Jbc1116 Samba Member
Joined: January 08, 2016 Posts: 12 Location: Berkeley
Posted: Mon Jan 11, 2016 6:14 pm Post subject: Re: What's this Ghia part and Where does it go? |
The white thing was just cardboard. I opened it up and it was a hose or vent leading somewhere behind.. Sorry no clue.. |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sun Jan 31, 2016 12:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
This came with My car in a box, It measures 12 1/2" and is threaded with a point at one end and a slotted head on the other, I'm guessing part of a swing axle or torsion adjusting tool?
_________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
c21darrel Samba Member
Mark33563 Samba Member
Joined: November 13, 2005 Posts: 1667 Location: Tampa Bay. FL
Posted: Tue Feb 02, 2016 6:22 am Post subject: Re: What's this Ghia part and Where does it go? |
Very handy tool if you are playing with height (rear anyway) or several cars or just trying to find the 'right' height for your own ride. _________________ ----------------
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24 |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Sun Feb 21, 2016 3:20 pm Post subject: Re: What's this Ghia part and Where does it go? |
What goes in these two holes in the b-pillar of the convertible frame if anything?
Also where can I find and what do I call the trim that goes over the ridge where the long red line is?
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sun Feb 21, 2016 11:10 pm Post subject: Re: What's this Ghia part and Where does it go? |
kman wrote: |
That looks like the area that the hook retainer for the top screws in. |
kman Samba Member
Posted: Mon Feb 22, 2016 4:21 am Post subject: Re: What's this Ghia part and Where does it go? |
djway3474 wrote: |
kman wrote: |
I have those. I had the bases and made stainless steel hooks out of a couple of bolts.
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3924 Location: In Molinya Orbit
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
kman Samba Member
Posted: Mon Feb 22, 2016 6:15 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks. I kept searching for trim or plastic trim and couldn't find it anywhere. Also I have to say that is a pretty useless place for a coat hook, especially when the top is up.
"Are you looking into replacing the original attachment hardware for the side panel cover strips?"
Not really too important for me. If one of the stock plastic trim attachments fit from the auto store (or even a stainless buttonhead bolt) I can just go with that. |
Posted: Mon Feb 22, 2016 6:48 am Post subject: Re: What's this Ghia part and Where does it go? |
kman wrote: |
Also I have to say that is a pretty useless place for a coat hook, especially when the top is up. |
Agreed And this isn't an ideal coat hook either, even with the top up...
slexik Samba Member
Posted: Sun Apr 24, 2016 2:38 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hi there !
I'm new kg owner from belgium and I'm changing the 2 floorplans.
On this picture I have seen the same button than I had on my older floors but don't know the utility and the name.
Is there still available and where ?
Thank you.
Kind regards,
SLeXiK _________________ Karmann Ghia '67 L50K : restoration in progress |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2664 Location: Gullane, Scotland
slexik Samba Member
danielsan Samba Member
Joined: September 18, 2008 Posts: 802 Location: Carson City, NV
Posted: Sun Sep 04, 2016 9:59 am Post subject: Re: What's this Ghia part and Where does it go? |
Hope you don't mind waiting 8 months for a reply. Old school mod. Instead of using the heater boxes to heat the cabin you us the fresh air system to cool the engine. You run the fresh air vents to the back and you have enough air for the carbs and the shroud without having to replace the 69 decklid with a later model. Also increases the debris that makes it on the engine unless you also find a way to incorporate an air filter. |
Rob KG Samba Member
Joined: June 13, 2015 Posts: 12 Location: Suwanee, GA
Posted: Wed Sep 07, 2016 3:57 am Post subject: Re: What's this Ghia part and Where does it go? |
Hi all,
I'm relatively new to the VW world. I have a 74 KG convertible and found this in the trunk. Anyone know what it is/where it goes? For what it's worth, the car has A/C.
Thanks,
Robert
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1051 Location: Jacksonville, FL
Rob KG Samba Member
Posted: Wed Sep 07, 2016 5:52 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks fellas. Something tells me this isn't going to be fun re-installing. I can only hope there's one installed and this one is extra.
Robert |
Posted: Wed Sep 07, 2016 8:10 pm Post subject: Re: What's this Ghia part and Where does it go? |
Rob KG wrote: |
Robert |
It is an easy one to get at if you remove the breast plate. There's plenty of room to get at it that way. I had them reversed and corrected them in that manner.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
