nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Sun Dec 06, 2009 1:58 pm Post subject: Splitcase trans.... lets talk! |
I'm restoring a 70's era glass dune buggy that was built on a 1958 Type 1 pan. It origanly had a 36hp mill and splitcase trans. Well, now I have a 1600cc SP (1966) going in, but I still have the splitcase trans. There really isn't too much info on these trans as far as what they can handle. what are there weak points and what are their strengths. I can't even find a picture of what they look like on the inside. I have found, however that my trans has a needle bearing on the pinion shaft, unlike the early splitcase that uses ball bearings. So my question is... can an 1958 split case handle a 1600cc SP in a 1200lb car for street driving? Looking for all insight, facts, and opinions....
-Nick- |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1298 Location: south san francisco
Posted: Sun Dec 06, 2009 4:42 pm Post subject: |
i say run it. avoid drag race starts . there fairly strong . first gear and the ring and pinon i would say are the weak links. a buddy of mine had a 1600 in a shorty single cab with a split case and used to pop wheelies with it. never broke the trans. normal to spirited driving it will be fine.
steve |
Posted: Sun Dec 06, 2009 8:23 pm Post subject: |
Thats what I figured. I see guys here in the Vintage Speed Forum running hopped-up Okrasa 36hp motors on splitcase trans, and it looks like they are pushing more power than a stock 1600 SP. I'm thinking about opening the trans, cleaning out all old fluid, re-sealing it and running it. Figure, it only has 33k miles on it... should be in decent shape. I plan to use 6V 180mm flywheel and 6Volt starter.
-Nick- |
nsracing Samba Member
Posted: Sat Dec 12, 2009 1:51 am Post subject: |
Toss that split in the trash. Get you a late case and do a nice swing axle. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sat Dec 12, 2009 10:27 am Post subject: |
nsracing wrote: |
There really is no need for him to do that. The low gears of the early trans will go well with tall buggy tyres as well once the 1600 is in. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Sat Dec 12, 2009 12:13 pm Post subject: |
Come on Krusher. If you have ever done an early split trans, you will see what I mean.
Toss it in the trash or save it for a giant paper weight.
You do not want to be stuck out there w/ a broken trans. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13960 Location: Southampton U.K.
Posted: Sat Dec 12, 2009 12:48 pm Post subject: |
nsracing wrote: |
Well if you really think its such a bad trans that it worth nothing more than throwing away then it would be nice for you to outline it week points so people know.
I dont know its weak point and would like to know what parts of it the 50hp of a 1600sp will break.
I'm just not trying to make the guy spend money if he really dosent have to. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Tue Dec 15, 2009 7:41 pm Post subject: |
For starters.... no synchro 1st. The mainshaft is smaller than your pinky.
Second...very tiny gear teeth. The gears in my lawnmower has bigger teeth.
The axles are also skinny.
You really do NOT to go far away from civilization w/ this early trans.
I think VW came up w/ much better trans real quick after the split.
If you are trying to save few bucks it is not worth it if you want to take this vehicle in the dunes. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Dec 15, 2009 9:26 pm Post subject: |
nsracing wrote: |
You really do NOT to go far away from civilization w/ this early trans. |
Lots of dune buggies were made in the 60/70" that utilized the "bigger" 1500cc engine with no problems other than a non synchro first gear.
As to not driving one a far piece maybe it is the driver not the trans
Ask me, I know how far I would drive one of those pos trans.
Save your bucks and use it. If and when it brakes then? |
Posted: Wed Dec 16, 2009 8:01 am Post subject: |
This is like....I am telling NOT to put a sledgehammer to your head. And someone is telling you it will only hurt a little or not at all.
I told you so is going to come later I am sure. |
tkelley Samba Member
Joined: January 10, 2006 Posts: 1597 Location: Where Pterodactyls crash and burn...
Posted: Sat Dec 19, 2009 3:19 pm Post subject: |
I've driven my split case from South Florida to Upstate SC, about
750 miles one way. No problems.
Drove it daily for awhile...again no problems.
There are plenty of people driving split case trans out-of-town,
with no problems...
If you know how to drive and keep it within it's limits....you'll
have no problems.
NSR, Next time you're going to throw one away, send it to me instead.
Tom _________________ When the sun doesn't rise, we'll replace it
with an H-bomb explosion or a painted jail cell... |
ProjectX Accessory Nut
Posted: Sat Dec 19, 2009 8:47 pm Post subject: |
I'm sure a few split cases made cross country trips back in the day.... my '53 had clocked 91,000 miles on it before it's restoration, with the original transmission so I think they are pretty bulletproof if serviced well.... or not _________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
Posted: Sun Dec 20, 2009 1:51 pm Post subject: |
To the guy that stated "Thats why VW changed the design of the trans...". Splitacse was used for over 23 years, while tunel style less than 17. I think it comes to one fact.... ABUSE! Splitcase has fewer aftermarket parts, making them more likely to break under severe abuse. The 1100cc and 1200cc motors weren't designed for drag racing or dunning, so it makes sence you can't run a 2332cc on these transaxles. However, there is no reason why a stock or mildly moded 1600cc can't be ran. Talk to anyone with Okrasa (sp) 1200's... they're making 70+hp, or even the Formula Vee guys, of which I've seen plenty run splitcase. I would still like to see some picks of splitcase insides!
-Nick- |
Shadd Samba Member
Joined: January 18, 2007 Posts: 883 Location: Lancaster, Ohio
Posted: Sun Dec 20, 2009 7:20 pm Post subject: |
I put a 1600DP in my 59 and drove it for years, even made a trip across the country. There were many occasions where I beat the shit out of that transmission and it always held up to the abuse. I once power slide it through a corner so hard that the tires popped and the rims collapsed. Never so much as a groan from the splitcase. I don't know where you can find any info about rebuilding them, but I can say that your probably safe to run it. Besides its a dune buggy, you plan on making many cross country trips? |
Posted: Fri Dec 25, 2009 8:20 am Post subject: |
Actually, yes I do. I plan to make a regular driver out of it. Maybe not a "Daily" driver, but for sure an "at least one day of the week drive to work in it" driver. I think this whole "tunel style better than splitcase style" arguement has snowballed over the years from alot of mis-information. I'll keep everyone posted on the rebuild, then I plan to put this trans to the test. I feel this is going to be "Myth BUSTED"!
-Nick- |
Posted: Fri Dec 25, 2009 9:34 am Post subject: |
You have never seen the inside of a split trans and yet you insist that you are going to Myth-bust?
I am sure you will be myth-busted...in the desert! More like stranded. |
Posted: Fri Dec 25, 2009 10:10 am Post subject: |
nbuscemi wrote: |
Actually, yes I do. I plan to make a regular driver out of it. I feel this is going to be "Myth BUSTED"!-Nick- |
Sorry to bust your myth but I done it
over 200k on my ride. 3902 miles this summer on a two week trip to Funfest thru 7 states and yes I've seen the inside of a split case.
And it prolly won't leave you stranded if you drive it like an old POS junk fricken split case tranny. JMHO from owning AND driving one. |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Fri Dec 25, 2009 6:23 pm Post subject: |
i straight axled one and threw it in and no problems with the setup just make sure you check your reverse gear...mine is wasted and the trans is coming out for the same setup just a fresh trans.pretty basic and straightforward...
dont let people nay say about what is possible with the early gearboxes...they hold up fine.just a little loud.especially people that put 1600dp in everything they drive no matter what...
_________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Posted: Fri Dec 25, 2009 6:50 pm Post subject: |
Nice bus! Do you have any more pics of your splitcase. Looking for teardown and rebuild pics especially!
Thanks!
-Nick- |
