rickycox Samba Member
Joined: April 14, 2008 Posts: 21 Location: London, England
Posted: Fri Mar 10, 2023 10:06 am Post subject: Re: '58/'59 Beetle Discussion |
Ash tray plate… no I’m afraid not…
The only part with colour on is the body shown in the photos.. _________________ The Wonky Donkey Emporium
Classic Volkswagen & Porsche Restoration
www.wonkydonkeyemporium.co.uk
Follow us on Twitter - www.twitter.com/thewonkydonkey |
VWNate Samba Member
Joined: October 04, 2016 Posts: 374 Location: Sunny So. Cal.
Posted: Fri Mar 10, 2023 11:54 pm Post subject: '58/'59 Beetle Defroster Ducts |
Okay, I'm confused ~ my early '59 Bug has paper defroster tubes coming up the door pillar and of course, one is damaged .
How do I go about getting _all_ the old crispy paper duct out then how do I attach the bottom of the reproduction metal duct to the bottom ? .
TIA, _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1791 Location: Winnipeg
Posted: Sat Mar 18, 2023 8:07 pm Post subject: Re: '58/'59 Beetle Discussion |
You have to cut the base of the A-pillar open. Sorry.
Don _________________ Better and better mistakes! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7033 Location: Clyde, TX
Posted: Sat Mar 18, 2023 8:40 pm Post subject: Re: '58/'59 Beetle Defroster Ducts |
VWNate wrote: |
TIA, |
If you're the kind of person with the patience and skill to build a sailing ship in a bottle then you can achieve what you want through the small access hole in the footwell a few inches forward of the bottom of the A pillar. The heater channel has a short metal stub of a tube that the defrost tube slips over; once cleaned off you'd need to fish the new tube down the "black hole" area in the trunk and slide the tube onto the stub.
If you lack these skills and patience, cutting open the A pillar will have you pulling out much less hair. _________________ 1960 Ragtop w/Semaphores "Inga" |
VWNate Samba Member
Posted: Sun Mar 19, 2023 11:39 am Post subject: Defroster Tubes |
GAH ! .
I do mean thank you both for replying .
I'm going to try and wrap the slightly damaged paper tube, wish me luck .
I don't know how to weld and body works have never really been my thing .
I appreciate any and all replies, I have several threads going and get very little feedback .
my59 Samba Member
Joined: August 13, 2003 Posts: 3803 Location: connecting the dots
Posted: Sun Mar 19, 2023 12:16 pm Post subject: Re: '58/'59 Beetle Discussion |
Before you go sticking your hand into the black hole, shine a light and look. Make sure your tetnus shot is up to date.. I have vauge recollection of the carpet nail tips causing some mayhem. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
VWNate Samba Member
Posted: Sun Mar 19, 2023 12:28 pm Post subject: it _BIT_ me ! |
Thanx for the reminder! .
I was a VW Mechanic for decades back during the glory years and I have the scars to prove it ! .
Now I know better and use a long telescoping wand with a strong magnet on the end to see what's lurking down there, I have found more than a few original tool kit tools this way .
I need to learn how to post pictures on SAMBA so I can share some of this raggedy old mess of a car . _________________ -Nate
Randoli Samba Member
Posted: Sun Apr 02, 2023 11:44 pm Post subject: Re: '58/'59 Beetle Discussion |
My Aussie CKD is June 59.
Has fender flares, no wire tubes.
Has 3 rib panel at build plate.
Has no metal at base of drain tubes in engine bay.
VWNate Samba Member
Posted: Mon Apr 03, 2023 3:59 pm Post subject: Re: '58/'59 Beetle Discussion |
Your images don't show....... _________________ -Nate
jbannon Samba Member
Posted: Fri Apr 28, 2023 6:53 am Post subject: Re: '58/'59 Beetle Discussion |
rickycox wrote: |
This is my 58 UK RHD Bug, previous owner had the shell bead blasted 15 years ago then stored in a barn without being primed !!!
I have no floor pan to get a BC, so what do people think the colour might have been, photos below show all the colour I can find.. to me I thought maybe Capri Blue ?? |
It's difficult to tell the color from your photos. However, if your car is a 58 model year, the paint is a light blue, and the paint does not have a metallic sheen to it, then Capri makes the most sense. There were only two blue colors in 58 for hard top beetles--Capri and Glacier Blue. Glacier Blue was metallic.
Another consideration would be if your car was a Standard model and not a Deluxe model. Jupiter gray has a bluish hue as well.
Given the small sample size, your best bet would be to get a birth certificate from VW. While not a perfect solution it may help.
Best of luck! |
VWNate Samba Member
Posted: Sat Apr 29, 2023 3:35 pm Post subject: Shift Rod Bushing Question |
What year did they begin using the split plastic bushing underneath the shifter ? .
Posted: Sat Apr 29, 2023 8:12 pm Post subject: Re: Shift Rod Bushing Question |
VWNate wrote: |
TIA, |
I believe 1960 or 1961. 1958-59 did not use them, and instead relied on a heavy dose of grease. |
VWNate Samba Member
Posted: Sat Apr 29, 2023 9:06 pm Post subject: Re: '58/'59 Beetle Discussion |
Thanx, I have changed many of them over the decades, the one in my '59 was squeaking but only needed cleaning of mucho rock hard Lithium grease, a dab of new and proper adjustment to return the tranny to *perfect* shifting ~ it even slips into first gear easily when rolling .
' _________________ -Nate
VWNate Samba Member
Posted: Sun May 14, 2023 3:09 pm Post subject: BROSOL 30PICT Carby Manual Choke |
I have been searching and not found any discussions on this manual choke carby .
I bought one, a Brazilian one not the Chinese copy and it came with a #120 main jet and a stubby #200 float valve .
I put it on my 36HP engine and it runs out pretty well, first mileage check was 31 MPG, yesterday I took a long back roads drive up to Mariposa, Ca. from the L.A. basin and when I reached Mariposa the engine flooded and died at a stop sign .
This is when I discovered the wrong, #200 float valve ~ I carefully took the top of the carby off and the float bowl was so full it was almost over flowing .
I had an old 28PCI carby in my spares box and harvested and tested the old German SOLEX # 1.5 float valve, put it in and away I went, no more flooding .
I'm just curious if anyone else has tried these carbys on 36 or 40 HP engines ? .
I'd put a #130 main jet if it was on a 1600 . _________________ -Nate
Posted: Sat May 27, 2023 11:19 am Post subject: Re: '58/'59 Beetle Discussion |
I’m curious what the 58-59 community is using to reattach the interior chrome molding inside their cars. These cars use the brass/chrome metal trim which used special retaining clips. Later ones used plastic retaining clips. Any ideas on what to use is appreciated. |
AlteWagen Troll
Posted: Mon May 29, 2023 1:40 pm Post subject: Re: BROSOL 30PICT Carby Manual Choke |
VWNate wrote: |
I put it on my 30HP engine and it runs out pretty well, first mileage check was 31 MPG, yesterday I took a long back roads drive up to Mariposa, Ca. from the L.A. basin and when I reached Mariposa the engine flooded and died at a stop sign .
I had an old 28PCI carby in my spares box and harvested and tester the old German SOLEX # 1.5 float valve, put it in and away I went, no more flooding .
I'd put a #130 main jet if it was on a 1600 . |
The problem is not the needle valve but fuel pressure. Verify its below 3psi as the current production solex and replacement valve cannot tolerate more and will quickly flood the carb _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1898 Location: Fontana
Posted: Tue May 30, 2023 11:22 pm Post subject: Re: '58/'59 Beetle Discussion |
jbannon wrote: |
I got those from. Wolfsburg West not the best fit you may want to source OG ones _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
bwaz Samba Member
TXHCBeetle Samba Member
Joined: October 07, 2021 Posts: 174 Location: Boerne, TX
Posted: Wed Aug 02, 2023 9:50 am Post subject: Re: '58/'59 Beetle Discussion |
Can anyone confirm if the original rear view mirror mounting screws were flat-head or Phillips-head? _________________ In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red |
my59 Samba Member
Posted: Wed Aug 02, 2023 3:13 pm Post subject: Re: '58/'59 Beetle Discussion |
TXHCBeetle wrote: |
Can anyone confirm if the original rear view mirror mounting screws were flat-head or Phillips-head? |
Philips, and not flat head.
