hbays Samba Member
Joined: January 15, 2006 Posts: 213 Location: Norman, Oklahoma
Posted: Sat May 15, 2010 10:06 am Post subject: Putting Abarth on my 67 ghia. What to do about heat? |
I'm putting an Abarth muffler on from Steph. I don't see how my fresh air heat exchangers will work so do I need to got to the older 40 hp stale air type and will they work on my 67?
Thanks |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Sat May 15, 2010 1:22 pm Post subject: |
What size engine are you putting in the ghia? I think he makes them up to 1300CC engines not sure though I know a stale 40hp would work . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
hbays Samba Member
Posted: Sat May 15, 2010 1:50 pm Post subject: |
It's actually an 85.5mm x 82mm stock with the wrist pins in the pistons relocated so stock dimensions are retained as far as engine width. 1600 type as41 case. |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Sat May 15, 2010 6:21 pm Post subject: Fresh air 36 |
On my 'modern' 36hp (dog house oil cooler, Pertronix Ignitor, 12 V choke 28 PICT carb, 12v generator), I also use fresh air heater boxes. They fit the stock 36hp muffler with only a slight bit of persuasion. I did have to use an EMPI 36hp style fan shroud with fresh air ducts(although a wide factory non-36 shroud would work, just not look as natural) and I had to modify( i.e., big holes ) a rear breast tin to allow the fresh air tubes to access the heater boxes and narrow 40hp under tins below the push rod tubes between the boxes and the case.
Works fine!
Burly |
hbays Samba Member
Posted: Sat May 15, 2010 8:05 pm Post subject: |
Mine has a non 36 shroud on it now with the ducts. The fresh air hoses have to connect to the top part of the muffler as in the link below. The abarth doesn't have this connection for fresh air hoses. So I didn't know if the stale air 36 hp heater boxes would work or am I missing something here?
http://www2.cip1.com/PhotoGallery.asp?ProductCode=C23%2D35171 |
Posted: Sat May 15, 2010 8:33 pm Post subject: Hbays |
The 'pre-heat' cans fitted to the #3 & 4 exhaust pipes on the fresh air muffler shown in your link coming from the head are 'not critical' to providing heat. Since your Abarth does not have these cans, just use a longer piece of fresh air hose, preferably the factory style cardboard coated aluminum type (the all aluminum tubing will work, it just does not look as good and also deteriorates quicker!). Fitting to the input portion of the fresh air heater box will be tight but can be accomplished. I use a wide screw type clamp to secure the hose to the heater box.
Some folks sell a pre-bent metal pipe to bypass around the upper pipes from the heads, but I have never been successful in making them work and found the simple hose bypass I described above as a good solution. The good quality cardboard/ aluminum hose can lay against the head pipes and not burn through!
Hope this is helpful..............
Burly |
hbays Samba Member
Posted: Sat May 15, 2010 9:15 pm Post subject: |
Ok. Now I read you. So connect the fresh air hose directly to the heat exchanger. |
Posted: Sat May 15, 2010 9:48 pm Post subject: Yes ! |
Tight fit but it works !
Good luck...............
Burly |
Posted: Sat May 15, 2010 9:49 pm Post subject: Correction |
I meant #2 & 4 exhaust pipes. Sorry for the error!
Burly |
hbays Samba Member
Posted: Sat May 15, 2010 10:01 pm Post subject: |
Who makes the curved adapters you were talking about? |
Posted: Sun May 16, 2010 4:53 am Post subject: Adapters |
The curved adapters came with some exhaust systems but since I could never get one to work, I have forgotten who supplied them. They would not bend tight enough to fit closely to the pipes!
Sorry I connot help with this one...............
Burly |
ACTION IS GO Samba Member
Joined: May 08, 2008 Posts: 175 Location: SoCal/Dana Point
Posted: Mon Oct 04, 2010 8:03 pm Post subject: Re: Hbays |
36hplandspeedracer wrote: |
Burly |
Do happen to have a pic of this set up? |
