Glenn Mr. 010
Joined: December 25, 2001 Posts: 76976 Location: Sneaking up behind you
Posted: Mon Aug 28, 2023 12:39 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
shanered wrote: |
Glenn wrote: |
cdennisg wrote: |
Glenn wrote: |
Gotta be a mess to replace the oil filters. |
Maybe. Plenty of modern cars have filters like that (usually just one) and are very easy and tidy to change. I am guessing it helps to have a relief valve at the bottom of that filter housing, so oil has a chance to mostly drain out of the filter before you remove it.
Your picture is of a Subaru... I have 2 of them. There's flanges around the filter that all the oil drips into.
Most filters have a anti-drainback valves so they are not empty at startup. There's oil in the filter and with that double mount, it will run down the engine. |
of course Glenn drives a Subaru |
For a everyday driver... they sure are safe.
I walked away.
_________________ Glenn
Member #1009
#BlueSquare |
shanered Samba Member
Posted: Mon Aug 28, 2023 12:44 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
monstrosity....
my bad
slayer61 Samba Member
Posted: Mon Aug 28, 2023 1:11 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Just let it die fercrissake! _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Mon Aug 28, 2023 8:54 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
So, what exactly are we looking at here?
Custom carb-mount with a carb I don't recognize (plus a terrible accelerator-cable angle, won't last long), custom oil-breather box welded up from remains of original (with additional valve-cover breather collection-box), pre-cleaner foam filter tied onto filter with paracord, stock coil in non-stock location, stock generator, fuel-pump delete (with added brace for heavy carb), three-piece intake with preheat deleted in favor of aluminum foil, heater-boxes replaced with J-tubes, fan-shroud horns plugged, aftermarket dizzy, voltage-regulator moved to engine-compartment, messy unsupported wiring, lower sled-tin zip-tied loosely in place, aftermarket crank-pulley, and no front pulley tin at all!
Did I miss anything? (are the case-halves mismatched, or did only one get cleaned/painted? Maybe a GEX?)
Quite a mess! Looks incomplete/hasn't been run long or at all in current configuration. _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Posted: Tue Aug 29, 2023 7:32 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
the samb
Posted: Tue Aug 29, 2023 8:26 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Fish Samba Member
Joined: December 05, 2000 Posts: 5567 Location: OB. It's beside the point.
Posted: Tue Aug 29, 2023 10:20 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I don't understand why you would post the picture of the motor in this "come see the horror" thread, wait for someone to knock it down, then defend it? Wouldn't your own build thread be better? Where you could explain first why you built it this way? _________________ Prosit!
# 303 and #156
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Tue Aug 29, 2023 11:27 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
My favorite part is the two distributor caps!
I think one of my engines got posted in this thread too because I had the fuel filter in the engine compartment _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
Posted: Tue Aug 29, 2023 1:50 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
i set the little one on top and it arcs across. its called split fire maybe you've heard on it. |
Posted: Tue Aug 29, 2023 1:53 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51175 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 29, 2023 2:35 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
So... basically just whoring for attention? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 29, 2023 5:18 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I love that oval a few pages back. |
Posted: Tue Aug 29, 2023 5:20 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Oh, it'll function well enough for a surprisingly long time!
I didn't say it wouldn't run, I just noted all the mods/hacks done, some of which affect longevity.
(I didn't spot the hose-barb-ception at first glance, glossed right over it XD)
These are tough little relatively simple engines, after all.
So, what sort of carb do you have on there, anyhow? Now that we know it's yours. I'm curious! _________________ Two Bugs-
Posted: Tue Aug 29, 2023 5:24 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
busdaddy wrote: |
So... basically just whoring for attention? |
Just wanted to share something different and I don't mind being made fun of because it works well. Dare to be different. |
Posted: Tue Aug 29, 2023 5:32 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
VeeDubWolf wrote: |
So, what sort of carb do you have on there, anyhow? Now that we know it's yours. I'm curious! |
only carb that won baja 6 years in a row. Its a Zenith. |
Posted: Tue Aug 29, 2023 5:38 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
shanered wrote: |
Nice! I'll have to play around with alternate carbs one day, once I build a good engine for each of my bugs, and a couple spares from used parts. _________________ Two Bugs-
Posted: Tue Aug 29, 2023 5:57 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Here ya go
Posted: Tue Aug 29, 2023 6:31 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
running hot, look at that blueing, and an over priced and primitive distribution of spark. That blueing looks really awesome tho. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2235 Location: HdG, MD & NJ
Posted: Wed Aug 30, 2023 9:11 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
The blueing will soon be covered in oil. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
