thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Sat Dec 24, 2011 3:24 pm Post subject: |
I've heard stories about coils breaking off if they're mounted to the fan shroud because the metal is too thin. That being said, mine is mounted to the fan shroud and so far no problems... |
Garner Samba Member
Joined: January 19, 2010 Posts: 128 Location: Columbia, MO
Posted: Sat Dec 24, 2011 5:06 pm Post subject: |
I'm going to guess that a lot of broken fan shroud/coil mounts are as much to do with the vibrations caused by solid mounts as are caused bh off road impacts. I've yet to relocate mine, bit it has minimal time on it with rubber mounts and an adjustable trans strap.
If the movie Contact has taught us anything, its as easy to build two as it is one. Build a second coil mount while you're there and you can run a spare if you want. |
twomonkeysayoyo Samba Member
Joined: November 17, 2009 Posts: 651 Location: Carrollton, GA
Posted: Wed Dec 28, 2011 11:34 am Post subject: |
joescoolcustoms wrote: |
Great to see you making progress!
A suggestion is to replace that one pushrod you bent and strightened. No matter how well it is straightened, the metal stretched when it bent, and it will be the weak link in the chain. I have done it before, and learned the hard way.
As for mounting the coil, keep the main lead as short as possible. The longer the lead, the more resistance it creates. |
It turns out the item I could not identify with my carb kit was a coil relocation mount that situates the coil between the distributor and the doghouse by means of attaching to the case bolt there. Easy enough, and probably a better place than the stock location.
Does anyone sell individual push-rods? These are chromoly. _________________ ---
Looks like trouble. |
Posted: Mon Jan 16, 2012 8:30 pm Post subject: |
Motor together, wiring complete, gas lines in tact, gas tank in place. Valves adjusted and battery charged. Need to set initial timing and see if it will crank. Gonna sleep on a safety checklist and read some initial carb setup info. _________________ ---
joescoolcustoms Samba Member
Posted: Tue Jan 17, 2012 6:41 am Post subject: |
Looks Great!
Did you fill the oil filter with oil before installing?
Check the sump plate to make sure tightened.
All oil lines tight.
Alternator Pulley Nut tight.
All fuel line clamps tight.
All 4 bolts in bellhousing and tightened.
All carb base nuts tight.
Do have a question, the fan shroud hoses look to be plastic coated, if they are won't they melt around the exhaust tubing where it comes out of 2 and 4 cylinder side of the heads? _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
retterath Samba Member
Joined: July 19, 2004 Posts: 661 Location: SW Washington state
Posted: Tue Jan 17, 2012 11:26 am Post subject: |
Quote: |
Does anyone sell individual push-rods? These are chromoly. |
I got custom length pushrods from Crane through my FLAPS. I'm sure they'll sell individuals. (I bought 9 of each size for a 460 ford project) |
Posted: Tue Jan 17, 2012 12:41 pm Post subject: |
Looks Great!
Do have a question, the fan shroud hoses look to be plastic coated, if they are won't they melt around the exhaust tubing where it comes out of 2 and 4 cylinder side of the heads? |
I HAVE filled the oil filter.
7lbs on each sump plate bolt (switched to a billet for superior flatness).
oil lines are too tight to move.
Alt pulley needs a bit more tightening, I think... should I be able to turn the crank with the alternator nut on a serpentine?
fuel lines are tight
bellhousing secure
carbs are tight.
RE: Pushrods, bought a grab bag of crap from a guy at work that included nine pushrods. So I replaced them til I figure out what to do with the chromoly 7 I have. I have not put on the 1.25 rockers, yet. I want to make sure everything works as close to stock as possible and was worried a bit about pushrod tube clearance with the 1.25's.
I need to adjust the clutch, make sure it's not in gear and that should be about it.
Question: What about the oil filler tube hole for the pressure stuff that normally has a hose that runs to the bottom of the air filter? What should I do with that hole? _________________ ---
Posted: Tue Jan 17, 2012 1:05 pm Post subject: |
That question can become a hotly debated topic.
Some say to pipe it into the top of your right carb filter. Some say to run it to a crankcase breather/vent box. Some plumb it into the header collector to pull a vacuum on it. Some put a filter directly on it. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Jan 17, 2012 1:27 pm Post subject: |
Some say to pipe it into the top of your right carb filter. Some say to run it to a crankcase breather/vent box. Some plumb it into the header collector to pull a vacuum on it. Some put a filter directly on it. |
What should I do with it TONIGHT? _________________ ---
Posted: Tue Jan 17, 2012 1:34 pm Post subject: |
Make sure water cannot get in, (if stored outside).
It will vent the crankcase vapors. Since your engine is new and will create some blow by until the rings are seated, you may want to direct it away from the general area so it does not spew oil vapors onto that clean engine. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Jan 17, 2012 3:34 pm Post subject: |
excellent, thanks. _________________ ---
Posted: Tue Jan 17, 2012 5:08 pm Post subject: |
no fire at starter (or no spin at starter) Any suggestions? I haven't checked fuses yet and will have to look at a wiring diagram to see if there IS one. The dash lights dim when I turn the ignition key, but no spin from the rear happens. Didn't smell smoke, either.
Electrical things I did do...
removed voltage regulator, bound the three wires there together (3 big red ones, one went straight to the battery, one went towards the front of the car, and one went to a relay for, I think, the rear window defrost). The big wire to the starter seems intact, I get fire in other places (so I don't think it's a ground issue). And I joined the green and blue wires from the regulator together. The green wire goes to the alternator. There is a big red wire that goes to the alternator and then to a 70 amp fuse I installed, on the other end of that is the 3 big red wires previously mentioned. _________________ ---
Posted: Tue Jan 17, 2012 5:33 pm Post subject: |
I'm starting to think it is the ignition key switch, the original of which was ripped out of the car and tossed to God knows where. The shop that didn't want to pony up for the motor loss was good enough to throw in a key switch so I could at least turn the steering wheel and I am 100% certain that this switch is of the highest quality. Or, more likely, the opposite of that. I'm 100% certain it is one of those things. So is there a quick, easy way to hot wire the starter just to see if it works? How do I determine if it is the starter or the switch? _________________ ---
Posted: Tue Jan 17, 2012 6:23 pm Post subject: |
Hot wired it. Probably ignition switch, I guess, because starter turned over and car tried to run. Will try again tomorrow! Have to get a new ignition switch but in the meantime I can get to tuning it. _________________ ---
Posted: Tue Jan 17, 2012 7:36 pm Post subject: |
Posted: Tue Jan 17, 2012 8:32 pm Post subject: |
Two thumbs up!!! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
RailGuy Samba Member
Posted: Tue Jan 17, 2012 10:21 pm Post subject: |
"i dont want to be in here"
"ok"
made me laugh.
Congrats, sounds good. |
vwfanatic67 Samba Member
Joined: July 19, 2003 Posts: 427 Location: Warner Robins, GA
Posted: Wed Jan 18, 2012 7:12 am Post subject: |
congrats dude sounds like I remember it. _________________ "white trash but worth every cent"
SBS #74
52 Split Beetle
60 Panel
65 Notchback
More if my wife would let me! |
Posted: Wed Jan 18, 2012 7:34 am Post subject: |
vwfanatic67 wrote: |
congrats dude sounds like I remember it. |
Ha, cool. Thanks for checking on the progress! It's supposed to be pretty nice today so I will get it tuned up a bit better and then turn my attention to the front end which is in shambles. God, I hope this works. _________________ ---
Posted: Wed Jan 18, 2012 2:49 pm Post subject: |
this afternoon has been terrible. First off I found gas under the car this afternoon... fuel pressure regulator leaking terribly. Lost a gallon of gas replacing the line from the back of the car to the T, all in my eyeballs.
Moved the car out of the garage so I wouldn't die from CO poisoning and now ... SCREECHING http://www.thesamba.com/vw/forum/viewtopic.php?t=496071 _________________ ---
