akajenfer Samba Member
Joined: August 16, 2016 Posts: 2 Location: Lincolnton, GA
Posted: Tue Aug 16, 2016 11:57 am Post subject: '67 Split Window Bus Dash Question |
Hi!
I have a '67 split window dash that I came across and I've been trying to find some pricing info on it so I can sell it. I don't want to over/under price myself. I was hoping you nice folks on here might be able to help a girl out.
https://goo.gl/photos/idhxzSnReFkYvKfE8 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13286 Location: Tejas!
Posted: Tue Aug 16, 2016 12:08 pm Post subject: Re: '67 Split Window Bus Dash Question |
someone else will give you more detail but it's not a 67 - they have a different radio hole.
couple hundred at least as the radio part is not hacked. If the speedo and gas gauge are good that will be more.
look at the back of the gauges - there will be a date (but they may not be the originals) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24774 Location: Olympia Wash Rinse & Repeat
Posted: Tue Aug 16, 2016 12:19 pm Post subject: Re: '67 Split Window Bus Dash Question |
1962-66 dash.
Best way to price, it is to do a search of the classifieds, and put a price that is less than most are asking for their's. _________________ In Stereo, Where Available! |
Posted: Tue Aug 16, 2016 12:31 pm Post subject: Re: '67 Split Window Bus Dash Question |
Thanks so much Erik G! It had a business card with '67 on it taped to the back so I was semi guessing. I had someone tell me it was in that vicinity. I will check out the back of the gauges when I get home. |
Clara Samba Member
Posted: Tue Aug 16, 2016 2:18 pm Post subject: Re: '67 Split Window Bus Dash Question |
I would think 62, tell us what the gauges say. :)
No hole for red light for emergency flashers, which would be to left of speedo. 66 doesn't have that either, but, has more holes for switches to right of dash. I only see one switch hole to right of dash.
But 62-66 is a good guesstimate. Someone could always add holes.
ads for "dash'
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
Yours has a speedo, gas guage, and ash tray. I'd think it would sell at $200.
Sometimes things sell if you ask more, but you may have to wait longer. |
Posted: Tue Aug 16, 2016 2:45 pm Post subject: Re: '67 Split Window Bus Dash Question |
Clara wrote: |
, has more holes for switches to right of dash. I only see one switch hole to right of dash. |
Think Clara means right of speedo pod, instead of dash. Yes, one can always add in later holes, but not anywhere as easy to add in 1967 radio hole or earlier pointed top corner speedo pod. _________________ In Stereo, Where Available! |
Clara Samba Member
Posted: Wed Aug 17, 2016 8:03 am Post subject: Re: '67 Split Window Bus Dash Question |
I left out that euro spec buses did not have emergency lights as early. While a US spec 63-66 would have the red light to left of speedo and 63-66 would have the emergency switch to right of headlight switch, if euro spec 63-66 it would not.
Anyhow, it is unlikely it would be euro in the US, and this would not affect value. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
olliehank47 Samba Member
Posted: Wed Aug 17, 2016 8:14 am Post subject: Re: '67 Split Window Bus Dash Question |
Clara wrote: |
No hole for red light for emergency flashers, which would be to left of speedo. 66 doesn't have that either, but, has more holes for switches to right of dash (pod). I only see one switch hole to right of dash.
ads for "dash'
You can't dismiss the dash as a '67 due to the radio opening as early '67's had the smaller hole. However, I think Clara has nailed it due to the lack of holes for the emergency light switch. That would eliminate this particular dash as a '67, except if it was a Euro. |
