vwb5t Samba Member
Posted: Thu Apr 23, 2009 7:33 am Post subject: fuel injection conversion |
Looking to convert to fuel injection, what are the good kits out there? engine is a 1641 with dual carbs but i want to go fuel injection, but one that is tunable cause i will be upgrading the motor later on. its going in a 64 baja. |
The Noof Samba Member
Posted: Thu Apr 23, 2009 7:49 am Post subject: |
Megasquirt is a good ecu format, if you're handy.Stock efi can work well on a 1641, depending on your combo.If it was a biiger engine, I would recommend cb's quick-tune efi:I have it on my car, and I love the adjustability. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3495 Location: Charleston, SC
Posted: Thu Apr 23, 2009 8:00 am Post subject: |
1) MegaSquirt: not a bolt-on kit, but the least expensive option. It requires that you design the intake, whether using IDF throttle-bodies, or adapting a single throttle-body to be used with CB Performance-style fuel injector end-castings. In the end, you will know the fuel-injection and its hardware inside and out. Despite its low cost (and high investment of time), MegaSquirt has the same features as many of its overpriced competitors, and more! Who else has in-car touch-screen tuning capabilities? The user- and knowledge-base for MegaSquirt is unreal and more features are developed by these users day by day.
2) CB Performance Quick Tune EFI: bolt on and go. Press a button or two on your laptop and it supposedly programs itself. Several people have been very pleased with this system, from Mike Lawless on his wife's 1776, to Don Pauter on his 3.5L Pauter powered Ghia. [edit: oh yeah, and Noof is happy, too ]
3) DRD Racing: Darren is currently marketing an EFI kit. I can't recall if he is using the Microtech ECU out of Australia or another brand (so don't quote me on it). Drop him an e-mail and he can probably quote you a price and timeline on a complete kit to bolt in and go.
4) Marty Staggs: IIRC, a distributor for Haltech ECUs. He can fabricate a complete intake set-up to accompany the ECU so it can be a bolt-in affair.
5) Weber/Redline EFI: IIRC, a complete kit is offered by the vendors who distribute this ECU (VW Paradise is among them). The person who designed this EFI is a regular contributor to the EFI forum at the shoptalkforums.com.
6) Electromotive: not a complete kit so, like MegaSquirt, you are responsible for procuring/fabricating the throttle-bodies, intake, etc. Recommended only if you have more money than brains. I'm currently running their Tec-GT ecu and the AutoTune feature has never worked. The previous 2 versions of the software commonly crashed during tuning, and the functionality of playback on the datalogger has been spotty (add that headache to the dysfunctional AutoTune feature). Maybe the 3rd release of the software they recently sent me will finally work properly. But hey...I can tell people I'm running Electromotive and they always seem impressed
There's other ECUs on the market that vary in price and features, but few are available as "kits" outside of what CB Performance and other VW vendors offer for the VW engine. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Apr 23, 2009 8:58 am Post subject: |
I'm partial to MS because I'm a tightwad, but I was really impressed by how much it does. I bought one of the first kits that came out way back before it could do ignition control; I have that same ECU in my car today, but it's now running the injectors, distributorless ignition, and will soon be handling alcohol injection duties as well. It turned out to be a decent investment at the time costing me only $175 if I remember correctly, and it's capabilities have done nothing but grown. Like Stripped said, you will know your hardware and software from the inside out when you're done, because you have to do everything yourself. Not to say that you're alone in your efforts though- MS has one of the biggest support forums out there, I've never seen a bigger group of guys (and gals) that go out of their way each day to further the MS movement. If you need help, you can always ask. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu Apr 23, 2009 6:01 pm Post subject: |
Megasquirt rocks.
You just can't beat the price, and has more features than you can shake a stick at.
I really don't know of any features avaliable on other EFI systems that aren't avaliable on MS. I'm sure there may be, but none that I apparently need. There's a lot more than I need in mine as it is. haha _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 579 Location: Colorado Springs, CO
Posted: Fri Apr 24, 2009 8:54 am Post subject: |
I have used SDS and it is a solid standalone with good adjustment and price, but without the need for a laptop for mapping.
I have Megasquirt I need to build for the current project, but I know it is a great value and very capable, especially thanks to all the people sharing info and supporting it.
Don't overlook the factory EFI setups. Wasserboxer, Porsche 914, Type 3 and 75+ Type 1. It might be hard to get a complete, excellent condition setup, but the cost might be more attractive than a custom build. Depends a lot more on you and your engine setup and wallet. _________________ 1972 Porsche 911E Hot Rod (3.4 Turbo)
1973 VW 412
1979 Audi Fox GTI
2002 Eurovan
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
Posted: Fri Apr 24, 2009 11:21 am Post subject: |
Stock hardware witha megasquirt ecu would be fine for a 1641. |
joescoolcustoms Samba Member
Posted: Fri Apr 24, 2009 11:29 am Post subject: |
Quote: |
1) MegaSquirt: not a bolt-on kit, but the least expensive option. It requires that you design the intake, whether using IDF throttle-bodies, or adapting a single throttle-body to be used with CB Performance-style fuel injector end-castings. In the end, you will know the fuel-injection and its hardware inside and out. Despite its low cost (and high investment of time), MegaSquirt has the same features as many of its overpriced competitors, and more! Who else has in-car touch-screen tuning capabilities? The user- and knowledge-base for MegaSquirt is unreal and more features are developed by these users day by day. |
Not trying to Hijack, but I guess I am.
Who sells MegaSquirt? Can you take a set of IDF's and gut them to be just throttle bodies for this application or am I missing something already produced? Will the throttle bodies need to be modified to accept a TPS?
Shouldn't there be a FI Sticky for this? _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Matt Cramer Samba Member
Joined: October 17, 2008 Posts: 86 Location: Covington, GA
Posted: Fri Apr 24, 2009 11:39 am Post subject: |
joescoolcustoms wrote: |
Shouldn't there be a FI Sticky for this? |
Hi, I work for one of the sponsors who happens to be a MegaSquirt seller. Yes, you can gut carbs to use them as throttle bodies. We've even had one customer who put injectors in a set of SU carbs; it may work for other carbs too:
http://www.mgexperience.net/journal/scotabbott/2284
The MegaSquirt can use the MAP sensor reading instead of a TPS for acceleration enrichment. One of our shop cars never had a real TPS from the factory and so it's running around without one. _________________ Matt at DIYAutoTune.com
Megasquirt EFI, wideband O2 sensor displays, injectors, and more |
Posted: Fri Apr 24, 2009 4:49 pm Post subject: |
Have you looked in the sticky section?
My build thread is up there, and in my sigline. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Fri Apr 24, 2009 5:33 pm Post subject: |
miniman82 wrote: |
My build thread is up there, and in my sigline. |
I knew about your build and have looked at your sig line thread, but with all the threads on ignitions and cranktriggers lately, I thought it may be good to start a Sticky on FI. I am reading more and more about it in the last year or so. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Smallsc111 Samba Member
Joined: February 05, 2009 Posts: 203 Location: Dallas,TX
Posted: Sun Mar 01, 2015 10:59 am Post subject: |
Might be the biggest bump in samba history....
I'm looking at the CB performance set up, does it have the capability of running a turbo with it? _________________ '74 Baja- Dad's Daily
*PROUD FORMER DAS KLUB MEMBER*
thechief86 wrote: |
jlex wrote: |
Might as well be driving a Hummer....  |
nah, then he'd look like a jackass on top of getting crummy mileage. at least the bug looks cool |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4915 Location: sanger ca
Posted: Sun Mar 01, 2015 11:23 am Post subject: |
Smallsc111 wrote: |
I'm looking at the CB performance set up, does it have the capability of running a turbo with it? |
Yes, however they are out of ecu's currently. Waiting on one myself. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sun Mar 01, 2015 11:26 am Post subject: |
Look at thedubshop, Mario there will help you out and give great advice, an won't rob you blind! He's a good guy.
I'm running my 1200's ignition on a basic MS1 2.2. Doing that to learn a little before I make that same ecu run gsxr throttle bodies on a 2110  _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
Posted: Sun Mar 01, 2015 11:27 am Post subject: |
mcmscott wrote: |
Smallsc111 wrote: |
Yes, however they are out of ecu's currently. Waiting on one myself. |
Eh can't afford it yet so just as well. Post some pictures when you get it done _________________ '74 Baja- Dad's Daily
thechief86 wrote: |
jlex wrote: |
