59eurobug Samba Member
Posted: Fri Jan 08, 2010 4:23 pm Post subject: |
I used smoke grey for my bumper brackets and headlight bucket too, looks OG _________________ May '58 Deluxe Beetle
March '59 Euro Beetle
May '99 Passat 1.8T
DRK |
crowe66 Samba Member
66RHD Samba Member
Posted: Tue Jun 22, 2010 12:07 am Post subject: |
What about assembly for the European headlights with the smaller 'bulbs' instead of the American 7" round ones? I pulled the headlight assembly out to inspect, and saw the myriad of tension springs, etc. and was a little baffled. It seems there is more 'pieces' to the American version. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Tue Jun 22, 2010 3:22 am Post subject: |
Dumb ??? - My wife had restored a set of these for her 61 and I love them - but the repros I got for my 65 seem very cheesy with coil springs on the adjusters. Did VW change the style later or just that the new repros are crappy? Just curious. _________________ D-Dubya Manx clone - 63 Short pan,1914.
dakdak Samba Member
Joined: March 09, 2009 Posts: 579 Location: Sydney, Australia
Posted: Tue Jun 22, 2010 4:30 am Post subject: |
66RHD wrote: |
The European is similar in that the bucket of the headlight is held to the outer chrome trim by those springs. The difference being that the reflector is seperate to the bulb.
I also like the look of the fluted outer lens as opposed to the clear outer lens. _________________ The great enemy of the truth is very often not the lie - deliberate, contrived and dishonest, but the myth - persistent, persuasive and unrealistic.
JFK |
dakdak Samba Member
Posted: Tue Jun 22, 2010 4:32 am Post subject: |
andk5591 wrote: |
Dumb ??? - My wife had restored a set of these for her 61 and I love them - but the repros I got for my 65 seem very cheesy with coil springs on the adjusters. Did VW change the style later or just that the new repros are crappy? Just curious. |
I'm not aware of VW changing the adjusters for those headlights. Just the repros use a cheaper method to do things. _________________ The great enemy of the truth is very often not the lie - deliberate, contrived and dishonest, but the myth - persistent, persuasive and unrealistic.
JFK |
CRoe Samba Member
Joined: July 14, 2006 Posts: 126 Location: Gadsden, Alabama
Posted: Tue Jun 22, 2010 4:54 am Post subject: Early headlight assembly |
Thanks for the post and pics. From your pics I realize I am missing the tension spring on the ligts for my 65. I had to wedge washers between the two pieces to adjust them right. I don't like "rigging" things so this will help, I hope.
Clyde _________________ I'm not afraid of the Devil, I married his sister!!!
63 Ghia Vert
68 Ghia Hardtop
74 Dasher Wagon
61 Baja
68 Baja
71 Super Beetle
65 Beetle --Current ride |
83_WabbitGTI Samba Member
Joined: December 01, 2006 Posts: 1335 Location: Eagle Point, Oregon
Posted: Tue Jun 22, 2010 1:48 pm Post subject: |
I had a post similar to this about 2 years ago.. Not as detailed though... Great write up!
BTW. I found it easier to put the long side of the spring in first then the short side. It takes most of the spring tension off so you don't put an eye out. _________________ 2013-2014 Vice President of SOVW www.sovw.org
"No matter how a VW breaks down.... You can always make it home on Zipties, Ducktape, and JB Weld...."
-Doug Christen, VW Owner
83 Rabbit GTI - 83 Rabbit LS Custom - 63 Westy - 65 Bug - 64 Baja (Herbie's Studly Cousin) - 91 Audi 90 Quattro 20v - 85 Vw Cabby - 84 VW Scirocco - 69 Beetle (Phantasm Bug) - 78 Cabriolet
Need a VW website built? PM me. |
Lockfordian Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Mon Jul 19, 2010 8:12 am Post subject: |
Those rubber sleeves are for the later style headlight buckets, with the diagonal adjusters, not the early ones talked about previously in this thread.
I'd not seen WW's writeup about those before, or if I had, I'd forgotten it.
I did take some detail photos though of this style headlight bucket for reference some time ago (I have some NOS German buckets as well as some India-made knockoffs)
The pieces you are referring to, those are sort of a poor design, each bucket has two rubber sleeves that the adjuster arms poke through. Then another one across from the adjusters that the bulbholder pivots on. And these are all inside a metal/glass enclosure that has a bulb that produces lots of steady heat - it's surprising they don't fail more quickly than they do. Hella's rubber sleeves must have been of an appropriate quality to withstand it. Now, I don't know how well WW's replacement sleeves hold up compared to the originals. (I've had some less-than-great experience with some of WW's rubber/vinyl parts before, about the only things I've ever had any issue with from them)
Maybe these photos will help you see where those rubber sleeves go on the diagonal-adjuster buckets.
vdubpq32 Samba Member
Posted: Sat Nov 13, 2010 3:20 pm Post subject: |
Nice writeup!
Apparently, while taking apart my driver's side headlight to adjust it (screws were not working), I found out that it is missing the retaining ring...where is the best place to buy that? |
bfunke Samba Member
Posted: Sat Nov 13, 2010 6:50 pm Post subject: |
These old clear glass buckets just seem to be begging to be mated with a modern HID projector. Anyone found a good mount to adapt the Hella HID projectors to the 7inch sealed beam retaining ring? This combo would give great vintage looks with modern lighting performance. |
Livin'LaVdubLoca Samba Member
Joined: December 05, 2005 Posts: 104 Location: Boulder, CO
Posted: Sat Nov 13, 2010 7:24 pm Post subject: |
Great writeup... thank you.
**subscribing for future reference**
_________________ --KEVIN--
My '67 Type 1 Project
Give a man a fish and he will eat for a day. Teach him how to fish and he will sit in a boat and drink beer all day. |
CLASSIC CAR GUY Transport and Title Guru
Joined: August 09, 2010 Posts: 1608 Location: Phoenix AZ, but originally from Long Island NY
Posted: Sat Nov 13, 2010 9:43 pm Post subject: |
great right up, i did my 62 a few months back and used a good grey that was about the same color as stock, but had a light metallic to it, but not silver, it really woke up the light at night! i tossed the can when i was done and i dont remember the color, it was a duplicolor paint though, one of those small cans, i bought at pep boys probably 10 yrs ago and it was just sitting in my paint cabinet, i cant remember what i bought it for in the first place either , but ill figure it out it was a ford color i think _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com |
faster Samba Member
Posted: Wed May 11, 2011 4:50 pm Post subject: |
Everett asked me two years ago to post my headlight restoration for my 65 single cab and to post it here with some pictures. Remember this is for a bus and not a bug.
I`m thinking it was the rubber plugs that I made that he wanted me to show and where to get them so here you go.
Heres what I did to replace the old rubber bought O-ring stock 8mm I think make sure and check it from McMaster-Carr for less then $10.00 per foot and made my own. Heres the old and dryed rubber that couldn`t be saved.
Heres the O-ring that I used.
This is the old and the new with a paint matched from Ace Hardware
The new sprayed around the lettering
_________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
BGLOCOTE Samba Member
Posted: Thu May 12, 2011 7:41 pm Post subject: |
Wish I woulda found this topic 2 days ago. Note to self if wife is watchin you take apart your headlight and your not wearing safety glass and a spring goes flyin by her head she might get alittle mad.......... and I still haven't found that spring yet lol. _________________ 1955 TYPE 1 Under Construction
1962 TYPE 1 SOLD
Looking for 54-55 TYPE 1 finger tin.
UNITED STATES SUBMARINE VETERAN |
Posted: Mon May 16, 2011 4:31 pm Post subject: |
vdubpq32 wrote: |
Nice writeup!
So finally got back to working on the car...here is a photo of all of the parts from my driver's side headlight (sealed beam bulb excluded, which is still connected to the car):
As I said, no apparently retaining ring, and the only springs that I found were sitting at the bottom of the fender recess.
The passenger side is better (it's assembled at least, with springs), but still no ring:
Only 4 springs on the inside and 4 on the outside.
Does anyone know the best place to buy my missing parts, or entire headlight assemblies? Thanks. |
russtee54 Samba Member
Joined: February 11, 2011 Posts: 236 Location: Waco Texas
Posted: Mon May 16, 2011 5:06 pm Post subject: |
A neat way to not get sproinged by those pesky springs when you take them out is to cover it with a shop rag before you sproing it. However safety glasses are always in order when working on things under tension, (said the blind mechanic to his Deaf and mute helper). |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
stale air Samba Member
Joined: August 23, 2007 Posts: 5155 Location: Senoia Ga, formally NorCal
Posted: Tue Aug 02, 2011 3:27 pm Post subject: |
It goes right between the h/lamp lip on the fender. You can kinda see it in this pic.
_________________ WANTED: Henry Veale Santa Rosa plate frames
