66ratrod Samba Member
Joined: September 22, 2009 Posts: 463 Location: Tallahassee FL (insert funny comment here)
Posted: Wed Sep 29, 2010 2:27 pm Post subject: Judson supercharger parts |
I have found an og judson supercharger that im considering putting on my 66 bus. It's only the compressor, so what parts would i need to get it to work.
Also, I have a 1600cc DP motor, would the judson still work (I have only seen them on very early VW's)
Thanks; Austin _________________ 1966 Standard Bus (No longer a ratrod)
"ACWVs are like having a sick dog that has a 100 year life span and needs constant medical attention... that you ride to work daily."
-Brian
Ojai63dbl Samba Member
Posted: Thu Sep 30, 2010 12:53 pm Post subject: |
you need to goto look at Judson Register (see below)
and check this link
http://www.thesamba.com/vw/forum/viewtopic.php?t=136613&highlight=judson+1600
The short answer is No, for 2 reasons:
1) the Judson was built for a 40hp or 36 hp engine and
2) to get it into the bus youll have to cut one of the cross memebers and still I think the airfilter wont fit
quick review of Judson
2 types out there,
40hp (Type II judson - does not mean for bus)
and a 36hp Judson
the Judson TypeII is a 40hp (1200cc) designed to give mild boost for the small single port engine, thus without overreving the Judson it will not provide boost to the 1600. Overevving can be done but heat loading is an issue. Most people agree that overrevving Judson leads to overheating and failure.
Finally the blower body is one part of alot of other pieces. go to
http://vwjudsonregister.tripod.com/
and see the list of parts and applications for the Judson |
Posted: Thu Sep 30, 2010 1:20 pm Post subject: |
OK thanks for the help, i would have sucked spend $300 on a part I could not even use _________________ 1966 Standard Bus (No longer a ratrod)
-Brian
Posted: Thu Sep 30, 2010 3:31 pm Post subject: |
Now you could shove this in your dad's single cab with an oldschool
single port 40hp and have something pretty different. |
