Empi Sportster Roll Call
Page: Previous  1, 2, 3 ... 30, 31, 32, 33  Next
vwtrey
vwtrey is offline
PostPosted: Tue Sep 08, 2020 4:18 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
didget69 wrote:
vwtrey wrote:
This is probably a dumb question. I browsed through and didn't find the answer.
Was it possible to build a Sportster as a kit, from a set of plans?
Smart answer - yes. A number of them were built from plans.
bnc
Thanks. I'll dig around for more information. I have a good pan with a bad body, and a set of sprintstars.
EarlT
EarlT is offline
PostPosted: Thu Oct 01, 2020 5:45 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
YouTube of test drive:
https://www.youtube.com/watch?v=Ma0uq8UNamE
mads1234
mads1234 is offline
PostPosted: Sat Oct 31, 2020 4:44 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Empi Sportster barn find ... sitting on April-May 1963 pan ... it’s been through a few owners so roll bar has been added and rear floor was cut along with battery box no longer in correct location...now the question is ? Is it the real deal? Everything appears to be correct but no vin tag on pan tunnel ... you can see where the old rivets were for a tag ... also has a number tag welded to the front cowl? Anyone else have a welded number tag on there Sportster?
yankee1919
yankee1919 is offline
PostPosted: Tue Nov 03, 2020 3:58 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
That looks really clean, it almost looks like it could have been made by factory. The only thing I see is the supports to roll bar.
Keep us up to date with the project.
Tony.
yankee1919
PostPosted: Sat Nov 28, 2020 4:23 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Hello everyone.
I hope you are all doing well. Turkey day has past and looking forward to new Empi Sportster updates. I myself will be doing some electrical work, temporary rust prevention painting, doing some preventative maintenance. Next year going to strip the buggy for a much needed overhaul. This will include brakes and some modification to doors.
Let me know some of your ideas.
Don't forget to upload new images.
All best
Tony
flyin' blonde
flyin' blonde is offline
PostPosted: Mon Jan 04, 2021 12:39 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
I bought myself a Christmas present this year, but I'm not sure what it is. It looks similar to an Empi Sportster, but its slightly different, so I'm not sure. If anybody can identify I would appreciate it. It looks too well built to be a home build, but it could be. It sat abandoned in a briar patch for the last 12 years, this is how I got it, missing parts and wheels, drums all rusted stuck. The engine is stuck, probably from rust, not sure if its salvageable, but I hope to get this driving by next summer. I have 3 of the drums loose since, still working on the left rear, I may have to cut the axle nut to get the drum off. My intent is use this around my two acres as sort of a side-x-side, note the pick-up like bed. Its on a shortened pan, most of the body is pop riveted aluminum sheet over a square tube steel frame. Although all of the lights are missing, the mounts are still there, it looks like it was probably street legal at on time.
dustymojave
dustymojave is offline
PostPosted: Tue Jan 05, 2021 1:21 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
Keep in mind that the EMPI Sportster was sold in several manners.
1. Complete turnkey factory built
2. Partly factory made, to be finished by customer.
3. Customer made from plans
4. Imitation made by owner to copy the EMPI Sportster.
Richard
SoCalBajas Member
yankee1919
PostPosted: Wed Mar 31, 2021 11:14 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
I hope all you guys are doing well.
Lets start reposting Empi Sportster pics again, 2021 would be a great year to see old and new images.
Tony
yankee1919
PostPosted: Sun May 02, 2021 10:13 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Hello All,
Many projects going on, time time to wrap them up. Any new new Empi Sportster Pics? its mayday!
yankee1919
PostPosted: Sat May 08, 2021 8:14 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Empi in So Cal is going to have an open house in June. I will post the flyer and if you can make it would be awesome.
yankee1919
PostPosted: Fri Jun 11, 2021 3:34 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Summer is here, lets see some new pics of your Empi Sportster.
atomicmime
atomicmime is offline
PostPosted: Tue Jun 15, 2021 4:37 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
I happened across this Sportster for sale here on Samba about a year and a half ago, and I purchased it mostly for the engine, to use in another dune buggy project I'm working on. When first inquiring about it, I discovered this was a Sportster that Gene Berg and his son Clyde started building, but Gene died before it was completed, and his wife stored it for 30 years at their shop. The man I bought it from had been employed at their shop in the '80s and knew the Bergs, so Dee sold it to him about 5 years ago. I did a very little bit of minor work on it, and it is something like 75-80% completed, but I have decided that my priority is to complete my Manx buggy, so I will be selling this Sportster here on TheSamba. I do have a couple questions about it, which I'd like to get some input on from others here. I know that Sportsters were available in the different levels of completion, so what I'm hoping is that someone here might be able to tell something from the pictures about its production. The welds that are all over the place (see the last pic) and not yet ground smooth indicate it was fabricated to some extent, but I would think not by factory, but did the Berg's do all this welding, or how much of that was required when the kit was built? Purchased from factory in kit form, or built from plans? Thanks in advance!
--Patrick--
'69 Meyers Manx (still a project, but not for long!)
'72 Westy
'79 Super Beetle (now electric!)
'13 Beetle
johnnyniceguy
johnnyniceguy is online now
PostPosted: Tue Jun 15, 2021 7:17 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
atomicmime;
What year is the pan?
Is the tranny of the same era? syncros?
Thanks!
atomicmime
PostPosted: Tue Jun 15, 2021 10:11 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
It’s on a ‘63 pan. The tranny is a ‘67, (long axle).
--Patrick--
'72 Westy
'13 Beetle
coupe415
coupe415 is offline
PostPosted: Fri Jul 09, 2021 8:18 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
My 1968 EMPI Sportster, on a 1960 pan. Take a look! coupe415
johnnyniceguy
PostPosted: Sat Jul 24, 2021 7:47 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Just wanted to thank this forum for all of the great knowledge
that has been distributed here. Due to my maturity and limited abilities; I have posted my Sportster for sale. I attempted this once before as the covid started; and then I pulled it from the market.
Thank You TheSamba for being here. You are most important to the
VW community!
Proud to say I will still be lurking on the Ghia Forum.
Johnnyniceguy
yankee1919
PostPosted: Fri Jul 30, 2021 3:12 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Good luck on the sale and I can relay the The Samba to the new owner.
yankee1919
PostPosted: Fri Jul 30, 2021 3:16 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
"If you can"
Dont eat chickens wings and type at the same time!
atomicmime
PostPosted: Tue Aug 17, 2021 12:58 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
I posted some photos and a question or two just a couple months ago (see about 5 or 6 posts up) about a Sportster project I would soon be selling. Just wanted folks to know that as of today, it is now up for sale here on Samba, as well as S.F. Bay Area Craigslist. Thanks!
--Patrick--
'72 Westy
'13 Beetle
yankee1919
PostPosted: Sun Aug 29, 2021 4:51 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Hello All,
I hope all are well, very interesting times.
Saw some posting on the classifieds for Empi Sportster, wow thru the roof!
Post some pics of your updates.
See you guys soon.
Tony
Page 31 of 33
