Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Sat May 10, 2014 9:28 am Post subject: |
They may also cross or not cross at whatever rpm if the scales left and right are placed differently. There is no magic relation involved in this. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sun May 11, 2014 8:32 am Post subject: |
Alstrup wrote: |
Hello.
The torque numbers are in Newtonmeter so the curves will not cross at 5252 as when the torque is measured in pounds.
T. |
My bad, I didn't look closely at the graph before I asked the question.
Thanks |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Tue May 13, 2014 10:13 am Post subject: |
Budget 1776 (all used parts except bearings)
Dual relief case, full flowed
Stock German 69 crank
stock German rods
stock German flywheel
90.5 pistons and cylinders I found here in the classifieds
CB 2241 cam 240*@.050" .424" With 1.1 rockers
Brazil lifters (cam and lifters were broke in together and had many miles but checked out!)
G03 heads I bought from DRD a few years ago. 40x35 valves, single heavy springs, 55cc chambers.
8:1 compression
Aluminum pushrods and stock 1.1 rockers
Built it for a friend and had it in my bug for a while with dual HPMX 40 carbs, CB Magnaspark, CB 1.5" merged header with a Bugpack hideaway muffler.
It is pretty damn quick, 3-5k is its happy place although I rarely rev it to 5 because of the stock crank. It will be getting dual kadrons and a 1-3/8 exhaust with heater boxes so that might tame it a bit. A solid easy-to-build combo for the first time builder, the only problem is once you drive it you'll wonder what a 2332 will do _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7229 Location: Videbaek Denmark
Posted: Fri May 16, 2014 11:46 am Post subject: |
Friday again.
This engine was designed to pull a freeway flyer transmission in a type 1 (4,125 R/P & 0,82 4rth) that covers a lot of miles per year. So everything was chosen with durablity and a wide torque band along with decent fuel efficiency in mind. It was supposed to be a sub 2liter engine, but I had this great old crank on the shelf and was allowed to cross the line just a little bit. As you can see from the dyno sheet it pulls more than 180 Nm from 2500 to over 5000 rpm. Which makes it a great daily driver that keeps up with traffic quite well.
Good used dual relief case, modified for full flow.
NOS 74 mm Scat steel crankshaft
200 mm flywheel. 8 dowelled and lightened 1 kg.
KEP stage 1 Pressure plate
All dynamically balanced
Exedy super disc.
Stock rods, rebuilt and balanced.
NOS Bugback 4062-10 camshaft. (240 @ 0,050”)
CB lightweight lifters.
26 mm Shadek oil pump, blueprinted.
1,3 L. CB thin line oil sump.
CB Cromemoly 8 mm head studs.
Mahle 94 mm pistons and cylinders. Balanced.
GO3 ”041” cylinderheads, 39 x 35 mm valves, Ported, (154 cfm @ 25”) Scat sgl. HD valve springs, CB Cromemoly retainers. 9,0 – 1 CR.
CB HD rocker shafts.
Porsche style adjusters.
Manton push rods.
German 009 distributor w. Ignitor module. Pertronix 3 ohm coil.
CSP 30 hp fanshroud w. doghouse & fresh air.
NOS dual 40 mm Dellorto´s on CB offset manifolds.
1½" heaterboxes. BAS 1½” ”super comp” header. 2 Simons 2” oval mufflers in line, one on each side on the engine. Very subtle sound.
Posted: Fri May 16, 2014 10:28 pm Post subject: |
Alstrup wrote: |
Line bored dual relief case, modified for full flow.
CB 69 mm counterweighted crankshaft
CB 200 mm flywheel. 13½ lbs.
Exedy super disc.
Unitech HD rods, ligthed 20 gr. (545 gr) Rebalanced.
Cam: A variant of the Web 110 cam. 256 degr. @ 0,050”. 0,495/0,435” lift. 108 LC.
CB 1,3 l. thin line oil sump
CSP full flow cover.
AA 94 mm pistons and cylinders. Checked, but in balance.
CB 044 cylinderheads, 40 x 35 mm valves, Ported to my stage II. (170 cfm @ 25") Oteva sgl. valve springs, CB titanium retainers. 9,8 – 1 CR.
ACN aluminium push rods.
CSP 1½” street sport exhaust system
Pretty cool to compare the 1915 and 2054, I find it interesting that the 1915 only made 10 more HP than the 2054 given the bigger heads, cam, and higher CR. The two engines made almost identical HP @ 5200 rpm, The 2054 has a better torque curve too 151 FT LBS to 140, again peak torque is at almost the same RPM.
Very educational!! _________________ 71 Super - Backroad Thrasher
Posted: Sat May 17, 2014 1:50 am Post subject: |
I chose driveability over the last hp with the 1914. "looks" was also a player when the exhaust was chosen. If I had chosen a 1 5/8" header and 1 mm larger venturies in the carbs the 1914 would have pulled about 147 hp, maybe even 150, but would also have lost some lower end driveability.
T |
57baja Samba Member
Joined: April 15, 2008 Posts: 1166 Location: Kaddie Shack Temple City
fozzymark Samba Member
Joined: January 23, 2008 Posts: 22 Location: st. petersburg florida
Posted: Sat May 24, 2014 2:47 pm Post subject: marks new 2276 |
case: empi supercase 94 mm rimco prepped
piston /cylinders: mahle 94 mm type b
rings: total seal 94 mm
crank : 82 mm drd
rods :5.4 h beam
pushrods: cb Chromalloy
pushrod tubes drd o-ring
bearings: silverline , mahle
flywheel : 12.5 lb
cam: drd 290
lifters: drd 28mm
cam gear : cb billet
heads: drd L5
rockers: cb superstock rhino
oil sump: gene berg 4 qt
valve covers: cb clip on vented
intake: drd custom matchported
carbs: redline Spanish weber 44
linkage: Linksys cable style
oil pump: gene berg 26mm full flow kit
fuel pump: carter rotary
gaskets: erling
distributor: cb magnaspark II , coil pack , and vacume activated black box
wires: 8.2 mm
alternator: compufire 90 amp
fan: welded balanced
tins/shroud: coolcase doghouse shroud and tins
pulley: empi sand seal stock size with broached nut
clutch/ pressure plate: kennedy 1700 copperhead clutch
transmission: benco superstock 3.88 r&p 3.87 1st .82 4th
suspension: sway-away spring plates and torsion bars mendeola kafer bar and transmission stiffy bar, mendeola weld-in rear swaybar _________________ Play Happy
Mark
~ History does not always repeat itself. Sometimes it just yells, "Can't you remember anything I told you?" and lets fly with a club. ~ |
57baja Samba Member
Posted: Fri Aug 29, 2014 9:33 am Post subject: |
1,9 WBX case, modified for aircooled cylinders etc.
82 mm AA crank.
200 mm forged 13 lbs flywheel.
Stage 2 KEP clutch with Exedy disc.
Rotating assembly balanced.
5,4” AA H beam rods.
Web 86B camshaft, installed straight up.
30 mm Shadek oil pump.
94 mm AA pistons & cylinders. 1,15 mm deckheight.
Manton cromemoly pushrods.
044 cylinderheads. 40 x 35 mm valves, ported to my stage 2½ or thereabouts Dual valve springs. 10 – 1 CR.
CB 1,4 ratio rockers.
Scat 5 tab valve covers.
Bosch 010 distributor.
Bosch Blue coil.
Scat 30 hp fan shroud. No doghouse, no fresh air.
External thermostatic controlled oil cooler. (Atomic warrior)
Dual 45 mm Dellorto carburettors, 38 mm. venturies.
Exhaust. Homemade 4-2-1 header. 1 5/8- 1 ¾ - 2” with 2½” Simons free flow muffler. All 304 stainless.
Not the most powerfull 2275 hp wise, but it has an incredible throttle response due to a conservative port volume. Almost like a motorcycle. It also pulls very nice torque in the lower rpm range.
Posted: Thu Sep 11, 2014 11:12 am Post subject: |
2056 type 4
Good used W case.
Stock 71 mm crankshaft.
210 mm flywheel, lightened 1 kg.
Sachs HD pressure plate w. stock clutch disc.
AA H beam stock length rods.
Web 86b/86c camshaft on 104 LC. Installed straight up.
SLR reground type 4 lifters.
26 mm type 1 oil pump, modified to type 4.
Stock 94 mm cylinders bored out to 96 mm. Keith Black pistons.
Manton 3/8” push rods.
”S” cylinderheads, 42 x 36 mm valves, modified to my stage3 (Street) 10-1 CR.
HD rocker shafts with Porsche style adjusters.
009 distributor w. ignitor unit. Pertronix 3 ohm coil.
Dual 40 mm Dellorto carburettors with 35 mm venturies on CB manifolds.
4-2-1 header w. 1½/1 5/8/2 1/4” going into a 2½” muffler system.
CSP upright cooling system with a thermostatic controlled type 1 oil cooler in the stock type 1 position. 30 hp fan shroud with venturi ring.
Pull without belt.
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Oct 27, 2014 8:31 pm Post subject: 2332 cc Dynojet results |
Had my street-strip Beetle on the Dynojet a few weeks ago. Here's the chart (apologies for the poor photo). 2332 cc, IDA's, 10:1 CR, 94 octane, MS230 heads, Raptor camshaft, etc. Best run was 204 HP to the wheels, here's a short iPhone video: http://www.youtube.com/watch?v=M9B_H3eklAo
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
Posted: Thu Nov 27, 2014 6:46 am Post subject: |
1914 type 1 buggy engine.
New mag case.
Std 69 mm crankshaft
200 mm Flywheel ligthened 1 kg.
Stage 1 pressure plate.
All balanced.
Unitech rods. Balanced +/- 1 gr.
Web 163 camshaft. 108 LC
Full flow.
94 mm Mahle cylinders & pistons. Balanced +/- 0,5 gr.
041 ”GO3” cylinderheads. 39 x 35 mm valves. Ported to my stage 1 (Approx) 150 Cfm @ 0,550” at 25”. 9-1 CR
Manton pushrods.
Bolted rocker shafts, stock rockers, Porsche style adjusters.
Pertonix Billet II distributor. Pertronix 0,6 Ohm coil.
Type 3 intake manifolds with 20 mm extensions, 40 mm Empi IDF carbs. 32 mm venturies. Jenvey wide flared stacks.
A1 1½” sidewinder exhaust system
135 hp @ 5600 rpm
192 Nm torque @ 4580 rpm.
This engine pulled better than expected. Normally the short and curvy intakes hurts performance somewhat. This one does´nt seem to care.
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Sun Dec 14, 2014 8:16 pm Post subject: |
Do have any pictures of that 4-2-1 exhaust? That sounds pretty neat.
Thanks
Tim |
mikeandnea7 Samba Member
Joined: January 04, 2015 Posts: 1 Location: Ardmore Oklahoma
Posted: Sun Jan 04, 2015 12:04 pm Post subject: 1967cc stroker |
I'm looking to get more power out of my 1967cc stroker I don't really wanna open the case (it's got less than 1k miles on it) it's got cb super mag heads/ norris 407s cam/ cb crank 74mm/ 92mm mahl pistons/ empi dual 044 carbs (I also have a set of webbers) I was thinking super chager but can't find a kit I don't know enough to just but pieces and put a kit together any input would be great cause I got a score to settle with a duramax (it has a full banks set up and barely pulled ahead ) |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Jan 30, 2015 7:35 am Post subject: |
My old 2332
Mag case,opened up by me
swap meet 84mm Porsche Journals crank
Rods 912 Porsche
94 Mahle
Balanced
4qt Berg sump
W120 cam
113 welded heads 42x37.5's mini wedge by me
stock rockers/ bolted shafts
48 IDA's 40 vents
1 3/4 merged
Tub Buggy 1320lbs w/my fatass
4;12,1:48,1:04
7.9 1/8mile
at 91 MPH _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Fri Jan 30, 2015 8:03 am Post subject: |
2276cc
Mag case opened by MadRacing F.F ect.
Crank again another swap meet special
Scat, Porsche Journal
94 Mahle
Rods 5.325 Carillo's
Balanced
Berg 4qt sump ,30mm pump
W120 10:1cr
044 42x37.5's Ported/Mad Racing
ScatTraxs & modified 48 IDA's
still collecting parts so haven't ran this yet _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Sat Jan 31, 2015 7:47 am Post subject: |
1641cc Daily Driver Bay Bus 3000+lbs
Mag case AE or AH
1 1/2 sump
87 P&C's
CW 69mm DPR crank
W110 cam
40 IDF's 50/115/200 airs and 28 vents
stock size valves 'Fluffed'
1 1/2" bugpact header and dual muffs
034 dizzy on this one
I only get 23-26MPG with 5:37 R&P,195/14's
same spec motor in my 917 and get 40-50MPG ,1800lbs 4:12 R&P 295/50/15's
and very 'Aerodynamic' _________________ 'Black Ice'Drag Buggy 'Turbo'
vwsb74 Samba Member
Posted: Tue Mar 10, 2015 7:12 pm Post subject: |
Hotrodvw wrote: |
2165cc (Berg 78mm crank, AA 94B pistons)
Steve Long Racing XR310-106 cam
SLR parkerized lifters
Autocraft 1.4 rockers
Steve Tims Stage 2 plus heads 42x37.5
Zero deck at the top of the cylinder
.040" coppeer shim makes for 9.5:1 C/R
Shadek 26mm pump, berg relief cover
Full flow oiling, Dog house shroud and cooler
Al's Headers 1-5/8" Merged, black ceramic
A-1 magnaflow Muffler
48IDA's, 3 rd progression hole mod
CB Big Beef manifolds, port matched
178hp at the crank with the belt on, 185ft lbs.
Power comes on pretty good at 2500rpm, but isn't much of a slouch below that either.
http://www.youtube.com/watch?v=6QBssR1hRw4 |
Do you have a dyno graph? I want to see the xr310 perform in every rpm . Thank you! _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
slalombuggy Samba Member
Posted: Thu Apr 16, 2015 7:56 pm Post subject: |
The latest incarnation of my big motor
CB Aluminum case with 3.5mm raised decks 8mm studs. Hoover oil mods for oiling on 1/2 side, grooved lifter bores. Ported inside for better airflow away from pistons and venting out of case.
CB 30mm keyed pump, blueprinted. Oil filter adapter is ported for better flow
CB 84mm crank Buick journals. NOS Kolbenshmidt bearings
CB 5.6 H beam rods. Clevite bearings
CB 2290 cam on custom lobe centers. Double thrust bearings
Competition Engineering straight cut cam gears fully polished
CB Ultra-lightweight lifters
Manton 3/8 .058 wall pushrods
AA true forged 94mm slipper skirt pistons and cylinders. .030 deckheight
EMPI stainless windage pushrod tubes
CB Ultra Wedgeport 46x38 cut to 45cc chambers. CB 650 springs Ti retainers. Matching Big Beef manifolds
Pauter new generation 1.4:1 billet rockers
Scat Stainless Valve covers, not vented. double gaskets, VW bails.
EMPI EPC 51mm carbs with 44mm vents and JAYCEE goodies. Weber 3mm needle and seats, #6 AN inlets
Pertronix billet distributor driven by turned down drive gear. Both drive pinion and crank gear are fully polished Pertronix coil. CB 8.2mm plug wires
Bruch 12lb forged flywheel, Bugpack HD glandnut and washer
Kennedy Stage 1 clutch with ACE/Blackline Copperhead disk.
CB 1 3/4 merged exhaust
Hope to hit the chassis dyno this summer. But it's a monster in my 57.
brad |
