boxertje53 Samba Member
Posted: Thu Dec 28, 2023 1:20 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Almost 10 years ago we bought some parts and a few cars, in this lot was this ugly unfinished baja project. My son and i decided to finish it.
We fixed al the sloppy welding and sprayed the car.
And then,.....it becam again an unfinished project. |
Posted: Thu Dec 28, 2023 1:21 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Posted: Thu Dec 28, 2023 1:25 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
At that time i found this topic and decided to mount the bus gearbox that was lying in the workshop, so plans wher made but, lots of other projects needed our attention so the baja collected dust for several years. Until recently we started again . |
Posted: Thu Dec 28, 2023 1:44 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Unfortunatly there where no sizes ,just foto's. So i had to eyeball eveything.
The rods are made of rectangular tubing 40 *20 millimeter .
I used super beetle track rod control arm bushings because they are easy to obtain and easy to replace. A friend made small tubes in the richt dimensensions so the bushing could be pressed in.
Posted: Thu Dec 28, 2023 1:56 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
The large mounting plates are made of 8mm steel . I took measerments with a sheet of paper and rubbed with dirty hand over the holes, then transfered it to the steel. |
Posted: Thu Dec 28, 2023 7:12 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Posted: Thu Dec 28, 2023 7:16 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
A small problem just came up, my bushings have a 10 mm hole, so the lower mounting point has a 10 mm bolt. The shock absorber has a 12 mm mounting hole ( i think 10 with a sleeve in the shock will not do) . |
dustymojave Samba Member
Posted: Thu Jan 25, 2024 1:38 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Looking at the pictures of your radius rods, you can probably ream out the inner diameter of the bushings to 12mm with a drill bit. Either in a hand held drill or a drill press. I've done that many times with shock end bushings going from 12mm to 1/2". The 1/2" fine thread grade 8 bolt is much stronger than a 12mm 8.8. _________________ Richard
SoCalBajas Member
