Shonandb Samba Member
Joined: January 12, 2019 Posts: 1204 Location: Vancouver, BC
2type2 Samba Member
Joined: June 02, 2002 Posts: 980 Location: SW Colorado
Posted: Wed Jan 10, 2024 9:16 am Post subject: Re: Fog Light Fest |
Looks good with bar, but how is that bar mounted? _________________ "A life of peace and happiness depends on your own gratefulness" |
racecougar Samba Member
Joined: July 31, 2023 Posts: 107 Location: Imperial, MO
Posted: Wed Jan 10, 2024 10:06 am Post subject: Re: Fog Light Fest |
racecougar wrote: |
I just placed my fog lights up on the new roof rack:
This is with smoked covers on the fog and off-road lights (street legality purposes & I didn't bother to take them off for the photo).
Posted: Mon Jan 15, 2024 3:39 pm Post subject: Re: Fog Light Fest |
2type2 wrote: |
Looks good with bar, but how is that bar mounted? |
If you are referring to my Bush Bar, I had L-brackets welded to the frame underneath but am in the process of modifying them to extend my air scoop farther forward. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
2type2 Samba Member
Posted: Tue Jan 16, 2024 9:03 am Post subject: Re: Fog Light Fest |
Yes Shonandb , I figured there had to be some fabrication. I wish somebody with metal skills would offer up some alternatives to Hursts , being that some of us would consider adding alternative bullbars or 'Roo bars for the purpose of lights or protection from wildlife. Need offerings for both splits and bays! _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Tue Jan 16, 2024 11:11 am Post subject: Re: Fog Light Fest |
2type2 wrote: |
Yes Shonandb , I figured there had to be some fabrication. I wish somebody with metal skills would offer up some alternatives to Hursts , being that some of us would consider adding alternative bullbars or 'Roo bars for the purpose of lights or protection from wildlife. Need offerings for both splits and bays! |
I kept my eyes out for a while and found this Bullbar on my local Craigslist and liked the look. It's 3.5" tubing and I could have used spring u bolts and some hardware or drill holes to attach it to the frame but figured welding would be stronger. I had an extra bent bumper so I straightened it and attached the bar to the bumper using stainless exhaust clamps so it is easy to remove (2 mounting bolts) and put the original bumper back on. I thought I would switch it back but the bar has grown on me and it makes a great ladder to get into the luggage rack bag.
I see that you are in Colorado. I lived in Edwards and worked in Vail one ski season back in the early 90s. I was driving a 73 VW Panel Bus at the time but only saw a bit of the State while I was there. Here's a pic from San Luis Lake/Reservoir.
indianpeaksjoe Samba Member
Posted: Sat Jan 20, 2024 9:16 pm Post subject: Re: Fog Light Fest |
Finally got around to wiring up my rack lights. Hella ValueFit in the front and a Hella ValueFit in the rear for reverse.
-Joe _________________ Adventures in owning a 66 beetle |
2type2 Samba Member
Posted: Sun Mar 10, 2024 11:24 am Post subject: Re: Fog Light Fest |
made these brackets from 6"x 2", 16 guage sheet. Mount to either side of bper bracket bolt. Note offset of holes for R+ L sides.These are for split bus with blade bumper specifically. But you can bend anything hoss. _________________ "A life of peace and happiness depends on your own gratefulness" |
