba Member
Posted: Thu Oct 09, 2003 6:47 pm Post subject: Fender Removal |
Never be angry at your girlfriend and reverse out of a tight parking spot without paying attention. I did it and my front left fender met a metal girder and the back part of the fender was ripped away from the body and folded under into the tire. I was able to bend it out to get the car to roll, but all those little nuts in the body were sucked out and the sheetmetal around them were all puckered up. Oh, and about the distributor cap not on when trying to start, I do it all the time, and I did it this morning.... _________________ http://www.vegabok.com
Not Quite Stock ACVW Club |
deadmansvw Samba Member
Joined: August 28, 2003 Posts: 151 Location: caliente nevada
Posted: Sun Oct 12, 2003 12:43 pm Post subject: |
now that is some funny shit _________________ 55oval..... |
Posted: Sun Oct 12, 2003 12:47 pm Post subject: |
tryin to move the sqr bk aginst the wall with 3 1/2 ton jack with none of the wheels on it and dropped it on the ground stupid move tryin to catch it one person 3ooo pounds ya right _________________ 55oval..... |
Fish Samba Member
Joined: December 05, 2000 Posts: 5564 Location: OB. It's beside the point.
Posted: Wed Oct 15, 2003 4:51 pm Post subject: |
A friend bought an old rabbit convirtible. I went over to his house to check it out. Out of habbit I went to the rear and opened the little hatch. At first I was supprised and then I said DUH! _________________ Prosit!
# 303 and #156
RobzKombi Samba Member
Posted: Fri Oct 17, 2003 3:21 pm Post subject: |
Never NEVER pull the sparkplug wire to try and turn the engine off DUHH WHILE gas is being spewed all over the engine compartment. Never again DOH |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Sun Oct 19, 2003 11:37 am Post subject: |
steped in dog shat then got into the beetle. _________________ 77 Westy - Cape Cod Sage
LLAP |
del Samba Member
Posted: Sun Nov 02, 2003 9:01 am Post subject: |
you buy a non running vw. spend a few days working and getting parts to make it run. once you get it running, you're so excited you just have to take it out for a test drive...only, you forgot to check to make sure the brakes work. |
johann_24 Samba Member
Posted: Sun Nov 02, 2003 2:04 pm Post subject: |
Nearly tore apart the engine trying to figure out why it wouldn't start after tuning it up, only to find the distributor cap wasn't on. _________________ When you're in up to your ears, keep your mouth shut.
'63 Classic resto bug |
VW Addict Samba Salesman
Posted: Sun Nov 02, 2003 2:57 pm Post subject: |
Didn't take me long to answer this one.
When I was younger, I was tearing apart my lawn mower..it was having trouble starting. I took the cyloniod out, tested it, and saw it was ok. I put it back in, and the lawnmower would still not work! So i figured it was the electrical going to the ignition to the starter/cylinoid. So I was connecting both ends of the cylinoid to a metal screw driver, and sparks were comming out, and I had done this about 40 times that hour, and alot of heat and energy were getting into that metal on the screw driver.
What did this dummy do? Ya...the phone rang, so I grabbed the screw driver and when I grabbed it, I grabbed it in the metal. It hurt so much... I still have a scar on my hand. It burnt through my skin, even though it was only on me for about a tenth of a second...I learned my lesson!!! |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Fri Nov 07, 2003 5:12 am Post subject: |
i can also say that having beetle battery clamped down and an insulated lid on it is a good idea. mine started burning with 3 year old boy belted into kiddy seat right above it!
no serious damage to son or car tho', just a load of new wires. i was quick with fire extinguisher.......
more recently, like this week i thought i'd move a bus that's been sitting at home for a year and a half. someone had constructed a fairly primitive wiring system for 2nd battery so i'd ripped that out but had left a relay which was screwed to the engine room floor just inside the right hand corner a few inches from the engine hatch corner.
now i'd been in this engine room lotsa times, but i'd never actually shut the lid with the engine running..............
sparks and smoke and flames in that order but ten times quicker than it takes to read this!
the spring thing that holds lid open had touched the relay when closing, probably only on the terminal that's live with the engine running.
again fortunately no serious damage, but that relay is in the trash can now.
or how about fitting a 71 axle to a 72 bus and then finding that the 72 calipers wont fit and you've already sold the 71 calipers a year ago.
i got pretty good at changing axles quickly tho'. |
kingkarmann Samba Member
Posted: Sat Nov 08, 2003 12:33 am Post subject: |
Hey Dad , don't worry , I can make it to work with a busted belt. My 1st Ghia was a 67. Bought it for $105.00 in 74. It is amazing how much oil smoke poured out of that thing Had to put my face real close to the glass to see where I was going. I pulled into the parking lot with smoke just a rolling out of it. Dad was ready to call the fire dept. Who knew the belt cooled the oil too _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
1973 1303S Samba Member
Joined: July 14, 2003 Posts: 550 Location: Sheffield, England
Posted: Mon Nov 10, 2003 4:51 pm Post subject: |
don't assume you can reverse that little bit further before hitting the gate or you'll stain the paintwork with 2 black circles!
check the car is out of gear before turning the key - i was leaning into the car & it shot forward dragging me with it! _________________ don't forget to flash & wave! ( . )( . ) |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Mon Nov 10, 2003 5:33 pm Post subject: |
1973 1303S wrote: |
check the car is out of gear before turning the key - i was leaning into the car & it shot forward dragging me with it! |
I did this with my bus... and it ran over my foot... That hurt. _________________ -Andrew |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Wed Nov 12, 2003 2:04 am Post subject: |
Thankyou everyone, i now feel like a damn genious. _________________ To his their own PBJ
Pl@y@ #1 |
moxnix Samba Member
Joined: September 11, 2003 Posts: 667 Location: Mpls Minn.
Posted: Fri Nov 14, 2003 4:26 pm Post subject: |
My dumbest stunt was with a buddys 67 Ford Galaxie vert in high school he hauled in back from ND, and we had it running around the nieghborhood when it stalled out and wouldnt fire back up. I had the bright idea to grab onto the coil wire as he was cranking it- Not so much fun. Also later that same year, I was drving my 71 bus and lost power- pulled over to find major gas leak... Couldnt find the source- so I actually told a buddy to crank it so I could find the leak! Poooof!! Like a freakin mushroom cloud _________________ Ritterlich im Kriege, wachsam für den Frieden |
MGKrebbs Samba Member
Joined: September 21, 2003 Posts: 19 Location: St. Louis, MO
Posted: Sun Nov 16, 2003 7:53 pm Post subject: Never work on your car when you're tired. |
Hooked battery cables up backward. I know that black is + and red is - in my bug, but I was tired. It's hard to overcome the instinct that black is - and red is +. Had to re-polarize my generator, change some fuses and my turn signal relay has been moody ever since. |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Tue Nov 18, 2003 6:51 am Post subject: |
Owning a NON-Air cooled VW with a Turbo! It cost me $200+ just to have the Turbo adjusted and I owned the car for 6 months of which 3 were spent in the Desert. Sold that Biznitch on to buy a 56 Oval. Like I said only once and I will NEVER do it again!!! _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
