2fast4u Samba Member
Posted: Sat May 21, 2011 4:25 am Post subject: |
If 78 busses come with cats, why wouldnt mine have one? |
babysnakes Samba Member
Posted: Sat May 21, 2011 4:52 am Post subject: |
The emission systems are slightly different for Ca. models. They have the cat. My '78 does not have one either. |
Posted: Sat May 21, 2011 4:53 am Post subject: |
How much would it affect performance? |
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1354 Location: Anaheim, California
Posted: Sat May 21, 2011 2:35 pm Post subject: |
It really doesn't. _________________ 1978 Transporter, 2.0L FI |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Sat May 21, 2011 6:55 pm Post subject: |
I have one:
Does the discoloration and cruddiness on the label look right?
The pump is maybe a bit over two years old and has maybe 10 hours use on it, mostly stationary in the yard.
I'm just worried it was overheating or something.
Since I took that photo this morning I've turned it around and put a rubber block between it and the bulkhead. Not optimal but it has changed the hammering to a tapping. It'll do for now. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue May 31, 2011 2:06 am Post subject: |
alternator question here:
If i have a slow drain, and the charging system isnt the greatest, would the regulator have much of an effect on any of that?
i realize its important for charging etc, but would it cause the drain and the lack of good charge?
if its not that, i would be putting the discharge on my radio, which i am 85% sure is it, and the charging issue as a bad Alternator. does that make sense, and does that theory work?
Also, iv been reading up on the alternator, and wanted to upgrade, and was wondering if a 110 amp alternator (or close to it) would work well for keeping two batteries charged, and to run a 15-16 speaker system, nothing crazy, but lots of speakers, with a single 8-10 inch sub. i was also thinking about HIDs, foglights, and brighter tail light setups for visibility and being seen.
would 110 work for what im attempting to plan out? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
smoovie Samba Member
Joined: September 04, 2009 Posts: 50 Location: Monroe, Michigan
Posted: Sat Jun 04, 2011 11:37 am Post subject: |
What is this clip/spring in the trans called? Anyone know where I can get one? Thanks.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 04, 2011 12:23 pm Post subject: |
Ratcamper: looks like a stain from a fuel drip.
Stu: disconnect the stereo and see if the draw stops, it's not often a reg can draw power when off but a bad alternator could, as for higher amps?, 70 is likely the best you'll get.
Smoovie: that's a throwout bearing retainer clip, every VW parts seller has them. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sat Jun 04, 2011 1:36 pm Post subject: |
no and no. Buy a new throwout bearing if that spring broke and the TO is old. If it was a new spring that broke send the TO bearing back. They come with them.
113 141 177C
113 141 178C _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Sat Jun 04, 2011 1:38 pm Post subject: |
Ok. It's old The Bay is a '71. Looks like an aftermarket engine block. I had to pull it to clean the gas tank and thats the way the clip was. I guess I'll buy a new one.
Thanks,
Gabe |
SGKent Samba Member
Posted: Sat Jun 04, 2011 1:45 pm Post subject: |
that spring may have just come off and you may be able to reuse it. They come with a new TO bearing and normally you replace the TO when you replace the clutch. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jun 04, 2011 5:34 pm Post subject: |
when i got the westy a year ago, the guy had mentioned that the reason he parked the bus in the first place was because he hated having to charge it every few days, or after every time he got home. When i have disconnected the radio in the past, it hasn't solved the issue. what would the next idea be? the only things electrical that i have found are a set of reading lights, with a on off switch, a propane heater with no electrical connections, and a radio, and the radio came out before, not solving the issue. would any of the camping things like the fridge or the 120 volt converter affect it at all?
Thanks
Stuart _________________ Stuart Zickefoose
206-841-7324
[email protected] |
SGKent Samba Member
Posted: Sat Jun 04, 2011 5:55 pm Post subject: |
Stuartzickefoose wrote: |
Thanks
Stuart |
Stuart - anything that draws electricity will discharge the battery(s). If the battery(s) are weak they will fail quicker. The average life of a battery in North America is 40 months. Once you have elminated the known culprits then pull fuses and see which one sparks when you put it back. If the battery(s) are old they may discharge on their own even without being hooked up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jun 04, 2011 6:11 pm Post subject: |
SGKent wrote: |
Thanks
Stuart |
Stuart - anything that draws electricity will discharge the battery(s). If the battery(s) are weak they will fail quicker. The average life of a battery in North America is 40 months. Once you have elminated the known culprits then pull fuses and see which one sparks when you put it back. If the battery(s) are old they may discharge on their own even without being hooked up. |
i have heard of the fuse idea before, but forgot about the spark aspect....i had heard pull it then see if the prob still happens, and i had heard if the battery cable sparks when you put it on then there is a discharge, but i never put the two together. ill try that and let ya know how it goes! thanks!
batteries were both good a cuple months ago, but ill be replacing them soon because they have been sitting a while and i get good used ones for about 20 bucks from work.
206-841-7324
[email protected] |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sun Jun 05, 2011 12:52 pm Post subject: |
Stuart |
$20 per month for batteries
save up for six months and get two new batteries that will last for three years
aloha
tp |
Posted: Sun Jun 05, 2011 1:16 pm Post subject: |
Tom Powell wrote: |
Stuart |
aloha
tp |
actually the quality of batteries are pretty nice. i picked up a redtop optima for my golf a while back for around 15 bucks....still works about 3 months later, still strong. ill hold off on new ones for now. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Jun 05, 2011 2:25 pm Post subject: |
[quote="busdaddy"]Ratcamper: looks like a stain from a fuel drip.
Well that's okay. It probably happened during the original car park installation or the downstream hose replacement I did whenever it was. Oh yes, when the progressive on the type 4 started messing up, so a bit under a year ago. That carburettor is still doing fine by the way, bolted on to its new host. except...
Another stupid question.
Both the 1800 type 4 and the EA81 (Subaru 1.8L OHV single port) had a tendency to blow smoke when I goose the accelerator or put it down in any more than a very gradual manner. It is far more noticeable on the EA81. The smoke kind of peters out after about 10 seconds or so. I'm guessing it's the accelerator pump has a bit too much squirt. Do I scale it down by knocking out the pump lever pin and putting it in the hole which provides less movement (top one? I'd know which way if I had it in front of me). I've heard using a different pump jet too, but I can't understand how that would reduce the charge, rather than just prolong it. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
SGKent Samba Member
Posted: Sun Jun 05, 2011 2:28 pm Post subject: |
Stuart - take the batteries out of the bus. Check the water level if either is a type that requires water. Fully charge them. Let them sit three or four days and take them to Autozone, O'Reillys etc and do a free load test it. See if they are good. When a battery fails it is common for the plates to slowly disintegrate and fall down to the bottom of the battery. The debris causes the battery to discharge itself. Maybe one of the batteries is draining the other one as well as itself. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jun 05, 2011 4:07 pm Post subject: |
Another un-threadworthy question.
Roughly how long are the rear lap seatbelts?
I can't just buy one from a VW parts seller because the seatbelts need to bear the AS (Australian Standards) patch. Can't buy secondhand as that's illegal, so I need to get a new one which I honestly prefer anyway.
If you are wondering I can't use the old one for two reasons. First and foremost it was a badly installed lap sash. The top point went through the square tab thing that I think has something to do with the spare tyre. That wouldn't hold anyone. The other one is quite simply because I set it on fire while doing a rust repair. A tiny ball of slag must have gone on a long skip and found a nice cosy place to live. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
